Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. TA DAD
    TA DAD
    from NC
    I have a new plan, the tank idea is to heavy, to Rat Rod looking. There is not a lot of solid info that I have found on air cleaner design. I watched one video where they were flow testing a old school velocity stack and there was enough reversion that the stack was floating up off the carb, that was interesting . So back to the drawing board. This is where I am at now. IMG_1107.JPG
    mad mikey and j hansen like this.
  2. woodbox
    woodbox
    Sat on the beach with my girl!
    guthriesmith, Cooon, 40two and 7 others like this.
  3. MCjim
    MCjim
    from soCal
    Broke in the reanimated motor:
    mad mikey, 67drake, charleyw and 2 others like this.
  4. PhilA
    PhilA
    Got the hot electric glue stick out and put some pipe together.
    Then I made another one. Now there are two.
    Phil
  5. 26 T Ford RPU
    26 T Ford RPU
    That looks safe!:confused: JW
  6. seb fontana
    seb fontana
    from ct
    What did I do today FOR my car. Cleaned the bay with the lift and everything in it because of the sandblaster explosion [dumb story] so there was **** [sand, same difference] everywhere. Maybe [hopefully] tomorrow I will get the car moved if it will start, been parked since July as wasn't running great. Great that the grand kid helped as HIS car is getting stored for the winter in one bay.
  7. lake_harley
    lake_harley
    Sandblaster explosion?! Please tell that story. Had to be scary.
    I had a 80 Gal. Compressor tank blow up years ago. Ripped the whole side of the tank open and blew a hole through the metal siding wall, bending a purlin. I was standing 4' from it about a minute before it blew. What a noise....people heard it about 1/2 Mi. away.
    Lynn
    seb fontana likes this.
  8. PhilA
    PhilA
    There's a couple stands hiding out underneath.
    26 T Ford RPU likes this.
  9. Pontmerc
    Pontmerc
    from Finland
    Decided to drive it inside.battery was too low, so younger corporate brother had to spare some electricity. IMG_20231210_131002.jpg
    mad mikey, Cooon, X-cpe and 1 other person like this.
  10. TA DAD
    TA DAD
    from NC
    I am going to build a flat base air cleaner ***embly, I want some type of short velocity stack/bowl shaped entry into the carb. throat. I came across this stainless bowl at the antique store and it will become the base for the sheet metal plenum for the ram air system. I also hammer formed/rolled some metal shelving for the air inlets that will go in the front fen IMG_1108.JPG IMG_1109.JPG IMG_1113.JPG ders.
  11. TA DAD
    TA DAD
    from NC
    I got the bowl opened up to fit the carb, I guess I need to remove the serving handles Lol. IMG_1115.JPG
  12. TA DAD
    TA DAD
    from NC
  13. seb fontana
    seb fontana
    from ct
    A silent explosion of sand outside of the cabinet due to my thinking if I shake the vacuum it would clean/drop some dust off the filter, sure and knocked the filter off so it blew out everthing, didn't know why it was so hard to see what I was blasting till my teeth got gritty. Yeah I've done worse..
    I did manage to get the car moved; it started with out too much cranking. It idled a little rough till it warmed up and then I heard the blown out exhaust pipe gasket. Took it for a ride around the block and it ran fine, except for the blown gasket noise. I must have been sick that night.
    mad mikey and loudbang like this.
  14. TA DAD
    TA DAD
    from NC
    Chucky, LAROKE, loudbang and 6 others like this.
  15. 67drake
    67drake
    from Muscoda WI
    Valve covers on my 260 Mercury are supposed to be orange. Closest I could find was an Allis Chalmers Orange. Sons are kidding me it’s just Chevy orange in a different can, IMG_0171.jpeg IMG_0178.jpeg could be, but….
    Anyway, valve covers got thrown in the parts cleaner, then sandblaster, then tried to keep them warm running them outside for coats of primer and orange. It’s a pain spray painting in the winter in Wisconsin.
  16. My past experience living in Wisconsin is that it's a pain to do ANYTHING that doesn't involve a fireplace and recliner during the winter!
    And "Yes Viginia" that IS Chevrolet orange!! Bazinga!
    mad mikey, 67drake and TA DAD like this.
