Projects 1959 El Camino Build
Discussion in 'Traditional Customs' started by Hotroder95, Dec 15, 2023.
  1. 38Chevy454
    38Chevy454
    Here's my old kind of beater 60 El Camino with your wheel and tire thoughts to help you see how they look. This one just dropped with cut springs:
    This 60 had a 307 and T350. I also had a 59 El Camino (notice this past tense on El Caminos) that had a 350 and 700R4. Traditional SBC works great in these, although you can fit just about anything. Here's my old 59, this one had dropped spindles and lesser cut springs.
  2. willys36
    willys36
    Fun project. Grandson and I did one in the teens him. Took lots of in-progress photos so if you need any advice just ask. We ran a 305 SBC with 200R4 ******. Car had a factory posi rear end. We did everything from the ground up.
    start car 1.JPG Frame stripped.JPG IMG_5391.JPG IMG_5393 - Copy.JPG IMG_5394.JPG IMG_5398.JPG
  3. 327Eric
    327Eric
    IMG_20220706_202015.jpg IMG_20220706_201937.jpg IMG_20231024_200802.jpg Here is mine with 5 spokes International drag masters, soon to go to stock wheels and caps. It has a 62 327 and a Saginaw 4 speed. I could make it look stock if I cared
  4. 327Eric
    327Eric
    Stogy likes this.
  5. willys36
    willys36
    It's as pre-2000 Cadillac power split bench. Can't remember if the center console came from that car or we adapted it from another. I seem to remember the latter.
  6. Hotroder95
    Hotroder95
    from Kansas
    I will have to look tomorrow after work and see! I hadn’t really thought about checking that out yet. I do believe it was one solid color, but I also have the chrome that splits the el Camino for a 2 tone paint job!
    gotta56forme likes this.
  7. Hotroder95
    Hotroder95
    from Kansas
    The stance is perfect on the 60! That’s exactly how I would like mine to sit, and I really do think I’m going to run astros and thin white walls.
  8. Hotroder95
    Hotroder95
    from Kansas
    I will definitely have questions! I want to split the body from the frame, and I have a spot behind the rear window that I’d like to see how it looks from the factory because mine looks a little odd. I also have a few parts I’m having a hard time finding
  9. willys36
    willys36
    we took the spare tire out of the cab and put it under the rear bed where it belonged. We adapted a Dodge Dakota crank hoist for the spare. We then opened the bottom of the back wall into the 'smugglers compartment' under the bed for storage. They do have a small 'luggage tray' between the seat and rear window if that is what you are referring to? We notched ours so the seats could slide a bit farther back.
    OOPS! You said behind the rear window. Are you referring to the hidden compartment beneath the bed panel? That is referred to as the 'smuggler's compartment'. It is there because to rush the truck to market to compete with the Ford Ranchero, Chevy just bolted Elky sheet metal to a station wagon platform. That space is the footwell for the 'wagon rear seat p***engers. We welded a a sheet metal roof over it and opened it into the p***enger compartment.
    Hotroder95, LCGarage and guthriesmith like this.
  10. swade41
    swade41
    from Buffalo,NY
    One of my friends had a nice custom done in black primer with white interior, bed cover and whitewalls, dual dummy spots, frenched antenna, shaved.
    I can't find a photo of it but here are others
    FB_IMG_1702837089490.jpg FB_IMG_1702837207409.jpg FB_IMG_1702837216223.jpg FB_IMG_1702837265629.jpg FB_IMG_1702837280477.jpg
  11. Hotroder95
    Hotroder95
    from Kansas
    So I took a picture of the part I was curious about how it would look originally, it looks pretty rough
  12. The spot behind the gl*** is just a trough and is under some trim.
    Hotroder95 likes this.
  13. Hotroder95
    Hotroder95
    from Kansas
    I appreciate the info and the picture! I was nervous seeing the bondo/filler. Looks like I should be able to just clean up whatever the previous owner did and see how it looks underneath.
  14. You can build almost anything and it will be covered by 3 pieces of trim. I believe it's to carry the water from under the gl*** and dump it into the bed, they rot quite often.
  15. 6sally6
    6sally6
    I live those "city-farmer" trucks !!!
    350's should still be pretty plentiful in junkyards.
    700R/4L-60 ****** behind it and you're golden (OD too)
    A snotty-idling camshaft with turbo mufflers and headers will give it some at***ude.
    Edelbrock RPM intake and 650/700CFM eddy carb and you got a dependable skreet rod !!!
    6sally6
  16. Hotroder95
    Hotroder95
    from Kansas
    The more I think about it, that does seem like a nice way to quickly get this car on the road!
