Projects 1950 Plymouth flat head 6 freeze plug
Discussion in 'The Hokey Ass Message Board' started by Surge, Dec 10, 2023.
  1. Surge
    Surge
    from Chicago
    Looking for guidance on installing the drivers-side, top of motor, rear freeze plug. I have new ones but never did this before. Any help would be appreciated.
    Thanks!
  2. KenC
    KenC
    First be sure the opening is clean, free of rust where the core plug sits. I use a sealer, Permatex #2 works, just a little in the hole. Insert the plug, convex side out. Seat is firmly and square in the hole. Now comes the hard part because there is often something in the way of a good hammer swing, hit the plug in the middle firmly to cause the center of the convex to invert to concave. Not the whole plug 1/2 or so.
    I use a ball peen hammer when it fits the space. Otherwise, improvise. A large punch with the end ground to an arc can help get around stuff.
    Hillbilly Werewolf likes this.
  3. Surge
    Surge
    from Chicago
    Thanks KenC!
    firstinsteele likes this.
  4. goldmountain
    goldmountain
    After you have knocked the old plug into the block, a brake s**** works good to pry it out. Tap the new one in and you are done.
    41 GMC K-18 likes this.
  5. BJR
    BJR
    I drill or punch a hole on the old one, then pry it out with a screwdriver in the drilled hole.
    57Fury440 and 41 GMC K-18 like this.
  6. Surge
    Surge
    from Chicago
    Thx goldmountain and BJR. I had the motor rebuilt about 4-5 years ago and for whatever reason, [they] didn't reinstall this particular freeze plug. So, no need to remove old, just install new one.
  7. goldmountain
    goldmountain
    Here in the land where it is always winter but never Christmas, we would fill that hole with a block heater.
    firstinsteele and vtx1800 like this.
  8. ClayMart
    ClayMart
    Do these engines use a deeper "cup plug" or the shallower style "welch plug"? The R&R could be a little different. Is the engine in or out of the vehicle?
  9. Surge
    Surge
    from Chicago
    ClayMart, I purchased a set of replacement freeze plugs from Andy Bernbaum. I only needed the one however, they came as a set of concave plugs. Then as noted above from KenC, I installed it with the convex side up...all went well.
    ClayMart likes this.
