Projects 1962 Biscayne Jr Stocker for the Street Build
Discussion in 'Traditional Hot Rods' started by Stock Racer, Mar 15, 2022.
  1. Stock Racer
    Stock Racer
    Check. I have also added braces from the frame to the crossmember as can be seen in post 157 of this thread.
    The original upper control arms are temporary just to get everything set up. I'm eventually going to build some adjustable uppers with heim joints. Trying to decide if I'm going to add the second upper arm on the original rear housing or wait for the 12 bolt.
    swade41, lumpy 63 and SS327 like this.
  2. saltflats
    saltflats
    from Missouri
    I was reading a recent post on installing a chevelle or some other 12 bolt rear and some fancy looking upper to make it a bolt in deal. I'm not sure how it would work with the upper pivot points being at different angle. They say the lover arms will bolt up with no mods. o_O
    Stock Racer likes this.
  3. Stock Racer
    Stock Racer
    That would certainly make things easier, I'll have to look into it. My housing is from a 65 Impala.
  4. flynbrian48
    flynbrian48
    Like this? :p You guys sharing photos of your Impalas are making me miss mine. I think we're gonna bring it down south with us next winter. Maybe even with matching paint...
    4C8B402E-D422-4EAB-9A1C-B1D7B5D5A42B.jpeg 470C4C7F-4C08-44DF-A935-4359B19F2CA0.jpeg
    tr_rodder, Deuces, brEad and 3 others like this.
  5. saltflats
    saltflats
    from Missouri
  6. Stock Racer
    Stock Racer
    Getting cold out so property maintenance has come to a halt and I'm back in the shop.
    Still in cleaning and painting mode. Can't wait until this **** work is over so I can get to the cool stuff. I'm not a fan of Red Oxide but it halfway match's what's already there and will be covered up eventually anyway. Wanted semi-gloss, found this at Home Depot ($22.95 qt). Used a 4" roller and it smoothed out nice.
  7. dart4forte
    dart4forte
    from Mesa, AZ
    327 small journal?
  8. Stock Racer
    Stock Racer
    The first engine will be a large journal 327. Only reason being I had most of the parts laying around. The engine will be NHRA legal for Stock Eliminator, toned down a bit for the street. I will do***ent the build here.
    brEad, loudbang, SS327 and 3 others like this.
  9. Stock Racer
    Stock Racer
    Well, the holidays are over so I'm getting more shop time. Been getting a few things cleaned up and painted. Clean, paint, repeat, lol.
    Shipped the big stuff off to the blaster.
    IMG_5646.jpg IMG_5657.jpg IMG_5683.jpg IMG_5656.jpg IMG_5684.jpg IMG_5714.jpg IMG_5693.jpg
    swade41, Junior Stock, TA DAD and 9 others like this.
  10. SS327
    SS327
    Bout time you started showing it some love!:D
  11. Stock Racer
    Stock Racer
    Getting a few things done. I've never found an easy way to remove undercoating (until now). An aggressive cup brush on an angle grinder. I was sure it would clog the brush but it didn't. Worked great.
    Used the persuader to straighten a bent front support.
    Got the bigger front end parts back from the blaster.
    Had some extra holes in one of the wheel wells. I **** at welding sheet metal but what the heck, the holes are filled. As a buddy of mine says "bondo...it's beautiful stuff"
    loudbang, SS327, saltflats and 2 others like this.
  12. 427 sleeper
    427 sleeper
    A Propane torch and a s****er makes short work of undercoating... Stink's like Hell, but it work's!
  13. Stock Racer
    Stock Racer
    Tried that. Made a mess on the floor and on me and still had to use mineral spirits to clean what was left. The cup brush method provided clean metal and just swept up the powder left on the ground. Much better
    loudbang, SS327 and 427 sleeper like this.
  14. Grandadeo
    Grandadeo
    Good thinking on the face shield. Back in '65 of so I spent a whole weekend under the G/Stock '58 Delray big brother and I where putting together. Wire wheeling, s****ing, grinding, etc. I think there was even some undercoat removal involved. I finally knocked off and looked in a mirror. It was scary. Love your project.
    Lee
    Stock Racer and loudbang like this.
