Technical HI-PO exhaust manifolds (FORD)
Discussion in 'Traditional Hot Rods' started by studebakerhawk, Dec 17, 2023.
  1. studebakerhawk
    studebakerhawk
    from Colorado
    I'm building a 37 Ford coupe with a 302 and C-4. Dad had the car mocked up with an exhaust system using stock exhaust manifolds and a 302. The 302 was just a worn out mock up engine and I've pulled it - had it bored .030, got an Edelbrock intake, holley 600, flow-tech heads, 331 stroker kit, and a mild roller cam since there seem to be soooo many issues with flat tappets these days. The car has a dropped I-beam with stock wishbone and a Saginaw 800 power steering box. I've had several people tell me I would be choking my engine with the cast iron manifolds but with the wishbone and the Saginaw 800 there is just no room for headers. Are the Scott Drake Hi-Po exhaust manifolds really any better than the 302 manifolds I already have ?
  2. KevKo
    KevKo
    from Motown
    I don’t know about the Drake manifolds, but on the street my opinion is you will probably never see the rpm’s where headers make a difference.
  3. TCTND
    TCTND
    What he said. Might cost you 10-15 hp at 6K; on the street, so what?
    57Fury440 and V8-S10-C3500-- Bug like this.
  4. jchev1953
    jchev1953
    Got agree with KevKo for a car that you are primarily going to drive on the street the stock manifolds will only cost u a little horsepower. If you have access to it the guys on Engine Masters have done a comparison on one of their episodes. If you want to improve the stock manifolds flow you could have them Extrude Honed. Also have you tried a pair of Ford Fox Body headers they might be a low cost performance option?
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    ^^^This
    I was the FoMoCo dyno engineer on the Mustang 5.0 GT program. The shortie, stainless steel factory headers lost only about 5 - 10 HP compared to long tube headers, when running a full, dual exhaust system with a crossover pipe.
  6. Why is it that most of us don't give a second thought to totally building a project on our own but will not build our own header system to fit what we need? A simple Tri-Y system is for sure first grade in the exhaust world, and they actually work pretty well as long as you step pipe as you go. Much better than stock manifolds.
  7. The HiPo manifolds are better than 'most' 302 manifolds and nearly as good as shorty headers. Two advantages are they're less likely to leak or crack like headers, as well as being a bit quieter. More compact too, so may be an easier install.
  8. studebakerhawk
    studebakerhawk
    from Colorado
    The amount of room available would dictate making headers that almost look like the same shape as stock manifolds, like one long runner from the front cylinder with the other 3 joining in -- probably no better than stock manifold but a lot more work and potential for leakage -- so I sort of discarded the idea of making headers on this project. Dad had originally built stainless headers for the previous engine -- a Boss 351C going into the fender wells and the mufflers were hung under the running boards, but that was when the car had the original early Ford steering box -now the Saginaw 800 (and hoses) take up space that the headers would need.
  9. X38
    X38
    Use cast manifolds, move on, enjoy life.
    dirt t, alchemy, RodStRace and 2 others like this.
  10. studebakerhawk
    studebakerhawk
    from Colorado
    If the Hi-Po exhaust manifolds are better than "most 302" manifolds then they are probably better than the 72 302 2 barrel exhaust manifolds I already have. Thanks
  11. 6sally6
    6sally6
    Lotsa my "M-word" buddys swear my the HiPo manis. They don't sound as cool (IMHO) long tubes but........they don't leak like'm either !
    6sally6
    THE FRENCHTOWN FLYER and Deuces like this.
  12. RmK57
    RmK57
    On a performance build like that I wouldn’t even consider stock 302 manifolds. The hipo manifolds if they fit without interference would be great. First choice for me would be a header kit and build my own tri-y setup.
    Good luck.
    dumprat likes this.
  13. deathrowdave
    deathrowdave
    from NKy
    I have a couple scarce 289 4 v not HiPo from a Comet with 4 speed . I think one will fix you up fat .
  14. mgtstumpy
    mgtstumpy
    From Fairlane Club of America. Comet / Falcon headers are different to Fairlane and Mustang
    oj, vtx1800, ottersea and 2 others like this.
