Projects 1949 Mercury barnfind resurrection
Discussion in 'Traditional Customs' started by MercMan64, Dec 5, 2023.
  1. MercMan64
    MercMan64
    from Taylor mi
    Hey guys good morning, I’m fairly new here, first Time poster. I recently picked up a 49 Merc 4 door that has been sitting since 1994. The goal is to get this car road worthy in the next 3 months and get it to its first show. I’m slowly trying to get it running. I’ll be adding to this thread periodically so you guys can see the updates. And asking questions, I’m excited to hear some insight IMG_3162.jpeg IMG_3162.jpeg IMG_3162.jpeg IMG_3162.jpeg IMG_3167.jpeg IMG_3161.jpeg
  2. pprather
    pprather
    Welcome as a new poster and on your new Merc custom.
    49ratfink and hudson48 like this.
  3. Looks like a good one to work with. Concentrate on getting it running and driving safely. Maybe we'll see it at some Michigan shows.
  4. Oneball
    Oneball
    That’s in a lot better nick than I thought when I read barn find.
    The Chevy Pope and chryslerfan55 like this.
  5. J54monterey
    J54monterey
    Love those old Mercs. Nice find
  6. MercMan64
    MercMan64
    from Taylor mi
    I’ve sent my paperwork for the 2024 Detroit autorama. The engine was locked up when I brought it home, I did manage to free it up with the exception of one sticky intake valve on the p***enger side of the block. A lot of what I’ve read in the threads here states heat from the engine running may free it up, so I plan to try that. The clutch is seized to the flywheel and the brakes are rock solid. I’ve got most the components to plumb the brakes and fuel lines. And also have a lead on a functional Rochester 2 jet carburetor. The original tea pot seems to be pretty crunchy. The car is fairly solid being a Michigan car, it desperately needs a trunk pan. The family of rac****s that were living inside the car were dedicating in the corners of the trunk and wasted it all away to nothing.
  7. MercMan64
    MercMan64
    from Taylor mi
    I had a moment to swap in a new battery and cables tonight, with the head off and no plugs the motor spun over quick and free. Now that the head is back on and the plugs are in I can’t seem to get the car to turn over. It’s got me scratching my head
  8. Squablow
    Squablow
    Looks like it'll clean up pretty good, a worthy project.
  9. If you replace the pressure plate and don't need the original for a core I may be interested in the original pressure plate
  10. Will it turn over heads on with no plugs?
  11. MercMan64
    MercMan64
    from Taylor mi
    Made some progress last night, finally got the motor to rotate with it all back together. Replaced the solenoid, points, condenser, rotor and coil. However I’m still on the hunt for spark. The wiring inside the distributor seems highly suspect as well as the wiring to the coil. Any thoughts? Also I found out my cluster lights work
    WC145, Okie Pete, Toms Dogs and 4 others like this.
  12. miguel.st
    miguel.st
    from germany
    Are you still trying to start the engine with the two coils and the ****py cables from the tuesday picture?
    I would recommend to test at least which of both coils is worse and take this out of the way. New cables only for dizzy and coil are easy and for sure worth the work.
  13. MercMan64
    MercMan64
    from Taylor mi
    The distributor ended up having some issues, I pulled it Sunday night and sent it to my friends at Brother’s Custom Automotive in Troy MI to have Bill go through it. I did snag another distributor from my uncle Thursday as well. However last night with this other installed I have now lost voltage to the new coil. I’m thinking it maybe related to the ignition switch but I haven’t had a chance to pinpoint it yet. I may take a brake from from engine work to start running new brake lines and installing the new master cylinder and wheel cylinders. And probably plum new fuel line while I’m under the car.
  14. MercMan64
    MercMan64
    from Taylor mi
    I got to spend a little bit of time with the car today. I’m waiting on the last of my parts to arrive but I couldn’t wait any longer. Brakes are ready to be plumbed, new tires installed, drivers door repaired and lowered 4” in the rear today. Plan is to level it out and get the front down a bit. Unfortunately the car still isn’t running but it is close. I dropped the distributor off with bill at Brother’s Custom Automotive to have it rebuilt, so it’s ready to install. I should be seeing brake lines and fuel lines in the next couple of days, plus I have a new gas tank to install as well. It won’t be much longer here and I can focus on the interior and exhaust! IMG_4146.jpeg
  15. Welcome to the HAMB. Love the project. Good luck making it to the Detroit Autorama.
  16. scotts52
    scotts52
    Love it! Great looking car. One task at a time. You'll get there.
