Hot Rods Automotive terms that don’t make sense....
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Nov 29, 2023.
  1. Harv
    Harv
    from Sydney
    The pointy end of a pig :D
    Cheers,
    Harv
    Ned Ludd, '28phonebooth and alanp561 like this.
  2. RmK57
    RmK57
    Rumble seat. No draft windows.
  3. 1935ply
    1935ply
    from peyton,co
    Where did 3 on the tree come from ? I learned to drive in a '62 Chevy pick up with a 3 speed column shift. Never got the tree thing.
    jimmy six likes this.
  4. twenty8
    twenty8
    That could be an Aussie one as well. Been around down here forever. "Tree" is the column..... sort of similar, right???
    Budget36 and Ned Ludd like this.
  5. BamaMav
    BamaMav
    from Berry, AL
    Could be a regional thing. Around the South, I've always heard it called either the dash or the possum box. "Look in the dash and get me a screwdriver.". As far as possum box, probably a bunch of good ole boys after a night of drinkin' shine started gathering up roadkill for a meal and figured that was as good a place as any to put their prized dead opossum.....
    Ned Ludd likes this.
  6. enjenjo
    enjenjo
    from swanton oh
    One time many years ago I was in the hinterlands of Japan. I needed some 6 volt parking light bulbs. I went to several garages looking for parking light bulbs, with no luck. Finally I took a bulb out and took it to the next shop. He looked and said " Ah Dashu Lampu" and grabbed one out of the box.
    Baumi, alanp561, ekimneirbo and 2 others like this.
  7. Don't want to add to your anxiety, but what about .... male member..
  8. So you're telling me my wife is actually a "Distributor Blonde"?
  9. twenty8
    twenty8
    How do you guys feel about "spats"? Would you run them or not....???o_O
  10. X38
    X38
    I loathe it.
    I don't like bonnet either. Sounds ...well we're not allowed to say that anymore.
    VANDENPLAS and ekimneirbo like this.
  11. twenty8
    twenty8
    Yep, spats is a weird one we could do without.....
    And about bonnet, we all know how it sounds.:oops:
  12. Thanks mate, one step further I see all Australians broken down into state (Or territory) i.e. Victorian, Queenslander, Northern Territory, etc. I also see tribal groups in the same way.
    I remember my father telling me it was known as a 'Dizzy' because the rotor spun so fast that if you turned like that you would get dizzy. Not sure if that's a commonly held reason but it worked for me.
    alanp561, ekimneirbo and Ned Ludd like this.
  13. spanners
    spanners
    I did my panelbeating apprenticeship starting 1973. I worked for my father in his business prior to that and after I finished my time. It was always known as a bonnet especially if you were ordering a new one even though on Holdens especially they had hood on the knob you pulled to release it. Probably easier to spell otherwise you'd need a larger knob. (cue the schoolboy snickers)
    alanp561 and VANDENPLAS like this.
  14. X38
    X38
    Actually, it's Michies. True.
    alanp561 likes this.
  15. Ned Ludd
    Ned Ludd
    You laugh? Our local term is "banana branches".
    VANDENPLAS likes this.
  16. DDDenny
    Mast jacket is a steering column outer cover but it sounds like something on a sailboat.
  17. Harv
    Harv
    from Sydney
    I ran spats on the sedan version of my avatar. They were possessed, worse than Christine.
    Maiden voyage on the highway, blew out a tyre and ejected the spat. Stopped, picked up the mangled spat, changed the tyre and proceeded.
    Got a panelbeater to straighten the spat and repaint. Wind blew the spat off the painting trestle, and got bugs/dirt/grit in it. Clean, sand, repaint. He was not happy.
    Took the repainted spat home and stored it in the shed waiting its turn to reinstall. A piece of rubber hose sitting above it dripped brake fluid on it and stripped the paint. That hose had been there for more than a year, and not dripped at all.
    Clearly, the spats do not want to be on that car. They are stored in the shed, in a circle of salt with cloves of garlic.
    Cheers,
    Harv
  18. DDDenny
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    True of all. Do we still have wars ? Do we still have violence ? There has been no basic change ! We humans are all complicit !
    twenty8 likes this.
  20. theHIGHLANDER
    theHIGHLANDER
    If nobody added this already it applies to specific terminology...a little. Also what we sometimes see as answers to a simple question in the hallowed halls of the HAMB (you know who you are).
    CSPIDY, 2OLD2FAST, alanp561 and 5 others like this.
  21. alanp561
    alanp561
    I'm 79. My father always referred to a column shift as three on a tree. Then, there is Ford's 4 on a tree from 1961.
    Sharpone, VANDENPLAS and ekimneirbo like this.
  22. Illustrious Hector
    Illustrious Hector
    "The British may have invented the English language, but Americans made it great!"
    -- Richard Rawlins
    Sharpone and loudbang like this.
  23. ekimneirbo
    ekimneirbo
    from Brooks Ky
    For some reason, in the back of my mind I keep thinking that in my regional area of the south, the term "dog house" was the group of components comprising the sheetmetal front end of a vehicle..........The hood and fenders along with maybe the grille and the supporting bracketry. If you went to a southern junkyard and bought a new "dog house" thats what you got. I think the rationale for that term was that in many junk yards, the traditional "junk yard dog" often slept under one of these ***emblies and was chained to it.........hence the term "dog house".
    Since there is no Webster's Dictionary of many of the hot rodding terms we used, and no one person appointed to decide exactly what something means or when it should be used..........terminology use often varies from person to person or area to area. So, my definition possibly has a little bit of logic behind it, but doesn't mean its the only explanation.:)
    Sharpone and alanp561 like this.
  24. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Coming from a poor area of town, I can remember guys taking column shifters out of cars and shortening them till they were about the size of a floor shift......then making a mounting bracket and using them as a floor shift. Nobody had money to buy much, so they often made things instead.
  25. jimmy six
    jimmy six
    No ****!
  26. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Some terms are like song lyrics; if they rhyme, they don't have to make a lot of sense. I always figured that "three on the tree" came about after "four on the floor", a term that makes more sense. Sort of like a big block Chevrolet V8 being a "rat"; since a small block Chevrolet was often referred to as a "mouse", since it was a physically small engine when it came along in 1955, its big brother must be a rat.
  27. A friend of mine did this back in the late 60s. He had used up most of his ready cash building his car. He had shoehorned a 289 Studebaker into a '60 Ford Consul. without the funds for a shifter, there was no room for the original column shifter, he cut it up and made a floor shifter that worked quite well. If I remember right, he got the idea from an old Hot Rod magazine that explained how to do it.
    ekimneirbo, Sharpone and alanp561 like this.
  28. hotrodjack33
    hotrodjack33
    I had one of those 3/4 race cams once...the other 1/4 wasn't of much use though:(.
  29. Harv
    Harv
    from Sydney
    My kids all learned to drive three-on-the-tree. With worn linkages, it's often like stirring a bowl of porridge.
    Please forgive me (and mods please delete) if it is politically incorrect to mention his work, but it reminds me of Bill Cosby's description of John Thomas' car.
    John had four on the floor, eight on the roof and nine on the doors.
    Cheers,
    Harv
    Sharpone likes this.
  30. Budget36
    Budget36
    From reading, is a “spat” a fender skirt” ?
