Technical Lowering a 40 Chevy Business Coupe
Discussion in 'The Hokey Ass Message Board' started by NXSLT1, Dec 9, 2023.
  1. NXSLT1
    NXSLT1
    Been trying to figure out the best way to lower a 40 Chevy business coupe with original IFS. I can cut the coil springs, lower the spring plate on the bottom a arm with spacers or make a lowered spring pocket for it, or my actual question is this. I have read on here from an older thread about using 53-54 chevy car spindles and spindle supports (uprights) and that will lower it 2". Is this true? Has anybody done it this way and it actually lowered it 2"? Just looking at pics from 49-54 car spindles there is a difference in them and a 40 as far as height but it don't look like 2" worth.
  2. 41hemi
    41hemi
    49-54 uprights mount to a control arm at the top and 39-48 uprights mount to the upper shock. I don't think they will interchange. I used 54 Chevy spindles on my original 41 Chevy front end and lowered the car 1/2". I also took 1 coil out of each spring and lowered it another 2".
  3. I plan to use dropped spindles on my 40 Buicks.
  4. jimmy six
    jimmy six
    Lowering by adding spacers to the A frame will keep the original ride and used on some Fords into the mid 50’s. To have one look good you need about 4” total since those cars are pretty high from the factory.
    If your brave since the 40’s have a nice stock boxed frame I would look to Circle Track suppliers for both adjustable upper and lower a-frames and their mounts. This will necessitate a different steering box but every thing would be modern and adjustable.
    I believe your complete suspension is either riveted or bolted in.
    If your planning on removing it weld a 2-3” tube across the front to hold what you have to start. This one had the IFS when new but removed in 1962 for a straight axle. You can see the front cross tube. IMG_2719.jpeg IMG_2868.jpeg
    Kreepea_1 likes this.
  5. NXSLT1
    NXSLT1
    40s have a arms also. They mount to the shock on one end but mount exactly the same as the others on the spindle support. They will fit, I'm looking for someone who has already done what I mentioned and can say how much it dropped it.
  6. NXSLT1
    NXSLT1
    4" drop is what I'm looking for but I hate to do it all with just spacers. I just got done putting a rack and pinion on it but I'm not interested right now in a full custom suspension. It's possible I could do spacers and make a pocket for the spring. I'll have to study on it since no one seems to know how much the spindle supports and spindles will drop it.
  7. 24riverview
    24riverview
  8. NXSLT1
    NXSLT1
