Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. saltflats
    saltflats
    from Missouri
    I cringe when I see that Taylor name, I worked at that place for a short spell outside of KC. when I was going to tech school. Finally got a job at the Midas shop at 30th and Troost :eek:
    chryslerfan55 and osage orange like this.
  2. chevy57dude
    chevy57dude
    Braided steel hose in black? Never saw that.
  3. saltflats
    saltflats
    from Missouri
    It has a fabric cover over the stainless braid. I like the look.
  4. 57 Chevy
    More realistic C-notch this time
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Now that the top is off my corvette this gap was real obvious
    Pretty ugly back there. I knew there was a small upholstery panel supposed to be there. I had some .025 polycarbonate and pearl white vinyl. So a little spray glue and a snap for the front. The back is riveted to the bottom of the hatch for the rag top
    A5C8435B-15F5-409B-970E-6B6B79BB4D91.jpeg AAE4A62C-F45C-434F-9EB8-9931DBBA8599.jpeg
    Looks a lot better
    3C538FB6-1740-4BDD-967E-20500A5A11F4.jpeg 05609FA3-8293-4394-8C6E-17FA24005680.jpeg 3DD4E282-E8C5-44EB-890F-DF1EC6C86F3B.jpeg
    Jeff34, rod1, anthony myrick and 19 others like this.
  6. 1pickup
    1pickup
    Waiting for the switches I ordered for my dash project, so I can drill the correct sized holes. As a distraction, I did a quick Triumph Bonneville tank. I Have no use for it but was tired of tripping on it in my shop. Painted it Black Sapphire & put some "original style" scallops in rainbow flake. It might make a cool table lamp.
    rod1, alanp561, J. A. Miller and 11 others like this.
  7. Reddy
    Reddy
    I had to vent the gas cap so drill a hole in the screw that told the gas cap on to the gas tank
    Mike
  8. pvfjr
    pvfjr
    Finishing up bed wood replacement in the old stepside. And no, it's not rough-sawn. That's curly white oak grain.
  9. swade41
    swade41
    from Buffalo,NY
    I'm going to use rough sawn from the Amish in my 57, thinking about giving it the used motor oil and diesel fuel treatment
    40FORDPU, rod1, Bandit Billy and 9 others like this.
  10. lumpy 63
    lumpy 63
    20231210_112226.jpg Started setting up engine mounts for the sbf in the 32 3window, gotta figure out the short water pump set up for a 289. Also got the bed painted on my slightly off topic C10 but I won't post any pics of it:cool:
  11. Zax
    Zax
    Pulled the heads off the 59A I removed from my '40 Ford. I expected a damaged piston, but I thought it would have been the one that only had 50 lbs on the last compression test...
    IMG_2459.jpg IMG_2460.jpg IMG_2461.jpg IMG_2462.jpg IMG_2463.jpg IMG_2464.jpg
  12. 29A-V8
    29A-V8
    from wyoming
    been replacing wheel cylinders on 1956 ford victoria 2 door hardtop, forgot how much fun it is to clean up after a wheel cylinder leaks. only one thing worse getting on your hands then anti-freeze and thats brake fluid!
  13. squirrel
    I hauled this home...I worked on it a long time ago. Now it needs to get back on the road after sitting for several years. 6 cyl 4 speed.
  14. brokedownbiker
    brokedownbiker
  15. High test 63
    High test 63
    I put used motor oil and crude oil on rough cut white oak for my 29 AA truck. It soaks in and doesn't peel. Diesel fuel is very similar. Its definitely not a show finish but I really like its utility.
  16. Let me introduce you to Never Seize!
    J. A. Miller and 29A-V8 like this.
  17. High test 63
    High test 63
    That's nice, and tough. And stable quarter sawn.
  18. That looks great! A home for your new 261?
  19. squirrel
    Probably not, the 235 is in good condition I think. Trying not to spend money on it.
  20. 29A-V8
    29A-V8
    from wyoming
    Im listening...........
  21. 67drake
    67drake
    from Muscoda WI
    Rebuilding an engine right now, so it seems like my parts washer gets used daily for one thing or another. Sitting in one of the darker spots in the shop, I finally got around to hanging a couple 2’ lights over it that mount pretty well under the shelf above the washer. IMG_0128.jpeg
  22. 29A-V8
    29A-V8
    from wyoming
    What cleaning solution do you use in the parts cleaner?
  23. 29A-V8
    29A-V8
    from wyoming
    28phonebooth tell me more.
    '28phonebooth likes this.
  24. swade41
    swade41
    from Buffalo,NY
    Sorting the new wires on the 41
    alanp561, saltflats, loudbang and 6 others like this.
  25. 67drake
    67drake
    from Muscoda WI
    Bill's Auto Works likes this.
  26. In my experience a matchhead sized dollop of Never Seize will cover the part, your hands, the front of your shirt, the eyebrow you just scratched, the doorknob on your way into the house, and the faucet handle on whatever sink you choose to wash up at. Your wife will discover it on the hand towel, the toilet flush handle and your pillowcase.
    That **** is like a visiting relative.... it NEVER goes away!
  27. What am i working on? Well i’ll tell ya… well maybe not it’s a little o/t. Either way, i’ve got to pull the body back off the frame then cut the frame in two to correct a little mis-alignment issue. I have found the proper measurements so this time it should go together where it should be:oops:
  28. Franco51merc
    Franco51merc
    Working on my 50 Buick trying to get the front clip to fit right after doing a Camaro subframe. 20231211_201131.jpg
  29. 29A-V8
    29A-V8
    from wyoming
    Thanks 67drake
    Your absolutely correct, in my younger days I was less attentive and did have a problem with it myself. I was unsure about the name you used as in my neck of the woods we called it anti-seize, you can tell as I advance in age I sometimes have a word ***ociation block and identical substance's called by different names make me go duh.
  30. atch
    atch