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  16. RodStRace
    RodStRace
    Yeah, when Freiberger had an engine on the dyno with some headers and started smashing the tubes, it showed that the flow didn't affect power at normal street operating RPM.
    https://www.motortrend.com/news/eng...es-headers-for-horsepowerso-you-dont-have-to/
    Unless you are building a hoodless, fenderless 37 :confused: that shows the exhaust, I don't see why you would bother. If you dig the fab work, you could make some nice heat shields for the floor and starter.
  17. There are a few other choices that may be worth looking at as I don't know your particular fitment issues. '69-72 full-size Ford car 351W manifolds are configured a bit differently compared to the HiPos but offer a bit better breathing compared to the standard 302 pieces. Those would probably be hard to find these days. A more common similar choice is the late '70s to late '90s 351W truck manifolds. These are heavy-duty, a downside is the heavy reinforcing ribs cast-in making them both heavier and bulkier. But the ribs can be ground off. All of these (including the HiPos) will benefit from port-matching the manifolds to the heads. Be careful around the bolt holes, it's thin there.
  18. finn
    finn
    Supposedly, the mid to late seventies 302 Maverick manifolds flow better than earlier manifolds, and the outlet is more suitable for hot rod applications.
    I can’t personally verify that, though
  19. RmK57
    RmK57
    The engine is a 331 stroker, half decent heads, roller cam so it should make 350 hp with a good flowing exhaust from the heads to mufflers. With restrictive manifolds I could losing at least 15-20 hp with small port iron manifolds. Not the way go for a performance build.
  20. dumprat
    dumprat
    from b.c.
    Early 302 manifolds are horrible. They crack like crazy. Anything is better.
  21. BamaMav
    BamaMav
    from Berry, AL
    I used Explorer manifolds to clear my steering box. They come in a cast version or a tube header style. They carry the front two tubes up and back, then drop at the third port, with the rear port coming forward. Maybe not the best flow, but in my case it was use them or build a set of custom headers, which I didn’t feel comfortable doing. I’m not the best welder on thin tubing, so they probably would have ended up looking like ****.
    Beanscoot likes this.
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Dyno testing on those Explorer manifolds showed they were bad, even worse than the cast exhaust manifolds, but if they solve a real estate problem, like they did on the Explorer, go for it.
  23. 38Chevy454
    38Chevy454
    I've got stock (std non performance) manifolds on my 37 Ford Ute with a 302 SBF. Stock wishbone and X- member also. Agree it's a tight fit for any exhaust and with my close to stock 302 it's a tradeoff that works.
  24. dumprat
    dumprat
    from b.c.
    Around here you can buy stock 5.0 headers for $50 a pair. They flow pretty well and there are two styles. One style is a simple 4:1 and the other is 2:2:1 both stainless and long lasting.
    Deuces likes this.
  25. The HY-PO manifolds work fine. They are not hard to find.
    as for street RPM I wing my motors pretty tight. That is what they are built for. I got to believe that I am not the only one who drives one. I could be wrong.
    Truckdoctor Andy likes this.
  26. seb fontana
    seb fontana
    from ct
    IMG_0531 - Copy.JPG IMG_0534 - Copy.JPG IMG_0533.JPG I pm'd the OP Monday [Dec 18] about some MAC'S shorty headers I have, needing his clearance dimensions. No response.
    19Eddy30 and X38 like this.
  27. BamaMav
    BamaMav
    from Berry, AL
    They fit like they were made for the car. I’ve seen those reports, but it doesn’t matter much on my car, it’s just a stock 5.0 roller cam motor. I figure it and an Explorer probably weigh about the same, so the performance would be about the same. If I had it all to do over, I’d raised the motor and transmission about 2” and used the Mustang shorties I had planned on to start with.
  28. PackardV8
    PackardV8
    As several have already correctly stated, with a full exhaust, all the way to the rear bumper of a street car, the small tube OEM manifolds will be just fine.
    OTOH, custom long tube headers with straight through mufflers bolted on the collectors and turndowns as short as possible, that's a street exhaust for some.
    (Reminds me of how that setup cost a guy a same day plane ticket home and almost a divorce. He put the race setup on his just-completed 496" BBC in his '55 Chev and took his wife on a 300-mile run to Cruisin' the Coast. The noise was a big-time-deal-breaker for her.)
    jack vines
