Projects 56 Fairlane power swap
Discussion in 'Traditional Hot Rods' started by MrYeats, Dec 11, 2023.
  1. why would you put all that work into a car only for it to have a STOCK 4.6 4v. if youre that far in get a 5.4 4v from a nav
    or build a 351 so itll actually make power without needing an inhaler
    alanp561 likes this.
  2. guthriesmith
    guthriesmith
    My guess would be because it makes a great driver…not what this forum is about, but lots of folks do stuff like this anymore.
  3. i guess, just not my cup of tea then.
  4. guthriesmith
    guthriesmith
    Me either, but I can definitely understand the reasoning.
  5. Dos Cincos
    Dos Cincos
    Your mechanic makes me very nervous. Floor jack is all but maxed out and then has stacks of blocks on top of that and the jack stand is not even touching the frame. Hope he is insured!
    MrYeats and guthriesmith like this.
  6. ottersea
    ottersea
    Should not need to max out floor jack to remove the suspension and the jack stands would be better farther back on the frame. But yeah looks a little sketchy.
    alanp561 and MrYeats like this.
  7. jimmy six
    jimmy six
    MrYeats… I didn’t want a vacuum can on the firewall, just a personal choice, and it’s why I went with a Wilwood 4 piston system including a 7/8” MC. I also drilled a hole just above the original on the brake pedal to give me a better mechanical advantage. I did also made a plug for the original hole to keep its strength. The rod doesn’t interfere with the MC end either. Fords first disc brake cars in 1965 did not have power ***ist or a dual MC as we know them today.
    I will also say at this time with the radiator out install a smaller pulley on the water pump to move the coolant at idle. I know on a 56 a Ford 289-302 from a Mustang works great, (pulley and spacer kit from Summit) many use this because of temp creap at long intersections or idling into car events.
    If you’re really seriously looking to repower in the future I would move the radiator up to the 6 cylinder position at this time.
    Above all have fun with your Ford…it most outstanding feature is “It’s not a Chevrolet”
  8. i believe the heat creep issue was only on thunderbirds since they have a smaller crank pulley
    MrYeats likes this.
  9. jimmy six
    jimmy six
    Not having a Thunderbird or knowing their concerns a Thunderbird owner did suggest the smaller pulley. I can only say that it’s helped hundreds of Ford car owners. Our family owned 55-56 Fords new and none had in town heating problems. But today with the formulation of todays gasoline they do. Full size cars never had shrouds and now are more efficient with them. More are currently air conditioned than ever left the factory with that option also. I share what I’ve learned from others and what as helped me personally.
    MrYeats, 1stGrumpy and guthriesmith like this.
  10. bobss396
    bobss396
    I kept my rear drums manual, so I have to crank the adjustment a couple of clicks once a year. I should have gotten a later self adjuster kit, really not a bad idea and it does keep the pedal up there.
    MrYeats likes this.
  11. bobss396
    bobss396
    Meh... I would simply drive the living **** out of it...
  12. guthriesmith
    guthriesmith
    Lol…don’t tell anyone, but that black 60 Thunderbird I drove daily was done similar. :D
    bobss396 and jimmy six like this.
  13. Good looking '56 and glad you're keeping the Y block since no other engine sounds like a Y block. As others have noted, a 390 is not a difficult swap. My friend Tim Pilgrim has had one in his '56 Customline for years. What's the third character of your caf's serial number which indicates the ***embly plant? My father worked at the Atlanta plant when they were building them. If it's an Atlanta car, he leaded the seams. The man could work lead.
    MrYeats likes this.
  14. HOTRODNORSKIE
    HOTRODNORSKIE
    Have a 390 in my 62 Fairlane a built 312 on the stand and a built 292 in my 57 F100 all fun engines but I just love that 292 hammer on that thing to no end, had problems with distributers to stabbed a Mallory Unilite in it and never looked back. Scored some new old stock Holly Wood steel packed mufflers can't beat the sound you will love that engine.
    MrYeats likes this.
  15. you can shove an FE in one, pretty sure the Cleveland will be pretty easy.
    the rear from a five seven or five eight will go in pretty easy. I ran a '57 rear in my 55 Vic
    MrYeats likes this.
  16. CSPIDY
    CSPIDY
    KISS
    Yblocks forever baby!
    deathrowdave and guthriesmith like this.
  17. James P Reynolds
    James P Reynolds
    Good evening,
    I just joined today after purchasing the '56 Fairlane at the beginning of this thread. Imagine my surprise when I found the exact car during a search. This is my first Ford of this era, and I am excited to learn about it.
    Best regards,
    Jim Reynolds
    Montgomery, TX
    The_Cat_Of_Ages and warbird1 like this.
  18. jimmy six
    jimmy six
    The most important thing to do is enjoy and use your car. Stock or modernized …engine swap or not..the fun is driving your car. Mine comes out every weekend unless it’s raining. For the most part my “modernizing” is unseen but each one has made the car better and more user friendly. IMG_7128.jpeg
    RAK and James P Reynolds like this.
  19. How far along did it get?
  20. James P Reynolds
    James P Reynolds
    Hard to say, I learned more about the car from this thread than when I bought it. Currently, doing fluid changes and safety checks but it seems to be in decent shape.
  21. Is it still running the y block or did it end up with an engine swap?
  22. James P Reynolds
    James P Reynolds
    It still has the Y-block and 3 speed column shift, runs good and sounds awesome.
    RAK and y'sguy like this.
