Projects Tucks AV8 Pickup build thread-----> BABE THE BLUE OX
Discussion in 'Traditional Hot Rods' started by Tuck, Aug 26, 2013.
  1. dumprat
    dumprat
    from b.c.
    Very cool!
    Tuck likes this.
  2. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Thanks man-
    No, it only shrinks 3 percent, the bosses I put in there are bigger than the screw head. I also spread the bolt pattern apart 5/32” more than what they should be. Length wise you’ll notice a little shrink, width wise you won’t notice anything.
    brEad, vtwhead, Stogy and 1 other person like this.
  3. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    This has nothing to do with this thread except for the hemi. I got this Hemi adapter from Fritz Christ in the cl***ified along with the cragar to early ford I’m running on this one.
    I wanted to put this hemi in my shoebox convert but couldn’t find an adapter like this… looked and looked… Then when I go ahead and decide to put it in my truck and this one pops up haha. So I got it.
    This is how having a pile of parts you don’t really NEED starts… :eek:
    brEad, rod1, cactus1 and 5 others like this.
  4. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I decided to cast some block off plates instead of the flat aluminum stand ins for the rear water ports since I can pour these all the same day.
    I’m gonna cast the spring return mount which I’ll drill and polish it. I’ll add Allen head bolts recessed into the aluminum like the block off next to it.
    redzula, brEad, Runnin shine and 6 others like this.
  5. Tim
    Tim
    from KCMO
    Very cool! Are the flat stand offs hollow and you would just drill and tap for a hose fitting? I was curious why you hadn’t cut them off and smoothed them when I noticed them.
  6. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Thanks man, They’re leftover solid risers from the casting process, Chrysler just machined off the tops the same height as the water inlet. I’m going to drill and tap them. I’ll locate where I want to put the hardware, machine those and then use a transfer punch to locate where I put the holes to drill.
    Tim likes this.
  7. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Wait, if you’re talking about the flat plates, they’re on the back of the heads… they’re there because you can put a head on either side of the engine the same so the water pump bolts up either way. No tapping for water.
    brEad and Outback like this.
  8. Tim
    Tim
    from KCMO
    You had it right the first time :)
    Tuck likes this.
  9. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Got them in primer surfacer. I’ll block them out and then paint them in single stage acrylic urethane. Once they’re shiny they make really good patterns because they pull out easy and will have a nice finish.
    I’m done posting for a week, I can slam some stuff through when girls are with mom, when they come back I don’t work on this stuff so I can give them 100%.
  10. Tim
    Tim
    from KCMO
    You got a great weeks worth of work in, now for a different kind of great week. See ya when your back.
    Tuck likes this.
  11. silent rick
    silent rick
    will those chrysler head block off plates work on a dodge hemi? hint hint
    Tuck likes this.
  12. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Yes! I’m gonna make some extras Rick :D
    Tim and silent rick like this.
  13. silent rick
    silent rick
    nah, just checked, they don't look the same
  14. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    For real? Theyre different? How dare they…
    I heard there was a lot of compe***ion between Desoto, Chrysler and dodge hence some of the different designs around the same motor.. it’s amazing they have the same bellhousing pattern. :eek:
  15. silent rick
    silent rick
    little brother didn't need all that flow.
    here's what a dodge looks like
    Outback, Tim and Tuck like this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    You own the original Hildebrandt casting pattern????
    Tuck and Outback like this.
  17. Outback
    Outback
    from NE Vic
    Wow!
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    Send it to @Tuck and see if he can make em??
    Tuck, rod1, Tim and 1 other person like this.
  19. rod1
    rod1
    Wow, look at you go! I leave for a week and look what happens. Great stuff there Tuck.
    Tuck likes this.
  20. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    @silent rick those are cool! The lettering looks like it’s to squared off at the bottom, If you took some glaze and molded a fillet at the base of those letters I think that would keep the sand from getting trapped in the font. And just sand in a slight draft… thanks for temporarily sharing that ;) way cool.
  21. burl
    burl
    from Minnesota
    Enjoy seeing these cast at home parts after being involved with molding for almost 50 years.
    On thing i notice is not enough draft on the side walls. Rule of thumb the shallower the detail the steeper the angle. Shallow letters should have at least 15 degrees or more draft to pull correctly. Draft chart for example. Following these guidelines will help with successful casting.
    brEad, Outback, Tuck and 1 other person like this.
  22. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I don’t not have much to report because I’ve been sick for almost two weeks… :confused: It’s the never ending story… Can’t wait for this bug to subside. I swear I get over one thing and get hit with another.
    I prepped the gen pulley for chrome. I’m going to chrome the generator because it sticks out in your face and would look cool. I need to chrome a few brackets too so might as well drop them all off at the same time.
    I cast the spring return mount.
    Had to take 3/16” off my valley pan so it won’t hit the bottom of the intake.
    I picked up material to build an engine run stand… so the plan is to get the hemi painted and then I can mount it on the stand and work towards getting it together and ready to fire up… with the idea that the ready to go running hemi will motivate me to finish the ch***is, run break lines etc… knowing I can drive the damn thing!
    Brookville is shipping my doors and rear panel mid Jan. I’m gonna run and pick up my roadster cowl here after Christmas.
    Happy Holidays and New Year from our family-
    impala4speed, swade41, SS327 and 13 others like this.
  23. Tim
    Tim
    from KCMO
    ****ty about being sick, lots of **** going around this year. Hope the holidays treat you all well.
  24. redzula
    redzula
    That casting stuff is cool would love to learn that skill sometime.
    Hope you got back to feeling better.
    Outback likes this.
  25. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
  26. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
  27. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
  28. SS327
    SS327
    It looked better painted candy red! The silver does nothing for me.
    Dick Stevens, Tuck and loudbang like this.
  29. 57 Fargo
    57 Fargo
    Man those wire covers and valley pan are dreamy! That little Hemi is beautiful.
    Tuck likes this.
  30. Tim
    Tim
    from KCMO
    Yeeah buddy
    Tuck likes this.
