62-65 Superstock Mopars picture thread..
Discussion in 'The Hokey Ass Message Board' started by caseyajones, Mar 24, 2008.
  1. dearjose
    dearjose
    Interesting car. Appears to be a 64 hemi, steel frontend, 4 headlight hardtop belvedere.
    SS- looks like a 4spd too. Fkn bad***!!
    Deuces, jeepsterhemi, das858 and 4 others like this.
  2. dearjose
    dearjose
  3. dearjose
    dearjose
    Snorkasaurus 64 hemi
    Deuces, jeepsterhemi, das858 and 6 others like this.
  4. dearjose
    dearjose
  5. 65pacecar
    65pacecar
    from KY, AZ
  6. dearjose
    dearjose
    65pacecar likes this.
  7. 65pacecar
    65pacecar
    from KY, AZ
  8. 65pacecar
    65pacecar
    from KY, AZ
  9. 65pacecar
    65pacecar
    from KY, AZ
  10. dearjose
    dearjose
  11. dearjose
    dearjose
  12. dearjose
    dearjose
    The hustler in yellow.
  13. dearjose
    dearjose
    Flynn's brand spankin new flying carpet after the drive home from Detroit:D:eek:
  14. 63savoy
    63savoy
    from Illinois
  15. dearjose
    dearjose
    65pacecar and tommyd like this.
  16. 65pacecar
    65pacecar
    from KY, AZ
  17. 65pacecar
    65pacecar
    from KY, AZ
  18. 65pacecar
    65pacecar
    from KY, AZ
  19. 65pacecar
    65pacecar
    from KY, AZ
  20. Deuces
    Deuces
  21. 65pacecar
    65pacecar
    from KY, AZ
  22. 65pacecar
    65pacecar
    from KY, AZ
  23. 65pacecar
    65pacecar
    from KY, AZ
  24. 65pacecar
    65pacecar
    from KY, AZ
  25. 65pacecar
    65pacecar
    from KY, AZ
  26. 65pacecar
    65pacecar
    from KY, AZ
  27. 65pacecar
    65pacecar
    from KY, AZ
  28. Two questions on this manifold, one, can you get two the valve cover bolts with the manifold in place? two how do you get to the bolts to install the manifold. Is the manifold two pieces? Thanks.
    Deuces and bschwoeble like this.
  29. loveoftiki
    loveoftiki
    from Livonia,Mi
  30. wrenchbender
    wrenchbender
    yes you can get to the valve cover bolts as there is a bit of space it’s close for sure but if you look at the valve cover in p*** side you can see the dimple in the cover and the intake is one piece if you look closely you can see the plugs in the intake in the center so you can get to the intake bolts
