Technical Anyone assembled a brookville 3-window body
Discussion in 'Traditional Hot Rods' started by 65standard, Dec 12, 2023.
  1. 65standard
    65standard
    I’m having an issue with the A-pillars. Not sure what is off or how to correct it. I know Ben built his 3-window but I can’t get ahold of him.
    Tony
  2. Happydaze
    Happydaze
    Pics might help. I've not built one, but have one.
    Chris
    Lil32 likes this.
  3. 65standard
    65standard
    D595AA98-CBE9-4C7B-AAE9-E2FCD3BB55E4.jpeg The A-pillar ***embly is straight from top to bottom.
    The body has the windshield A-pillar leaning more forward and not a straight line. B942EB7A-17D8-479B-B21B-43E68D54468B.jpeg
    Just not sure what’s off and how to correct this issue.
    It just doesn’t follow the body side.
  4. seadog
    seadog
    Watching
    leon bee likes this.
  5. Budget36
    Budget36
    If bought from Brookville, may be best to contact them?
    Woogeroo and clem like this.
  6. Happydaze
    Happydaze
    If I'm not mistaken, isn't the whole side of a Brookville body a single pressing? That's the rear quarter, sail panel, roof side, a pillar and cowl side. Not sure about the rocker / sill but the joins suggest that's separate. That being the case it must have some flex in it. I'd guess the tying in to the adjacent panels would require the door to be in the aperture first.
    I know Walden ***embles them and has his own jig that fits inside the body to provide alignments.
    Not that this helps you but it might help you trace your steps?
    Chris
    Lil32 likes this.
  7. If the doors fit the opening (should, B-Ville uses a uni-side stamping) then the inner A post would need to fit the uni-side
  8. 65standard
    65standard
    Can someone run a straight edge on their 3-window and see if the body is supposed to be dead straight at the front edge of the door opening?
    Yes, The sides are stamped in one piece.
  9. 65standard
    65standard
    I’ve been waiting months for doors. Kenny tells it will be months more before the stamp them.
    I wish I had a door to go off of.
  10. nochop
    nochop
    from norcal
    Seems like you would need the doors before going forward
    Jacksmith, lucky ink, Dak Rat and 4 others like this.
  11. K13
    K13
    I certainly wouldn't be trying to ***emble it without the doors.
  12. gary macdonald
    gary macdonald
    Here is a pic of one that’s currently for sale on here , not mine . FCB5BB77-C425-4B01-9EC9-3F0DE62E8FDD.png 8348585A-0675-4443-BE5B-BD208F9CB166.png
    Stogy likes this.
  13. Happydaze
    Happydaze
    Just checked on mine. Looks very straight. A 2 foot approx straight edge shows its straight accross the side molding on the A pillar, so about a foot either side.
    My door aperture (painted) measures a hair over 39" at the side molding height.
    Hope that helps.
    Chris
    Lil32 likes this.
  14. Maybe someone with a finished Brookville can shoot photos of their doors and take measurements across the top, bottom, and midway at cowl level.
    Is it possible you have a Frankenstein of mixed car and truck pieces? .......or different years?
  15. gary macdonald
    gary macdonald
    The bottom bead and point look off from the one thats for sale
  16. alchemy
    alchemy
    It’s futile to try ***embling any puzzle without all the parts. What if the post was tweaked, and now you’ve welded it solid to the cowl top?
    alanp561 and anthony myrick like this.
  17. gordspeed
    gordspeed
    from Oregon
    Might be some helpful photos on this Thread...
    "UN***EBLED 3W COUPE, HOW TO DO IT
    gary macdonald likes this.
  18. WiredSpider
    WiredSpider
    Here is a photo of my OG 3 window. Being black it is a little hard to photograph. I held a straight edge up to the jamb and the top of the door opening in maybe 1/4 or 3/8 forward of being dead straight IMG_1951.jpeg
  19. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Here are a few pics. The front is pretty straight between the arrows in the pic. Couple detail shots too.
    The broom handle was the only straight thing nearby............
    anthony myrick likes this.
  20. 65standard
    65standard
    DFA2995B-BF17-44A4-911C-25850A75BE64.jpeg Thanks for all the help. It looks like I need at straighten the body sides at the A-pillars
    this build is my personal project at work. I only get time to work on it at lunch. So it’s been 3 years already.
    3W Larry got me hooked and the Rolling bones guys keep me going. I’m going the full Schmidt here.
  21. Here is a side shot of one from with many moons ago.
    (Chopped)
  22. Could be the angle of the pic but the windshield post angle looks strange
    Stogy, clem and lurker mick like this.
    here’s the parts.
    A-post look straighter
  24. krylon32
    krylon32
    from Nebraska
    I've done a couple Henry 3 windows and have one in the garage. Something just doesn't look right. As said before the complete side is one stamping. The post above should give you an idea of what it should look like. Have you contacted Kenny at Brookville? Several of the go to guys who knew what was happening have retired so I'm not sure who to tell you to talk to?. I do know that when I was ***embling Brookville roadster bodies in the late 90'sto early 2000's I did have get a little creative to get everything to fit. Sometimes I felt maybe there some seconds being sold? It all worked out and the bodies were fine, but.
    Budget36 likes this.
  25. 65standard
    65standard
    I think if I push outward at the crease line it will help straighten the body out? The stamping must be correct and it just got pushed in at the weak area from stacking them on top of each other or pulling them out of the dies stressing that area or something?
    I’ll try calling Kenny at Brookville tomorrow and see what he thinks
    Stogy likes this.
  26. Kevinsrodshop
    Kevinsrodshop
    Not sure if this would help....
    patsurf likes this.
  27. Mr48chev
    Shrinkage from welding the cowl pulling it a bit? Possibly the hook tab A to Slot A Tab to slot B thing got out of the step by step order. Simply meaning that if you don't put the structure in this spot before you weld that spot that spot tweaks this spot.
  28. chickenridgerods
    chickenridgerods
    from DSM, IA
    Either wait for your doors and chop it, or do heavy Rolling Bones style chop now, lean the pillars back, and then make the doors fit. I'd personally wait for the doors. Especially if you're already 3 years into it.
    rockable, Wanderlust and X38 like this.
  29. X38
    X38
    Really difficult to tell from pictures, but my gut reaction when I first saw your pictures was the A pillar looks too upright. I didn't want to comment, because optics can be deceiving. Having said that, I agree with the others, wait for the door and use them as a datum. Especially if chopping, you can do whatever is necessary to make things right.