  17. birdman1
    birdman1
    Made a bracket to mount a slave cylinder on my 1960 Mercury picture at 10
  18. spanners
    spanners
    I've found a hooded barbeque works well for small parts. Put it on a low heat, place the parts in it for a while then take them out, spray and put them back in to bake the paint. Switch it off but leave the lid shut for a while.
    mad mikey, Cooon and 26 T Ford RPU like this.
  19. mgtstumpy
    mgtstumpy
    Removed the OEM gas tank (11 US gallons, 9 Imp gallons) in my 35 Chevy, overdue to upgrade after nearly 20yrs to a larger capacity Tanks Inc tank (15 US gallon, 12.5 Imp gallons). I should have modified tank when I originally built the car and a PITA on long drives having to stop to fill up. That 2" additional depth should make it better. Contemplating on letting it go to focus on the 46 Olds that's been languishing for far too long! 410602648_7235144416542685_3732018065710945466_n.jpg 410527960_1728219500995188_5768411767807655174_n.jpg
  20. Chucky
    Chucky
    The firewall had been torched out years ago, but today I took it a step further and cleaned it up at the same time. The plan is to remove as much factory interior sheet metal as possible.
  21. mgtstumpy
    mgtstumpy
    Parked everything up the other day pending Christmas [Family] travels prior to my extended 3mth US road trip starting 1/1/24. I'll definitely be looking for car events and car museum fixes during my odyssey. 409637961_1679305312593345_3760840752546264557_n.jpg
  22. TA DAD
    TA DAD
    from NC
    I picked up some nice 4in. hose for my ram air build, BUT I will be starting over on the air box. I was just not happy with how the other one was going. IMG_1140.JPG IMG_1139.JPG
  23. lake_harley
    lake_harley
    I spent several hours whittling this adapter out of a 3/4" inch piece of aluminum plate on my milling machine to replace the original carburetor on a 241 hemi I have that I might use in a future project.
    It will enable me to replace this tiny stock two barrel carburetor.....
    With this Holley two barrel which is much larger....
    It should enable the 241 to breathe a bit easier. I still need to blend the ports in the adapter and the manifold where they meet.
    Lynn
  24. TA DAD
    TA DAD
    from NC
    IMG_1142.JPG I got a little therapy time in today and rolled a couple inlets for the ram air ! The primered sheet metal on this truck is what Thomas bus used to build buses from. I am now all out of it , so I am waiting on some friends around here to come up with some Lol ! IMG_1143.JPG
  25. lake_harley
    lake_harley
    Just to follow up on my carburetor adapter from two posts back I made a decision today and bought a 153 ChevyII/Mercruiser engine to use in my Model A Tudor. It will probably be way less expensive to rebuild, weighs a lot less than the baby hemi, it will fit with room to spare without messing with the firewall and will still move the Model A down the road at highway speeds. I have a 151 Iron Duke in my A Coupe and I'm happy enough with it. I guess I'm just a ****er for small engines since I also have a 215 V8 in my T roadster.
    Lynn
  26. Chucky
    Chucky
    Went back to the woodpile and harvested my mock-up block. It’s been home to a few mice over the past 7 years.
  27. TA DAD
    TA DAD
    from NC
    So a friend came up with a nice sheet of the metal I needed. So I am now back at the beginning with the air cleaner. IMG_1157.JPG IMG_1154.JPG
  28. TA DAD
    TA DAD
    from NC
    Now to figure out what I am doing ! Lol . But I do have a lot of metal to learn on. Can I shrink and stretch that piece of angle to fit the outside contour of the snorkel and the piece it goes through. Or will I have to make the fit better so I can weld it up without the angle piece. No Tig available and I would have to Mig it . For a old blind guy that keeps getting harder to do.
  29. guthriesmith
    guthriesmith
    Men’s meeting at church so what better to drive.
  30. mad mikey
    mad mikey
    Adapting a old Enderle injection hat to my 2x4 set up on the blower. Don't flame me to hard, I always wanted one and got it for Christmas. Been working on this since the holiday fabing up a adapter and a air filter that will be hidden inside the hat. Pictures to come later.
    INVISIBLEKID, Chucky, swade41 and 6 others like this.
