Projects Mid Life Crisis 62 Vette
Discussion in 'The Hokey Ass Message Board' started by squirrel, May 12, 2023.
  1. Almostdone
    Almostdone
    Looks like great fun.
    So how many participants on the West tour?
    John
  2. squirrel
    I don't know, there were a thousandish? or so?
    We made it home! yay.
  3. poco
    poco
    from oklahoma
  4. moparboy440
    moparboy440
    from Finland
    Were does one find a new points distributor for a SBC? Couldn't find a single one on google.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Truckdoctor Andy and moparboy440 like this.
  6. squirrel
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Two reviews one with ***** the other **. The two star buying complained that condenser went out in a week. Is that really a big surprise?
  8. Beanscoot
    Beanscoot
    How can that be? This is verbatim from the ad copy:
    "...original design weaknesses are identified and corrected, resulting in premium-quality, brand-new parts you can rely on."
  9. X-cpe
    X-cpe
    But, what it doesn't say is, what you can rely on the parts to do.
    Algoma56 likes this.
  10. squirrel
    Been working on the smaller replacement.
    And back to the clutch noise. I pulled the transmission again, and the clutch. Yeah, the bushing is shot!
    But it doesn't want to come out, it just laughed at my slide hammer, and it's giving the cape chisel a run for it's money.
  11. 57 Fargo
    57 Fargo
    The Lego ‘vette is super cool!
    I’ve taken to just cutting a slot through pilot bushings with a small carbide but in my die grinder.
  12. alchemy
    alchemy
    Have you ever used the peanut ****er removal method?
    SS327, y'sguy and 41 GMC K-18 like this.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    I tapped threads in one that wouldn't come out and made a plug that screwed into it with a grease fitting in it. then i used my grease gun to "hydraulic" it out
  14. 57 Fargo
    57 Fargo
  15. y'sguy
    y'sguy
    from Tulsa, OK
    Yep, the hydraulic method works.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    I want to know why it is worn out already?
  17. squirrel
  18. BJR
    BJR
    This time buy a bearing instead of a bushing.
    Deuces likes this.
  19. lumpy 63
    lumpy 63
    Jim was it gray or bronze looking? I got one recently that was gray in color and I put a magnet on it and it stuck:confused: It went directly in the trash.
  20. lumpy 63
    lumpy 63
    It's amazing the amount of **** products being sold nowadays
  21. tomcat11
    tomcat11
    That bushing is suspect. I'd replace it with a proper oil-lite bronze bushing. I've seen other folks use those roller bearings and they dried out from the heat, failed, and destroyed the input shaft.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    When I converted my 56 to manual trans I had a hard time stabbing trans despite using an alignment tool. Next thing odd was car rolled upon start up despite applying the clutch. Things got ok after next try at start up. Then a few month’s later the clutch would squeal. It was the pilot bushing. Changed it out and all good since the early 2000’s.
  23. squirrel
    I got the old bushing out. I'll do some magnet testing in the morning. I have two replacements, one looks grayish (in a new Dorman package), the other looks bronzish, I think it came from an old Dorman orange bin.
    The pilot on the input shaft looks ok, I polished it up again to be sure.
    I don't like the bearings because they eat up the input shaft whey they go.
  24. RodStRace
    RodStRace
  25. lumpy 63
    lumpy 63
    I agree Jim , I never use bearings .
    Moriarity, Truckdoctor Andy and Thor1 like this.
  26. squirrel
    I don't think it's an alignment issue.
    Oh....remember those pesky leaking rear wheel bearing seals on my Drag Week trip? One of the new replacements is leaking now.
    Fun
  27. TrailerTrashToo
    TrailerTrashToo
    I had that problem on a Ford 9 Inch axle. The vent bolt was not drilled all the way through. Check that your vent is clear.
    Russ
  28. 57 Fargo
    57 Fargo
    I used a bearing in the Barracuda, almost all the oem stuff is roller bearings and unless you sit with your foot on the clutch, in gear, it’s not really a factor, although I suppose the lack of turning may be equally as bad for it…
  29. bobss396
    bobss396
    I made up a couple of bushings during my machine shop days, I should have made a bunch. I used the last one around 1984. I always put a good radius on the entry side and used a small amount of Lubriplate when I installed them.
  30. porkshop
    porkshop
    from Clovis Ca
    I have seen this happen, when the block has been line bored. Needed to get offset dowels to correct it.
    Driver50x and Tow Truck Tom like this.
