1955 Pontiac 605 steering box upgrade
Discussion in 'The Hokey Ass Message Board' started by Spdntrixi, Dec 10, 2023.
  1. Spdntrixi
    Spdntrixi
    I'd read up on doing this conversion before digging in, and it seemed pretty straight forward, but I've run into a snag. I upgraded my 1955 Safari to the 605 steering box, as derailed on pontiacsafari.com , and my original pitman arm is slightly smaller than the splined shaft on the new gearbox. Everything I've read said the old pitman arm would work. The 605 box appears to have a 1.125" shaft and my '55 pitman arm seams to be closer to 1". Has anyone run into tuis and can someone guide me to the correct parts that I need to make this work? Thanks in advance for any help!
  2. vtwhead
    vtwhead
    Speedway sells a 605 pitman arm as do many other vendors. I have purchased new arms thru Napa in the past as well.
  3. Spdntrixi
    Spdntrixi
    Thanks. I do see that but was worried that the length and amount of drop wouldn't work for my application, along with it not having the correct pivot ball. Is there a way to put the ball on it and is it ok to heat and bend them ? Thanks again for the response.
  4. vtwhead
    vtwhead
  5. Bird man
    Bird man
    from Milwaukee
    PS & manual used different pittman arms. Was your rig a manual?
  6. Spdntrixi
    Spdntrixi
    My car has the original bulky power steering box setup, which will be available for someone who could use it, once I get my upgraded steering sorted out.
  7. Spdntrixi
    Spdntrixi
    Thanks. That's very helpful info. Any idea how I can tell if a pitman arm is forged or cast?
  8. Bird man
    Bird man
    from Milwaukee
    They were all forged, look at the thick parting line.
  9. Spdntrixi
    Spdntrixi
    Thanks!
  10. Spdntrixi
    Spdntrixi
    I've it figured out. It requires the early style 605 gear box that has the snap ring retaining the upper cover as opposed to 4 bolts holding the cover on. Lares has an updated one that is the early style with the smaller output shaft, but a bolt on top cover. Lares part # is 11206. Hope this helps someone else doing this conversion and thanks for everyone's input who tried to help me figure this out!
  11. XpertSignTools
    XpertSignTools
    Hello, I have a 1955 Pontiac Star Chief and my power steering box has gone bad. Is your steering box still available? I could really use some help getting another one. Thanks, Josh
  12. Spdntrixi
    Spdntrixi
    Yes, I actually have 2. 1 I've cleaned and painted (not rebuilt) and 1 original and untouched.
  13. XpertSignTools
    XpertSignTools
    What are you asking for them? Thanks for responding.
  14. Spdntrixi
    Spdntrixi
    No problem. $250 for either box, $350 for either with the column.
  15. XpertSignTools
    XpertSignTools
    Would you please send a few pictures. Thanks
  16. Spdntrixi
    Spdntrixi
    Sure, but it'll have to be after I get off work tomorrow.
  17. Mr48chev
    I'm thinking that is the same thing as what I did on the 57 Starchief I had around 1980. I swapped boxes using the old pitman arm and slid the column down a little to match up with the new box. I never got it running as my wife hated the faded lime fire green and traded it for a 63 Chevy ragtop. I always wondered if who ever got it had issues with leg or lap room with the wheel being closer to the dash.
  18. Spdntrixi
    Spdntrixi
    Was able to go out and take pics this morning. The cleaned and painted one is the one that was in my car, working good, but had a small leak. The other box and column I got used, was told is good, but I never tried it out. These are heavy and large so shipping will be expensive, but you're more than welcome to pick it up. I'm in Sacramento, CA. The cleaned and painted one, I began to dis***emble the shaft to make it easier to shop, but thats when I changed gears and went with the 605 box installation.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    you guys need to handle this transaction via private message. The main forum is no place for buying and selling. thank you
  20. poncho catalina
    poncho catalina
    from summit il
    I was wondering if you got the 605 installed ?
    How did it go, did it give you any more clearance ?
    And did you get to drive it yet and what is your opinion of the swap? Any pics?
