Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. fastcar1953
    fastcar1953
    So the noise is gone?
    porkshop likes this.
  2. ClayMart
    ClayMart
    I've never noticed those anti-rotation bumps before, but maybe I just wasn't paying attention. Best I can figure is they'd be used on vehicles with a self-adjusting clutch. With the self-adjusting system when the clutch is engaged there is no air gap between the bearing face and the release fingers on the pressure plate. The bearing always turns at engine speed even when your foot is off the clutch pedal. Seems like they ought to work just fine with a manually adjusted clutch with an air gap as well.
    porkshop and chryslerfan55 like this.
  3. bobss396
    bobss396
    I am this many years old before I saw one with the bump. What is the brand?
    porkshop and Moriarity like this.
  4. bobss396
    bobss396
    I have always thought it was okay for it to spin if it wanted to, or not spin if it didn't want to. On my car, everything was new and mine was noisy above 3000 RPMs for a short while, then the parts got to like each other and quieted down. That's my 2¢... :cool:
  5. Oneball
    Oneball
    I’ve seen them without the bump but when it comes to Corvettes with a Muncie/T10 I’ve only seen them with the bump, but then I’m only a kiddywink ;)
    porkshop and bobss396 like this.
  6. bobss396
    bobss396
    My clutch set is a Zoom, I never looked to see who made the TOB. But it had no rib... obviously an option for her pleasure... :D:D:D
    porkshop, BJR and Oneball like this.
  7. squirrel
    No noise yet, I've not driven it very much though. But the noise was rare before I changed it. Very strange.
  8. BJR
    BJR
    I believe the interest is that a bunch of us have been doing this stuff for over 50 years, and the bumps on a TOB is something we have never seen before. Just my .02 worth. Always something new to learn.
    porkshop, ClayMart and Moriarity like this.
  9. Joliet Jake
    Joliet Jake
    from Jax, FL
    I haven't installed anyway near the number of bearings that some of you have. But I do remember some had a bump and some had this pin. This is a McLeod bearing
    Stock Racer, porkshop and Beanscoot like this.
  10. MCjim
    MCjim
    from soCal
    Interesting, I have a McLeod NOS in my spare parts, probably at least 15 years old. with the "bump"...
    Part#16010
    Is this really important?
    SS327 and porkshop like this.
  11. BJR
    BJR
    I wonder if we should bump this thread? :p Guess I just did!:eek:
  12. BamaMav
    BamaMav
    from Berry, AL
    I’ve had them with flats milled in the shaft that fit between the forks and I’ve had the ones with clips that held them to the fork, but never seen one with bumps like that.
  13. ClayMart
    ClayMart
    If you're going to say things like "I am this many years old" you have to post a picture of yourself holding up the appropriate number of fingers. :p And it better be more than just one finger! :eek:
    porkshop, scotty t, bobss396 and 2 others like this.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Talk about mid life crisis.
  15. squirrel
    I finally got around to fixing that pesky tail light. They problem is there's a br*** tube which contacts the bulb, and is pressed into a steel sleeve, which is crimped into the pot metal housing, which is 62 years old. An added ground wire takes care of the decades of corrosion that causes faulty ground connection.
  16. BJR
    BJR
    Had to do that on many cars, where the socket lost ground to the pot metal housing.
    chryslerfan55 and porkshop like this.
  17. ClayMart
    ClayMart
    I forgot about how almost every electrical item on a Corvette had to have a separate ground wire. Did your car originally have a separate ground lead from each lamp to the frame, or was there a cross-car harness that grounded all the lamps to a single point on the ch***is somewhere? :confused:
  18. squirrel
    The rear light harness has a ground wire for each tail light housing. Each has a ring terminal fits on the stud, just like my new wire.
  19. 57 Fargo
    57 Fargo
    You’re going to lose points at the corvette shows with that modification. :)
    WC145, Happydaze, porkshop and 10 others like this.
  20. squirrel
  21. squirrel
    Getting ready to hit the road for the Power Tour West. See y'all in LA
  22. BJR
    BJR
    Off on another adventure, please take us along again.:)
  23. milwscruffy
    milwscruffy
    Slave cylinder less leaky now ?
  24. squirrel
    That's a whole different car!
  25. noboD
    noboD
    So who's riding shotgun?
  26. squirrel
    My wife. 40th anniversary Sunday, what a swell guy I am taking her on a trip in an old car for the special occasion!
    (here she is trying to brush her hair after all that wind)
    David Gersic, Thor1, Sancho and 33 others like this.
  27. 51504bat
    51504bat
    Cabazon dinosaur stop before hitting LA traffic?
  28. Fordors
    Fordors
    Congratulations on the big 4-0, here’s to many more.
  29. Jim, congratulations to you and Mrs. Jim on 40!
  30. squirrel
    thanks!
    traffic wasn't bad at all, it's all about timing.
    Also, the car is running a big rough at idle/off idle, so I'll look at some stuff on it tomorrow. I brought my helmet so I can go drag racing, too.
    Thor1, Sancho, brEad and 20 others like this.
