Projects Mild custom '51 Pontiac Chieftain
Discussion in 'The Hokey Ass Message Board' started by PhilA, Nov 4, 2019.
  1. PhilA
    PhilA
    Took it for a run. Result? Much improved; light throttle and acceleration it still hangs up a little.
    I think the chamfer needs to be made a little softer, polished. At light throttle it seems as though there's only ounces of force available.
    Put my foot down a little heavier and it shifts just fine. Happy with that overall.
    Phil
  2. bchctybob
    bchctybob
    The nuances of driving them is part of the charm of driving old cars.
    PhilA likes this.
  3. treb11
    treb11
    Most guys would long ago have given up and slapped in a 350/350. Your patience and problem-solving methodology are to be commended. I daresay emulated.
  4. Oneball
    Oneball
    Fingers crossed that’s the end of a long road with your box.
    PhilA likes this.
  5. PhilA
    PhilA
    I hope so. Never would have thought it was a valve getting stuck halfway.
    Tow Truck Tom and Oneball like this.
  6. Johnboy34
    Johnboy34
    from Seattle,Wa
    Wouldn't adjusting the throttle pressure linkage boost pressure a tad?
  7. PhilA
    PhilA
    It would, but that also defeats the object of having the main line pressure reduction in the first place. Taking the edge off that piston so it moves correctly is a better solution in my opinion because it retains the low pressure at light acceleration and thus prevents the shifts from being harsh.
    Phil
  8. patsurf
    patsurf
    well--B+M won't hire you --but the pontiac dealer sure would!!--as all have said --great thought processing!
  9. PhilA
    PhilA
    It shifts with quite the kick if you stamp on the loud pedal, not quite B&M smoke the tires into each gear harsh, but it lets you know it's changed!
  10. PhilA
    PhilA
    Rolled over 115000 miles today. Did a couple moderate distance, high speed runs and although it did hang up a couple times now, every time snapping the throttle shut causes a 1-2 shift so it's just getting stuck on the edge again but now will free up easily.
    I'll pull the valve block at some point and machine it more.
    It's made it a lot easier to drive, without having to worry about it not shifting before the engine throws a rod.
    Phil
  11. Pontmerc
    Pontmerc
    from Finland
    You got spare valve body right?
    Take that valve spool out and cut grooves all the way about 3mm space between.
    That will center the spool as oil is not force it to one side. upload_2023-12-7_11-15-26.png upload_2023-12-7_11-15-26.png
    bchctybob likes this.
  12. PhilA
    PhilA
    I do, but I'm not sure that'll work because it's not a very long piece. I do have a spare though.
    It's not the hydraulic pressure making it go to the side though, it's the spring.
    Stogy and bchctybob like this.
  13. PhilA
    PhilA
    Jumped at a rare opportunity, NOS valve block. Gives me a chance to see if machining a sleeve for the old ones is viable.
    Phil
    brEad, pvfjr, Stogy and 6 others like this.
  14. Greg Rogers
    Greg Rogers
    I'm still followin' ya Phil. Love this thread.
    brEad, Stogy, RAK and 1 other person like this.
  15. PhilA
    PhilA
    I'm surprised; all I've been doing is driving it and occasionally greasing and changing the oil.
  16. Greg Rogers
    Greg Rogers
    I like that you are staying with the trans shifting problems, so I keep looking, Love it!
    Stogy, PhilA and TrailerTrashToo like this.
  17. 4 pedals
    4 pedals
    from Nor Cal
    Your determination to make things right is admirable and rare. Most would have said it's good enough long ago.
    Devin
    brEad, bchctybob, Stogy and 2 others like this.
  18. tubman
    tubman
    I agree with everything being said. Knowledge lost for decades is being regained here. Because of the very nature of the internet, it will be retained this time.
    bchctybob, Stogy and PhilA like this.
  19. y'sguy
    y'sguy
    from Tulsa, OK
    Yep! and this is just how it should be. Driving it and using it is the best thing for it. Enjoy it.
  20. PhilA
    PhilA
    Well, I know what the problem is, was going to try some engineering but the opportunity for one that doesn't need a repair came by.
    So, that should make it more fun to drive.
    Certainly easier for someone else to drive- you need to know the quirks right now and how to fix 'em as you drive.
    Phil
  21. Just think Phil..... You're gaining knowledge for a retirement gig as an early Hydro rebuild expert!
  22. PhilA
    PhilA
    By then we'll all be flying around in those Jetsons looking cars, BRRRRIIIWWWWWWW
    bchctybob, Stogy and '28phonebooth like this.
  23. PhilA
    PhilA
    Tonight, the car was called into action, to be taxi. Fully loaded six-up, we drove into the sunset.
    Handled that very well really!
    brEad, bchctybob, Stogy and 5 others like this.
  24. PhilA
    PhilA
    Took the clock out because it had been losing time. It's been a few years since it was serviced last.
    Stuck it on my bench and pulled it apart. Oiled the pinions and set about adjusting the hairspring balance.
    Yup, I set my clock up with an oscilloscope. Nice even pulses there so that's good.
    Ticking over smoothly again.
    All back together, tested and ready to go back into the car.
    Phil
    brEad, loudbang, bchctybob and 7 others like this.
  25. PhilA
    PhilA
    Been sitting listening to it back in the car.
    Doesn't seem to be catching the escapement any more (audible click) so that should be back keeping time properly again now.
    Phil
  26. Great job! As I remember it "back in da day" clocks were the first component/accessory to go ***s up in our cars. It was rare to find a five-year-old GM with a working timepiece.
    PhilA, bchctybob and Stogy like this.
  27. BJR
    BJR
    It's about time you fixed your clock! :D
    PhilA likes this.
  28. PhilA
    PhilA
    It gained about two minutes overnight so that's a good sign.
    Need to go bring a small screwdriver out and dial it a touch towards S.
    Phil
  29. Oneball
    Oneball
    I can’t remember, did you have to repair your clock in the first place or did it just need cleaning?
  30. PhilA
    PhilA
    It needed a thorough clean, adjustment and conversion to 12V.
    Phil
    bchctybob and Oneball like this.