  15. saltflats
    saltflats
    from Missouri
    I used one of those crud buster wheels on the Salt Shaker and it worked real well but it did consume itself.
  16. John 79
    John 79
    from Sweden
    Cool project, 2-door post rule!
  17. Stock Racer
    Stock Racer
    Thanks guys!
    Poverty cap and loudbang like this.
  18. 29Sleeper
    29Sleeper
    from SoCal
    When it's old and dried out the wire wheel will work better than melting it.
  19. 427 sleeper
    427 sleeper
    The torch and s****er worked better for me. The wire wheel just got it hot and smeared it around. Six of one or a half a dozen of another, I guess... :rolleyes:
    loudbang and SS327 like this.
  20. Stock Racer
    Stock Racer
    Made a couple of purchases. Found an Oklahoma hood locally that's much better than the one I had and picked up a proper pair of Jr Stocker street tires:).
    swade41, enloe, guthriesmith and 7 others like this.
  21. Stock Racer
    Stock Racer
    Cleaned up a few small items and started painting some of the bigger parts. IMG_5721.jpg IMG_5722.jpg IMG_5746.jpg IMG_5766.jpg IMG_5715.jpg
  22. Stock Racer
    Stock Racer
    Started on the floor repair. Shot some rust encapsulator in the floor braces and weld through primer on the joints. Fitted up the patch panel and got it tacked in.
    I come from the mechanical side of things, this is uncharted territory for me. Just trying to learn something here and I figure the carpet will cover it:D. For the record, I really didn't care for how that primer welded.
  23. Stock Racer
    Stock Racer
    I haven't posted in a couple weeks because the car has been sitting in a friends body shop. This car had been hit in the front. The right frame horn was kinked outward and the bumper support was bent. I thought about heating it up and using a come along and sledge to work it back into place. I'm thankful to have that friend as he has a frame rack and could do the job right. Here's a before and after.
    swade41, Chucky, enloe and 10 others like this.
  24. saltflats
    saltflats
    from Missouri
    Looks like you have made some good progress.
  25. Stock Racer
    Stock Racer
    Slow, but any progress is good progress I guess.
    It's actually starting to look like something. The bummer is I have about one more week to work on it and then it's all out on the off topic race car to get ready for racing season.
    lewk, HOTRODPOWELL, swade41 and 14 others like this.
  26. Stock Racer
    Stock Racer
    Work continues on the floor. Added more tacks and plug welds to mimic the factory spot welds. It's not a pro job but I'm learning a lot and so far I'm happy with the results. Sheet metal seems to like .023 wire much better than .035 and a 3/16 hole works well for the plug welds. IMG_5836 (1).jpg IMG_5838 (1).jpg
    20 years ago I built a Turbo 400 for a guy and my pay was this Mig Welder. It's gotten more use in the last couple weeks than all the time I've owned it. IMG_5851.jpg
  27. Stock Racer
    Stock Racer
    I'm not finished welding the first patch but my A.D.D. kicked in so I decided to start on the other side of the floor. Got the old piece out and the patch roughed in. The shelf's on the side and rear of the patch panel give some much needed leeway for fitting the **** joints.
    swade41, Grandadeo, SS327 and 6 others like this.
  28. BSL409
    BSL409
    Looking Great!
    Stock Racer and Deuces like this.
  29. Stock Racer
    Stock Racer
    Thanks, that means a lot coming from you. Your builds are outstanding.
    If any of you X-frame fans have not seen his builds, you owe it to yourself to look them up.
  30. Stock Racer
    Stock Racer
    After a summer of O.T. Drag Racing a**** other things, I finally spent some time on the 62 this week. When I started this project my intention was to do a mechanical and just get it up and running. Inspired by Jeff Norwell's 57 Ford #2, I decided clean things up a bit. The paint I used was old reliable semi-gloss Rustoleum.
    The cleaning is the worst part of the project but I'm thankfully close to having it done.
    I'm happy with the outcome and glad I decided to do it. Also started hanging some brake lines and other trinkets.
    I'm convinced this thing is trying to kill me. It has an on-off lock ****on. Told myself I was done buying tools but I'm in the market for a variable speed with a trigger.
    lewk, tr_rodder, HOTRODPOWELL and 8 others like this.
