Technical Homebuilt quickchange
Discussion in 'The Hokey Ass Message Board' started by Jethro, Sep 10, 2012.
  1. Genus, Very very nice.
  2. 2Blue2
    2Blue2
    This thread is really neat.
    Carry on!
  3. Just checking in on the progress. Very cool.
  4. coreythompsonhm
    coreythompsonhm
  5. Jethro
    Jethro
    This is the latest version
    I had a banjo all machined and ready to be ***embled. I ordered a closed drive QC shaft kit from Hotrod Works and welded and machined the banjo housing. This one is going in the General this winter.
    20231114_105757.jpg 20231114_105805.jpg 20231114_105820.jpg 20231114_105834.jpg 20231114_105937.jpg
    treb11, brEad, osage orange and 5 others like this.
  6. @Jethro do you have the ability to machine a blank case? I have a 201 that was cast but never machined so I am looking for someone to machine for me so I can put 36 bells etc into it.
  7. Jethro
    Jethro
    I could probably do it , but transporting it would be prohibitive.
    I bet Steve (elpolako) at IndustrialCh***is could do it or would know who could.
    I think the trick would be getting the width right so you get the proper preload and backlash on the ring gear.
  8. Steve is no longer doing Industrial Ch***is. He still owns the name and product lines but now has a regular 9-5 job with benefits. All I need to have done is the case machined for the axle bells and internals. Here is some pics of what I have. IMG_5931.jpeg IMG_5930.jpeg IMG_5929.jpeg IMG_5928.jpeg
    tractorguy, Outback and Okie Pete like this.
  9. Jethro
    Jethro
    Is that aluminum or magnesium?
    I think any competent machine shop with a rotary table could do it. Like everything else small shops are harder to find because of cnc production shops.
  10. Pretty sure it magnesium.
    Outback likes this.
  11. Jethro
    Jethro
    Yeah , that might be a little out of my ability. If it was just drilling and tapping a few holes maybe but finishing the bearing bores would be tricky especially without a blueprint.
    Outback likes this.
  12. alchemy
    alchemy
    Ron, to make sure it turns out square, you will need extensive fixturing on top of somebody with a bit of talent and a machine to perform it. We started out with a case that already had the main sides cut and drilled, and the pinion bore completed. And we still had many hours in CNC setup and hundreds in steel for the fixtures. Yours will be more than twice the work we went through. It will be more expensive than just buying a good Halibrand case that’s ready to go.
    tractorguy and Okie Pete like this.
  13. DDDenny
    Ron, as alchemy posted.............
    You might want to study a finished QC, you will see somewhat more work involved than you mentioned.
    Also, if you've never had machine work done, keep in mind there will be a setup charge, especially if the chosen shop doesn't normally do this kind of work.
  14. Outback likes this.
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    @Hot Rod Ron,
    My friend says that finishing his QCs is way down the list of things he needs to do. He also said he would be hesitant to do one for anyone else. Too many chances for errors and comebacks.
    Have you talked to Hot Rod Works about finishing the castings for you? Don't know if they would be interested, but they have the ability.
  16. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
  17. Jethro
    Jethro
    So , the General has his new Bell Speed(tm) QC center section. I wish it was nicer weather so I could take it for a spin. 20231219_111852.jpg 20231219_111915.jpg 20231219_111930.jpg
  18. patsurf
    patsurf
  19. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    That is some FINE WORK, right there!
    brEad likes this.
  20. Jethro
    Jethro
    Thank you , that means a lot.
    When I first had the idea of making a QC I read as much as I could and poached alot of information from people like yourself.
    From where I started to where I am now I can honestly say that I've learned a bunch. It's been fun making something like this and driving down the road with it.
    Outback, HemiDeuce, brEad and 3 others like this.
  21. Outback
    Outback
    from NE Vic, Oz
    Just re-found this thread - @Jethro what a great job, it must be very rewarding! How's it going 9 months on? Birthing another? :cool:
  22. Jethro
    Jethro
    Thanks @Outback ! I've put a couple thousand miles and got it salty at speed week at Bonneville. It's been a ton of fun ! It took a few trips to get used to the whine but now it's just part of the experience. It's no worse than an old truck with straight cut gears in the gearbox.
    I have another in the works for the 28 RPU I am working on.
    It's been a very satisfying project!
    brEad, GuyW, Outback and 3 others like this.
  23. patsurf
    patsurf
    so--do you now have jigs for everything and can just cut an ***embly out(sounds easy doesn't it?) and start welding etc.?
    brEad likes this.
  24. Jethro
    Jethro
    I have some jigs , and notes to help when I start cutting a housing. I don't do it every day so it feels like I have to relearn every time I start a new rear end. With each one I do I find little ways to improve.
  25. patsurf
    patsurf
    as everyone has said--killer work!!--makes me think of an old hrm article on a guy making a 57 chev diff into one!
  26. DDDenny
    I remember an early Corvette article.
