Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. noboD
    noboD
    Congrats on the big 40. No need for details about Sunday activity but we expect to know everything else that happens. Make sure you sign the card from all of us.
  2. Stogy
    Stogy
    Congrats to you both...dang good seniority there... @squirrel you have a natural Convertible Hairdo...looks good on you...;)
    squirrel and guthriesmith like this.
  3. 41 GMC K-18
    41 GMC K-18
    40 years together, that's an admirable milestone indeed!
    So cool that you both can enjoy each other and still have fun with cool older cars as well.
    Be safe out there, congratulations on your anniversary !
    Thor1, RAK, chryslerfan55 and 5 others like this.
  4. DDDenny
    Ok, enough kissy face, get out there and burn some rubber!
  5. DDDenny
    But don't be this guy!
  6. El Hueso
    El Hueso
    porkshop, Stogy and X-cpe like this.
  7. X-cpe
    X-cpe
    I wonder how good the story is going to get after a few beers.
  8. lumpy 63
    lumpy 63
    I saw that happen, guy had his kid in the car and lost control doing a burn out....
    Stogy, tractorguy, scotty t and 6 others like this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
  10. lumpy 63
    lumpy 63
    Goodguys Del Mar
    scotty t likes this.
  11. squirrel
    In the staging lanes at clutch is squealing again
    Thor1, Oneball, Tickety Boo and 13 others like this.
  12. squirrel
    Right lane. Red lights. Oops
    David Gersic, Thor1, LAROKE and 12 others like this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I had that pattern once. Input chattering in pilot bearing. New pilot bearing took care of it. IMG_2346.jpeg
  14. squirrel
    that's a possibility. Thanks
  15. squirrel
    On the road to Las Vegas. It's not convertible weather.
    Thor1, Sancho, brEad and 22 others like this.
  16. DDDenny
    Went by that in 97 on the Hot Rod Power Tour, this Oregonian just couldn't relate.
    Johnny Gee likes this.
  17. squirrel
    Made it to Vegas.
    Heading to my friend's house to work on the car and visit
    Thor1, bchctybob, LAROKE and 18 others like this.
  18. bobss396
    bobss396
    No red light and the RT is respectable. :cool:
  19. squirrel
    the rt is horrible! they ran sportsman tree at Irwindale, which I wasn't expecting so I redlighted, then they ran pro tree at Vegas, which I wasn't expecting so I spent a second sitting there staring at the green light.
    Got a pilot bushing too late to have the time to install it. But did spend some more more time looking at the distributor, and checking dwell and timing. The advance mechanism is wonky, it sticks at full advance, so I have the timing set up pretty far, and it's causing it to buck at low rpm. Not sure what I can do about it right now, except back off the timing so it's retarded at speed. Which is probably the best compromise.
    Anyways, we went with my friend to his aunt's 70th birthday party, and had a great time. They were even taking polaroid type pictures of all the guests. I've known their family for a long long time, it was fun.
    And I gave Janet her 40th anniversary card and Lego gift this morning.
  20. flynbrian48
    flynbrian48
    I've been dealing with, or trying to deal with, the faulty grounds of the 6 taillights on my '62 Impala. I've cleaned the mounting sites, the buckets, ran separate grounds, etc. They'll all work in the driveway, then the ones in the trunk on one side or the other will not come on, or do the weird "no ground" thing with the rest of them. They dim, they won't light, the turn signals won't work, or will, depending. It's aggravating, especially with the poor attention spans of drivers doing their make-up, texting, or driving stoned. Lastly, the indicator switch under the wheel called it quits. I've got some work to do when we get home...
  21. Had to do the same on my old '64 panel truck, br*** center to aluminum housing.
  22. You have to pay extra for that prime parking spot.
  23. ClayMart
    ClayMart
    I wonder if this is one of those situations where it helps to run a separate ground strap from the inside of the deck lid to somewhere inside the trunk compartment. This can usually be done around the trunk hinge area so the ground strap doesn't get in the way of things.
    Attach one end to the inner reinforcement under the deck lid and the other someplace under the parcel shelf. A simple braided ground strap should provide enough flexibility when opening and closing the trunk.
  24. squirrel
    Back to the car today... I bought a new Chinese point distributor, and installed it when we got to Pomona. Timing looks better, runs better. No tach. Made a p***, ran good.
    Thor1, Sancho, WC145 and 29 others like this.
  25. saltflats
    saltflats
    from Missouri
    Looks like your having fun.
    I have the same aluminum foot locker from my dad.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    I had a weird advance deal on a tach drive dist once. It would work fine as long as the distributor was loose. as soon as I tightened up the hold down clamp it would stick. I put 2 gaskets on it and it was fine. I am not sure if it was an incorrectly machined manifold (aftermarket) or if the gear on the bottom was not shimmed correctly
  27. flynbrian48
    flynbrian48
    That's what I'm thinking. Poor grounds can be really frustrating to chase. My '64 Riviera had the drivers door power window quit. All the others worked, this one had, then nothing. Tracing it, the switch was powered, both from the drivers door side and it's own switch was juiced, power to the motor, but nothing. Turnout to be poor ground between the door, the hinges and the body. The bolts were corroded in the cage nuts and between them and the hinges. There was a GM service bulletin on it from the time, adding a ground strap was the "fix", and what I did. Worked fine after that.
    Thor1 and ClayMart like this.
  28. RodStRace
    RodStRace
    For you guys chasing bad grounds, may I suggest making a few test leads with alligator clips. Try grounding the suspect part and any others (all 4 corner signal bulb sockets) before cutting and splicing wires. The nice innocent wiring you save will thank you!
  29. Crosley
    Crosley
    from Aridzona
    Plenty of luggage for that Corvette trunk.. Margarita boxes too.
    WC145, Johnny Gee and 41 GMC K-18 like this.
  30. squirrel
    Most of the stuff there is from another guys' truck, who went to get in staging lanes for racing. Not my stuff.
    Nominal, 41 GMC K-18, WC145 and 5 others like this.
