Technical ***December 2023 Banger Meet Thread - Santa I can explain***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 2, 2023.
  1. railcarmover
    railcarmover
    when you figure it out let me know ..
    Old Dawg and The37Kid like this.
  2. Dan from Oakland
    Dan from Oakland
    Here is a similar pump, except for a B head. The style of the top plate is very similar. I have the same one on my Four Port- it has a spring loaded face seal and does not use packing.
  3. A modern pump technology
    J
    Outback and Old Dawg like this.
  4. Looks like christmas came early!
  5. The37Kid
    The37Kid
    MERRY CHRISTMAS! I never knew that stuff was reproduced, what are the details on Parker?
  6. Kevin Pharis
    Kevin Pharis
    from Califunny
    Pretty sure the name was George Parker… way before my time so only have heard stories. Word on the street is he got the DO Fronty patterns from Joe Gemsa and was delivering castings. Apparently he was working with (or for) Hutchinson Race Engines here in Sac, and the patterns are now held by one of his kids
    The37Kid likes this.
  7. The37Kid
    The37Kid
    50 years ago you wild take the cast iron lump and fasten it to a Bridgeport. Today you would somehow write the program for a CNC machine. Either way it would be interesting to watch a speed up video of the process.
  8. Dan from Oakland
    Dan from Oakland
    George Parker was a foundry engineer who worked for an aerospace foundry in SoCal. At one time he owned what is now Joe Hunt Magnetos in Sacramento. Not sure what the connection with the mag business was. George made all new patterns for the DO Fronty head, chain case, side drive, water pump etc. Castings were produced and he had them for sale at one point in time. I met George at the old Squaw Valley Swap meet that replaced Harrah's swap meet for a few years back in the late '70's ?? and we stayed in touch for several years as he completed the various patterns and castings. His castings were actually much nicer than the original Fronty stuff, a testament to his foundry knowledge. In addition to the DO patterns and parts, he produced a mid-hi compression T flathead and offered that for sale for a few years. At one point he started a project to reproduce the 91 CI Miller engine. I'm not sure how far he got on that project. The patterns for the DO head and parts exist today, and were in the possession of his children at on e point in time but they are not owned by his children any longer. Just sayin.
    40 Olds and The37Kid like this.
  9. The37Kid
    The37Kid
    Thanks for the history Dan! Wonder if there is any connection to the D.O. Fronty Dan Price has produced. There were so many guys back in the 1970's that were into the 4Banger stuff, often wonder where their cars and parts are today. Bob
  10. Savage Coupe
    Savage Coupe
    from Washington
    I’m a believer. Little clean up.
  11. I spoke to Dan a few months ago, and he was in possession of all the Parker stuff. He was hoping to sell everything as he's getting up in age. No clue if there's been any progress.
  12. Dan from Oakland
    Dan from Oakland
    Its great you found all that literature for George's parts. Really cool!! Hopefully the other Dan will make some parts at some point.
  13. 25mercury
    25mercury
    George Parkers shop "Experimental Engineering" was located behind Hutchinson Racing engines. He did do magnetos. DSC06648.JPG fullsizeoutput_1506.jpeg fullsizeoutput_1507.jpeg
    Crazydaddyo, 40 Olds, AZ_Nick and 4 others like this.
  14. walls
    walls
    Working on a new project until the engine is rebuilt for my coupe.
    Traded for this phaeton.
    Only needs some fine tuning with the springs, add some shocks and mess with the brakes. it’s fairly solid.
    Going to get the distributor reworked to match the head a little better.keeping 6 volt though.
    New header and carb too. Two blade fan as well.
    Once I get it on jack stands to fix the front spring, I’ll drop the pan to get any sludge out and check shims.
    In mockup stage waiting for gaskets.
  15. This came to me as ready to run
    Always trust but verify
    John
    fur biscuit and Dan from Oakland like this.
  16. Kevin Pharis
    Kevin Pharis
    from Califunny
    Looks ready to run to me… run all the oil out the front that is! Good catch! Would have made a mess out of #1 rod bearing in a hurry
  17. joemac05
    joemac05
    How can you fix that, is it just the wrong bearing shell? :oops:
  18. I think best to plug the crank and redrill hole in line with bearing
    The web would not be wide enough to support a wide enough bearing to use existing hole
    Much easier to fix now than later
    J
  19. joemac05
    joemac05
    I am ***uming that it is at least a B crank, as if drilling them isn't bad enough, my good golly.:eek:
  20. No not a B crank
    This is a Donovan model D motor
    Drilling C cranks are easy with proper fixture and drills
    J
  21. joemac05
    joemac05
    Well that feels better, and better material in that new crank no doubt. :)
  22. No progress on the engine swap, but the car atleast has quarters now! D7B805A4-69C3-49FF-8151-E4025F27920C.jpeg CEF7F23C-C984-49FA-A795-5257B3C00E63.jpeg
  23. set me on fire
    set me on fire
    20231202_170251.jpg 20231209_172422.jpg HO HO HO!
    Outback likes this.
  24. wuga
    wuga
    Getting ready for the Santa Claus parade.
    Seasons greetings
    Warren
    set me on fire likes this.
  25. walls
    walls
    Could someone help me choose spark plugs for this head?
    Should be 6.8 +/- compression made by Specialty Ford Parts. I believe 14mm.
    Outback likes this.
  26. Time for lunch
    2 bottom ends together
    Finally getting some where
    40 Olds, burl, Crazydaddyo and 2 others like this.
  27. Jeff34
    Jeff34
    HO HO HO!
    who you callin’ a HO?
  28. Mainedrifter2
    Mainedrifter2
    Finally got my crank pulley back on and it’s starting to go back together. 0084EBEF-7C12-443D-BB80-10E3A324B307.jpeg
    Outback likes this.
  29. Liberty Garage
    Liberty Garage
    Outback likes this.
  30. Agreed, it is a nice piece.
    This one was machined by Jay Steel some time ago, never run.
    I had to clearance the block for the REM Rods and will under a HAL 2 cam head.
    J
