Projects My first crack at a traditional hot rod
Discussion in 'Traditional Hot Rods' started by Logan LeMaster, Aug 13, 2020.
  1. Austin kays
    Austin kays
    love your build but I cant help but notice you got 4x 750s in your cart! You aint gonna have no rubber rake!!
    redzula, Tim and Logan LeMaster like this.
  2. For sure there pricey, but can you really put a price on cool. lol
  3. Thanks! That was just a picture, I have not decided what would be appropriate for the front yet. Did get my rear reverse eye main leaf ordered. Still trying to get the brakes drums and wheel bearings sorted out before I order the rubber for the rear. The build has given me a little paralysis of the ****ysis for a minute. I finally decide to just get focused on the rear until its complete. Then going to start the front axle, think I have the parts I need. Probably either wire wheel my frame or have it blasted while I wait for parts to come in. Really don't know what the hell I'm doing but I suppose I will figure it out as I go.
    Outback and brEad like this.
  4. Austin kays
    Austin kays
    haha I get that man jus one project at a time and itll get there! Shoot maybe we could meet up one of these days and tool around in our hotrods looks like your jus a couple hours from me
    brEad likes this.
  5. That would be cool, I hadn't even noticed your kind of local! Yeah its been a slow start but I'm finally getting moving. Now its a matter of making sure I have the pieces and parts to keep moving.!
    Austin kays likes this.
  6. Jeff34
    Jeff34
    You could get some Blockley Crossply tires, but they only get to 6.50X16. But they're way cheaper
    I have them on my '29 roadster, and really like them...
    00-DboCy8WJYzQR_q_dc-F5BNadt25DzPkr_hjEv0s1JYq65Kf6rYHGj370sH4tB-5S4xJ2Twu75QF_jizMkB1ZdA.jpg
    aussie57wag, hfh, brEad and 3 others like this.
  7. Wow those look nice! Can’t wait to find me a roadster body!!
  8. I sure do like coming home to new hot rod parts! I got my reverse eye main spring from Millworks! This guys are a pleasure to deal with on the phone! Looking forward to my next order with them.
    Still trying to ****on up the rear end. I plan to call the early ford store next week to try and source some wheel cylinders and brake pads and springs to get the backing plates loaded up. I may even bite the bullet and order a pair of the firestones from Coker’s I’m really itching to get them mounted on my wheels.
  9. metlmunchr
    metlmunchr
    Spend a few bucks and have it blasted. All a wire wheel really does is sorta slick up the surface, but any rust you want to get rid of is still there. Clean blasted metal with a couple coats of epoxy primer will still be good 40 years from now.
    Logan LeMaster likes this.
  10. Hotroder95
    Hotroder95
    from Kansas
    Looks awesome man! Can’t wait to follow this build
  11. Thanks! I should be getting my rear spring back together over the weekend, and time to get the brake parts and wheel bearings and seals ordered. Its a slow build lol
  12. Yep called the guy just need to run it over and drop it off!
    Outback likes this.
  13. cederholm
    cederholm
    Digging this build!
  14. Thanks! its slow going but I'm about to turn up the heat. I'm planning to build my complete ch***is and running gear and hoping to upgrade my nice sedan body for a roadster body along the way. I have roadster fever bad!
    High test 63 likes this.
  15. dumprat
    dumprat
    from b.c.
    If your still looking at tires, compare 7.50 to 7.00-16. They are a touch shorter but a lot wider and have a better more original kind of look to them.
    They tend to be. A touch less expensive as well.
  16. The 7.00-16?
  17. dumprat
    dumprat
    from b.c.
    Yes. When I built my truck I wanted 7.00-16 rthaer than 7.50-16. I was pleasantly surprised when they were a little cheaper.
  18. I will be checking them out, plan to order next week or right after the first! Thanks for the tip.
  19. Quick update on how the build is going. Been busy with work and family and holidays like everyone else I’m sure.
    Noticed a set of 35 wire wheels for sale fairly local to me and the price seemed right. I really have no reason for another set but what can I say I’m a hoarder or at least starting to. I called the older gentleman a week ago and told him I’d like to take a look at them after the holidays if he still had them. Also put out a feeler with him looking for speed parts for my 8ba. He hinted around that he had a few things but sounded like they weren’t for sale.
    Fast forward to today and I decided to call and make the drive to grab the wheels. Showed up at his place which was a giant barn. Went in the shop and sure enough he had a decent looking set of wheels and for the price I was sure I was going to be packing them up. Notice he had an Edmund’s 2x2 intake sitting on a table so being curious I inquired if it was available, he said it was. To my surprise he also said he had a set of Fenton heads for an 8ba that he would part with. He disappeared into the barn and returned with a really nice set of heads.
    I’m not going to lie, I don’t know if Fenton heads have been repoped, hoping some one will chime in. I’m doing some research on that here tonight. We talked on price and I let him know that I was interested and would let him. Know in the next couple days. I did ask if he happened to have a Fenton 2x2 intake to match the heads and he didn’t say.
    So we finish up our conversation I strike a deal on the wheels and I load them up and leave. I probably hadn’t made it down the road 10 miles and my phone rings. It’s the nice gentleman calling to let me know that he had stumbled across a Fenton intake in his stuff lol.
    He was a very nice guy and easy to work with. I let him know I’d be in touch and would be back to take a look.
    So my question is are Fenton heads and intakes repoped? Thanks in advance for any advice! IMG_7402.jpeg
    aussie57wag, Outback, Jeff34 and 2 others like this.
  20. alchemy
    alchemy
    I’ve never seen any repop Fenton stuff. It was a low cost brand to begin with, and they made a lot of parts. Kinda silly to repro something that is still available.
    Outback and Logan LeMaster like this.
  21. Thanks just wanted to check, Looking to use vintage parts and don't want to buy something new.
  22. Dan from Oakland
    Dan from Oakland
    If ya buy your tires thru Summit, you will get free shipping. They sell all the Coker stuff.
  23. Awesome Tip! Thanks
  24. Austin kays
    Austin kays
    always check the heads over with a fine tooth comb look for any damage to the water p***ages or cracks in fins, ect,ect lots of guys with old heads think they are worth what a brand new set is and its easy to get burned on buying old flathead heads.
    Logan LeMaster and Outback like this.
  25. Crookshanks
    Crookshanks
    Tried buying mine through Summit and ended up on a wait for 6 months until they finally canceled the order.
  26. aussie57wag
    aussie57wag
    from australia
    Very cool build. Looking forward to seeing finished.
  27. New to me roadster to enjoy while my build drags on, lol
    hfh, Vic Walter, Outback and 3 others like this.
  28. cpldale
    cpldale
    from Naples, FL
    Always nice to have one to drive and one to work on! Enjoy
    P.S. Best to take pictures in the sun not the shade.
  29. The shade helps hide the imperfections, hahaha!
    Outback likes this.
  30. Got some tires and tubes ready to slide them on my wheels
