Technical ***December 2023 Banger Meet Thread - Santa I can explain***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 2, 2023.
  1. Jiminy
    Jiminy
    Link to previous month: November 2023 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    If it weren't for the last minute nothing would ever get done.
  2. 62pan
    62pan
    Checking in
  3. Kevin Pharis
    Kevin Pharis
    from Califunny
    I’m here, and with the Akron-Hed off the speedster…!:( After a steady decline in performance over the summer I found that the exhaust valve seats in cylinders 2 and 3 had settled, causing a backfire thru the carb under low rpm load. Not happy with what the machine shop did in there, so gonna pull the exhaust seats out and do em myself! Hope to have it back together this weekend:cool:
    chryslerfan55, Old Dawg, Tim and 4 others like this.
  4. denis4x4
    denis4x4
    from Colorado
    Started fixing and tweaking those things on the extended cab pickup that I’ve been ignoring. Waiting for a new touring engine from Bert’s
    Outback and 29 Speedster like this.
  5. Kevin Pharis
    Kevin Pharis
    from Califunny
    The exhaust seats that came out of 2 and 3 were installed crooked. About 1/2 of the seat pocket has no floor surface to support the seats, and the inserts were not even touching what was there. The seat pockets are only about .15” deep, but the inserts are only about .090” thick at their thinnest point… no wonder they had settled!!! 838605B7-346B-4ADC-A83E-F379F77C131B.jpeg 757F702C-DD17-4E3D-8E47-4B9528DACC9C.jpeg
    chryslerfan55, GuyW and Outback like this.
  6. lahti35
    lahti35
    Spent 2 hours taking these guys down this afternoon... One was easy, the other was a nightmare!
    Gotta get the new axle under the banger by X-Mas!
  7. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    You will love the upgraded braking..
    lahti35 likes this.
  8. UGH, that is a shame
    it looks like the port is too close to the roof of the chamber, not out of the norm for early castings.
    How deep is the pocket from roof of chamber to top of the bowl/port?
    John
    chryslerfan55 and Outback like this.
  9. Kevin Pharis
    Kevin Pharis
    from Califunny
    The ports are larger diameter than the valve heads. Machining the seat pocket breaks into the port after about .150” deep. The shop that did the work originally only put 7 seats in. They chickened out on number 4 exhaust when it completely broke out into the port. At that time I machined a .100” deep counterbore above the seat pocket, and machined a stepped diameter seat to match. This seat looked great, but I cut it out due to the shop cutting the seats really low.
    New seats are made and installed!! Just a little bit of grinding and she’ll be ready to go back together
    9BAA5FC2-AE92-4DE2-AD70-3003F7EE6DEC.jpeg C29EA619-50B2-4766-8044-60349DB14CA0.jpeg
  10. joemac05
    joemac05
    I just love it.. :D
  11. Looks really good
    J
    Outback likes this.
  12. Checking in! Ended up buying a junky coupe with no rear quarters, spent the weekend bolting parts to it!
  13. burl
    burl
    from Minnesota
    got another m-40 mated to the banger for the race car. Making progress racecar 1.jpg racecar 2.jpg racecar 3.jpg
  14. Stovebolt
    Stovebolt
    stubbsrodandcustom likes this.
  15. railcarmover
    railcarmover
    Took them all of 45 minutes once I was on the rack..
    cut out old rot, shaped bone ends and glued stainless ball covers for femur, fibula and tibia
    Cleaned rot off back of patella and glued a plastic patch on, re ***embled with a new plastic spacer between tibia/ femur.. I asked if I was riding on Delrin and got a blank look..
    big duece likes this.
  16. Kevin Pharis
    Kevin Pharis
    from Califunny
    Ouch!! Total knee replacement is not somethin you wanna sign up for till the OEM parts are clean wore out. Glad yur put back together and in good spirits… er maybe the meds haven’t wore off yet?;) Gotta make it thru day 3, then the pain will begin to let up
    ***uming the work was done here in the states, you are most likely equipped with cobalt chrome (CoCr) implants and ultra high molecular weight polyethylene (UHMWPE) patella and knee insert
  17. railcarmover
    railcarmover
    Bone on bone, couldn’t do the things I was to do. Pain? Other than the tourniquet they put on the quad it ain’t bad.. dull muscle type ache, not sharp bone like it was..
    thanks for the low down on materials
    Outback likes this.
  18. Kevin Pharis
    Kevin Pharis
    from Califunny
    Ground the valves last nite, and goin back together now! Gotta adjust the valves and re***emble all the little stuff. Should be runnin in a couple hours:D
  19. I’ve made progress! Now I just need washers, packing nuts, and to figure out the impulse coupler for the magneto!
  20. The37Kid
    The37Kid
    This turned up in a box of stuff in the garage. Aftermarket A water pump, who made them, and is there any reason to rebuild it and use it?
    Old Dawg likes this.
  21. Outback
    Outback
    from NE Vic, Oz
    I know nothing about it except it would get people talking, it's also begging for a finned top cover!
  22. Kevin Pharis
    Kevin Pharis
    from Califunny
    Day three has come and gone, how ya doin…?
  23. s.e.charles
    s.e.charles
    sorry for my ignorance, but other than (i think) a Scintilla magneto, what is this driving?
    thanks
  24. drtrcrV-8
    drtrcrV-8
    The middle thing is a water pump
    s.e.charles likes this.
  25. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    Is there any non-convoluted solution to fitting a mechanical fuel pump to an A block, or is an electric pump the only real option?
  26. I'm here again!
    This nifty two-man car belongs to a friend in Santa Barbara. He had Carl "Smoky" Alleman buid a "Pop" Dreyer Four- Banger to go in it!
    Outback, 40 Olds, burl and 3 others like this.
  27. The37Kid
    The37Kid
    Looks like it was built to stop! Sure would love to find the two man car I sold to Jim Etter. Bob
    Outback, Old Dawg, 282doorUK and 2 others like this.
  28. wheeldog57
    wheeldog57
    Currently in the cl***ifieds but I am thinking nobody wants it.
    I'd like to get it running over the winter
    Outback and Old Dawg like this.
  29. This is a Frontenac water pump, it's driven via a second crank gear hanging off the cam gear. The shaft spins the water pump, as well as a Bosche magneto!
  30. railcarmover
    railcarmover
    Pain just about gone, swelling way down.. feel good, thanks for asking.
    G Baese likes this.
