Technical Chevy Starter application with horizontal bolts?
Discussion in 'The Hokey Ass Message Board' started by Hemi Joel, Dec 11, 2023.
  1. Hemi Joel
    Hemi Joel
    from Minnesota
    Hi, We are building a rear motor plate/adapter to put a GM bellhousing and manual trans behind a Lincoln 337. Our car will have a belly pan and is designed to be serviced from the top. The GM starters I know about have vertical bolts going up from the bottom to attach it to the block. So we need horizontal bolts to attach a starter to the adapter. We will use the 168 tooth flywheel. Does anyone know what starter we should be looking for?
    Thanks, Joel
  2. Not sure if it works for 168 tooth flywheel but the
    ACDelco Professional 336-1849 Starter, has horizonal bolts
    Hemi Joel likes this.
  3. Mr48chev
    This starter fit a lot of Chevys and GMCs with manual trans This one for a 68 C 10 with a 327 and granny 4 speed. Screenshot (524).png
    I'm thinking 60/68 with a manual trans have the starter that bolts to the bellhousing rather than the block.
    I remember that back in the early 80's someone gave my buddy a pretty nice 327 that had the corner of the block that the vertical bolt starter bolted to broken off ( I think the chain they were lifting it with broke) and we stuck a truck bellhousing on it and ran the truck starter.
  4. Early 60's Corvettes used that starter and I checked my 62 and the flywheel has 168 teeth so the one I mentioned previously should work if mount points are same.
  5. Oneball
    Oneball
    Most of the aftermarket hi-torque gear reduction staters for SBC are horizontal bolt starters attached to an aluminium adapter plate
    SS327 and Hemi Joel like this.
  6. Mr48chev
    That starter fits a list of Chevys that is pretty long.
    Several outfits including Jegs and Summit sell a starter plate for tri 5 chevys when you put a late trans behind the engine that doesn't have provisions for a bolt from the bottom starter. I'm not sure that would be good for anything except a pattern in your case though. You could do that with a truck bellhousing. Screenshot (526).png
    X-cpe and Hemi Joel like this.
  7. Hemi Joel
    Hemi Joel
    from Minnesota
    Thanks for the reply's, you guys are on it! A gear reduction mini starter would be great.
  8. Mr48chev
    They are great at chewing up ring gears at inopportune times though.
    irishsteve likes this.
  9. bobss396
    bobss396
    I have used truck bellhousings forever with my Chevy applications, manuals only of course. Were trucks with automatics using the same type starter?
  10. squirrel
    bobss396, Desoto291Hemi and alanp561 like this.
  11. BJR
    BJR
    Pre 63 Pontiac's have horizontal bolts.
  12. Up to 1972 C10 with manual transmission used the horizontal mounting bolts.
    In conjuction with @Mr48chev @squirrel post.
  13. Casual 6
    Casual 6
    from Great NW
    Since you're making your own engine/trans adapter, another option for a "horizontal" bolt pattern starter is one off of a 2005 - 20010 Trailblazer Vortec 4200 six cylinder. Different bolt pattern than the early Chevies listed above, but still uses the same starter gear. It is small and powerful. Sort of a factory mini starter. I used one on an engine adapter I made using a traditional GM bellhousing and GM 168 tooth flywheel.
  14. '51 Norm
    '51 Norm
    from colorado
    I had a similar problem with a Pontiac and made an adapter like the one that Mr48chev showed.
    It worked well and I used it for years.
  15. Hemi Joel
    Hemi Joel
    from Minnesota
    I'm thinking I like that newer one because it only has two bolts and it looks like they are easier to get at. Thanks
  16. squirrel
    Might help to know what you're using for a bellhousing, what the adapter is like, etc
  17. 4 bolt horizontal. Very common. Easy to find parts or replacement.
  18. squirrel
    only horizontal on the upright engines, not on the vertical shaft lawnmowers.
    borntoloze and Desoto291Hemi like this.
  19. Hemi Joel
    Hemi Joel
    from Minnesota
    I have a used Chevy Lakewood ****ter shield I bought at a swap meet. I'm pretty sure it is the late 60 design that has no provision to bolt a starter to it. But I could always sell that and buy a different one if that proved wise.
    squirrel likes this.
  20. Hemi Joel
    Hemi Joel
    from Minnesota
    Except every time you really need it, the rope pulls off and just hangs there in your hand, or else it won't retract.
  21. bobss396
    bobss396
    So do FE Fords... ask the Highlander about his recent experiences... :eek:
    19Eddy30, BJR and JohnLewis like this.
  22. Hemi Joel
    Hemi Joel
    from Minnesota
    I went and ordered the trailblazer starter from RockAuto. Will see if I can make that work. Thanks for the help!
  23. JD Miller
    JD Miller
    I had a factory original 1969 CST/396 1/2 ton chevy truck, turbo 400... It had that "horozontal bolt starter".
    bobss396 likes this.
  24. Casual 6
    Casual 6
    from Great NW
    No problem. And if the trailblazer starter won't work, it is pretty easy to just machine up a new aluminum block (see arrow on picture) that meets your "horizontal" bolt pattern requirements and use an aftermarket mini starter:
  25. Hemi Joel
    Hemi Joel
    from Minnesota
    What starter would I use for that? Say we were to use a starter like that, get rid of that block, and machine whatever is on that block right into the adapter plate that is going between the engine and the bellhousing?
  26. Casual 6
    Casual 6
    from Great NW
    There are a ton of generic aftermarket mini starters like this. Below are just a couple off Amazon. I never thought about machining the adapter plate itself, but that would work. You might still need a spacer between the starter body and adapter plate though, in order to get the right throw distance of the starter gear.
  27. bobss396
    bobss396
    I am this many years old before I knew this. Is the case different over a car unit?
