Hot Rods Another Deuce Five Window Gets my Attention
Discussion in 'The Hokey Ass Message Board' started by ct1932ford, Nov 1, 2023.
  1. Deuce Lover
    Deuce Lover
    Very nice! Thank you for post 89
    ct1932ford and Stogy like this.
  2. ct1932ford
    ct1932ford
    While I had the header panel down I modified it to accept sun visors. IMG_5615.jpeg
  3. Fortunateson
    Fortunateson
    So you mention Canadian mice, or was that squirrels? Anyway, where is the car from?
  4. ct1932ford
    ct1932ford
    Originally PA. but spent most of it's later years in Vancouver.
    Stogy likes this.
  5. Fortunateson
    Fortunateson
    WHAT?! I’m in a suburb of Vancouver so I must have seen that somewhere around here.....
  6. ct1932ford
    ct1932ford
    Sent you a pm
    Stogy likes this.
  7. ct1932ford
    ct1932ford
    New USA front drums delivered today.:cool: Old fronts were way out of spec.
    Got these beauties from Gotham Auto Parts LLC in Bedford Hills NY. Called yesterday and got them today! Great service as always. Thanks James! IMG_5619.jpeg IMG_5618.jpeg
    shortypu, TFoch, Stogy and 3 others like this.
  8. ct1932ford
    ct1932ford
    Over at cousin Ted’s today to cut shoes to fit drums. What a great machine. Ted’s expertise made the outcome perfect. IMG_5622.jpeg IMG_5623.jpeg
    TFoch, winr, Stogy and 7 others like this.
  9. The37Kid
    The37Kid
    What is the story behind the two saw horses, quality built stuff like that isn't made today. [​IMG]
  10. tb33anda3rd
    tb33anda3rd
    I don't throw anything out:) these were in a ba*****t I cleaned out and being low come in handy some time.
  11. ct1932ford
    ct1932ford
    Brakes finished and coupe back on all fours. I just keep moving forward.:) IMG_5632.jpeg IMG_5633.jpeg IMG_5635.jpeg IMG_5636.jpeg
  12. The37Kid
    The37Kid
    Amazing how much better it looks with black wheels.
    ct1932ford, V8-m, shortypu and 2 others like this.
  13. ct1932ford
    ct1932ford
    Those are 18” rear and 17” fronts. The yellow ones were 16”.
  14. The37Kid
    The37Kid
    A green hood and deck lid wouldn't look bad for the '24 season.
    Stogy likes this.
  15. ct1932ford
    ct1932ford
    Going to be primer, black and green for awhile. I will be welding up some holes soon. Cowl light holes and a couple of extra one in one side rail someone drilled to mount fender. Go figure! Eventually all black:cool:
    tb33anda3rd and Stogy like this.
  16. ct1932ford
    ct1932ford
    Moved Coupe into the shop bay today. Have some welding to do on it. Let the roadster get some air and run time before going on lift. IMG_5645.jpeg IMG_5641.jpeg
  17. Stogy
    Stogy
    Black, Black, on Black...and mmmmm...bias plys...Looking good Ct...
  18. The37Kid
    The37Kid
    [​IMG][​IMG]
    Plow mounts get welded to the 5Window and the Roadster gets set up to run the ski rope tow, sounds like a plan!
    ct1932ford, lucky ink, Tim and 4 others like this.
  19. Stogy
    Stogy
    But there's no snow...:oops:
    ct1932ford, tb33anda3rd and TFoch like this.
  20. ct1932ford
    ct1932ford
    You guys need some sleep.:eek:
    Stogy likes this.
  21. ct1932ford
    ct1932ford
    Got the hood hold downs finished after remounting the radiator. It was mounted too high with very thick rubber pads.
    Also welded up the cowl light holes and a couple of extra holes someone drilled into the frame. IMG_5656.jpeg IMG_5649.jpeg IMG_5650.jpeg IMG_5652.jpeg IMG_5655.jpeg IMG_5657.jpeg IMG_5658.jpeg
    lucky ink, Lil32, shortypu and 8 others like this.
  22. The37Kid
    The37Kid
    Fenderless with a full hood, looks like a Dry Lakes Racer.
    Just Gary, ct1932ford and Stogy like this.
  23. ct1932ford
    ct1932ford
    Getting there:cool:
    Stogy likes this.
  24. ct1932ford
    ct1932ford
    Car had a lean rear right. After investigating, I removed the rear spring and found another bad bushing, also someone tightened the left side u-bolt nuts so tight they seized to the u-bolt and I had to cut them off. The right side was hardly tight. Someone trying to straighten it out by this method. The top five leafs were longer on the left side. Also center bolt was not straight. I’m sure that probably shifted over time. I will cut the leafs and get it all sorted and see what happens.
    Stogy, tb33anda3rd and Big Al like this.
  25. sshep
    sshep
    Nice work Mark, The coupe is really coming around to your vision.
    Stogy and ct1932ford like this.
  26. ct1932ford
    ct1932ford
    Thanks:cool:
    Stogy likes this.
  27. banjorear
    banjorear
    Looks real good, Mark. Incredible car.
  28. Joe Troilo
    Joe Troilo
    Great job Mark.
  29. ct1932ford
    ct1932ford
    Can’t wait to get back to work on it. I will be back at it Monday.
    Stogy, tb33anda3rd and pprather like this.
  30. tb33anda3rd
    tb33anda3rd
    prepare to wet sand some parts:)
