Technical Post pics of homemade bone ball mounts
Discussion in 'Traditional Hot Rods' started by 28fordroadster, Nov 25, 2023.
  1. 28fordroadster
    28fordroadster
    Please post pictures of crossmembers and wishbone mounts for AV8 or similar. What did you use for clamps to hold the ball in? I will be using a 35 wishbone with a model A ball end welded to it and an F1 crossmember. Any pictures of that set up will be appreciated!
    Thanks
  2. Model A Gomez
    Model A Gomez
    Model A vendors sell a couple of replacement mounts, both of these are available from Snyders Antique Auto for about $25
    Packrat, Just Gary and Algoma56 like this.
  3. 28fordroadster
    28fordroadster
    Bump
    I hope that you guys have some pictures and ideas
    Thanks
  4. goldmountain
    goldmountain
    Maybe you could use some trailer hitch ball parts.
  5. 40ragtopdown
    40ragtopdown
    Not sure if this is what you're looking for. This was posted on a model a site. Hope this helps. FB_IMG_1681051825660.jpg FB_IMG_1681051793412.jpg FB_IMG_1681051837844.jpg FB_IMG_1681051873549.jpg FB_IMG_1681051804557.jpg
  6. 28fordroadster
    28fordroadster
  7. lewk
    lewk
    from Mt
    ‘35 ford with factory front wishbone and a 9” with ‘35 radius rods using a Johnny joint in the rear. Frame modified for a T10 and open driveline. IMG_4516.jpeg
  8. ydopen
    ydopen
    This is a 35 wishbone and 32 k member. Wishbone was a little short so I used 2 plates as sandwich to match up. Used a spring loaded Model A socket from one of the vendors IMG_0912.jpeg
    John
    40ragtopdown likes this.
  9. Nailhead Jason
    Nailhead Jason
    40ragtopdown and lewk like this.