  17. hotrodjack33
    hotrodjack33
    Ya know...someone has GOTTA ask about those "well endowed" mannequins;).
    chryslerfan55 and 49ratfink like this.
  18. BJR
    BJR
    Those are womakins. :p
    WC145, 49ratfink and hotrodjack33 like this.
  19. MercMan64
    MercMan64
    from Taylor mi
    Managed to drag the car over to my uncles shop this weekend and made some major progress. Just waiting on a fuel pump to be delivered. And to touch on the subject of the mannequins, I picked them to flake and throw down some candy on for this year’s panel jam. But the car has kept me a bit occupied so I have had a chance to get to them IMG_4267.jpeg
  20. Squablow
    Squablow
    Already looking better than when you found it for sure.
  21. MercMan64
    MercMan64
    from Taylor mi
    Once again made some good progress this weekend, finally heard the car run under its own power after 30 years of sitting in a pole barn. We managed to patch the floors and get the lights mostly functional as well. First start up was a bit of a smoke show as it burned off all of the leftover transmission fluid and acetone that we used to unlock the motor. Second start up with coolant and and an oil changed proved to be much better but still a little Smokey but mostly just residue.
    https://youtu.be/irK3bMvD3Cw?si=NDJXf8WMA7NISrby IMG_4275.jpeg
  22. topher5150
    topher5150
    dropping the ***, and putting some white walls on that ol girl makes a world of difference.
    Surfcityrocker likes this.
  23. MercMan64
    MercMan64
    from Taylor mi
    Slowly making progress, I drove the car for the first time Saturday night. Rode great and drove straight. It still has a hefty miss. I started working on the door cards Sunday and finally finished up tonight. Should be able to get them in with this odd 60 degree day we’re going to have here in Michigan tomorrow.
  24. MercMan64
    MercMan64
    from Taylor mi
    Spent just a little bit of time with the car this past week, but got side tracked painting a dash for another autorama car, we’ve got 13 days til move in. Interior is moving along nicely. Door cards are in and I’m getting ready to start the package tray. Club plaque is mounted and I still need to cover the seats. Found the heater core has sprung a leak and the generator isn’t charging. IMG_4413.jpeg IMG_4411.jpeg IMG_4427.jpeg IMG_4428.jpeg IMG_4471.jpeg IMG_4470.jpeg IMG_4464.jpeg
  25. guthriesmith
    guthriesmith
    Hmm...seeing the plaque in your back window leads me to believe that I will likely meet you in a couple weeks... My brother is also in the Suspects.
    drdave likes this.
  26. WC145
    WC145
    from Maine
    Wow, quite a transformation already, she looks great!
    And you need to post pics of the womakins once you get them painted!
  27. Jacksmith
    Jacksmith
    from Aridzona
  28. Hillbilly Werewolf
    Hillbilly Werewolf
    That dash looks fantastic!
    Have you tried copious amounts of marvel myster oil in the gas and oil? Sometimes that can help that last valve free up.
    Jacksmith, chryslerfan55 and SS327 like this.
  29. MercMan64
    MercMan64
    from Taylor mi
    guthriesmith I will see you there!
  30. MercMan64
    MercMan64
    from Taylor mi
    Spent some more time with the car this week. Covered the seats and finished putting fur into the package tray. I’m currently in between jobs so I spend all day Tuesday polishing the car. It’s really come around. I still need to spend some time polishing the chrome but so far I’m happy with the progress. We had a 60 degree day here in Detroit so I ran the car down to the car was and rinsed it off. We did block off the heater core as well. Tomorrow I’m going to take a look at the generator and possibly rig up some exhaust to keep the fumes down. I did try to paint the skirts last weekend however I had an odd chemical reaction which caused them to shrink and start to lift. I’ll probably figure that out also IMG_4500.jpeg IMG_4506.jpeg IMG_4507.jpeg IMG_4515.jpeg IMG_4539.jpeg IMG_4543.jpeg IMG_4542.jpeg
