Anyone ever see/have a Holley 3 barrel carb?
Discussion in 'The Hokey Ass Message Board' started by Groucho, Jun 19, 2007.
  1. lemondana
    lemondana
    from Lincoln NE
    Thanks! I think the Ball Stud Hemi was slated to use the Carter Thermoquad.
    Deuces likes this.
  2. 73RR
    73RR
    ...favorite pastime of old guys...:D
    lemondana and Deuces like this.
  3. Elcohaulic
    Elcohaulic
    I was just reading about this in a Hot Rod Feb 1967 magazine..
    Deuces likes this.
  4. the SCROUNGER
    the SCROUNGER
    from USA
    old thread, worth reviving...per old ads posted previous in this thread-
    it was the DOMINATOR carbs that Ford contracted to Holley to develop, for the NASCAR BOSS 429, in the late 1960's. By 1970 Holley had released them for sale to the entire performance market, for all makes.
    the previous Holley 3150/3160 three-barrel in 950cfm (4 booster venturis) and 1050cfm (secondary discharge tubes like Qjet, Thermoquad) was first developed and used in 1964 July 4 NASCAR race for the 426 HEMI....
    however, I'd yet to actually SEE a model "3150" which technically should have metering blocks on both front and back bowls. I HAVE seen mechanical linkage secondaries, extended accelerator pump discharge squirters on secondaries, on Ebay Holley 3-barrel carbs.
    the 3-barrels ran quite good for their time. there was a 1970 Olds 442 W-30 on Ebay, with story about how he bought an intake, 3-barrel, raced it for years, ran mid-high 12's bone stock, cam, heads, no porting, Muncie close ratio, full interior, factory weight.
    That's banging on 4000 lb. w/driver.
    RmK57 and Deuces like this.
  5. the SCROUNGER
    the SCROUNGER
    from USA
    950=4 downlegs
    1050=secondary discharge tubes
    Deuces and egads like this.
  6. uncleandy 65
    uncleandy 65
    Best carb I ever ran, Had them on my stock car and drag car.
  7. Deuces
    Deuces
    It's great to see this thread again.....:D:)
    lemondana and egads like this.
  8. the SCROUNGER
    the SCROUNGER
    from USA
    that's what a 3150 "should" look like, because the "-50" suffix is supposed to mean, dual metering blocks, no metering plate on secondaries.
  9. jimmy six
    jimmy six
    A good friend had a 950 3 barrel on a 455 Olds jet boat. It was only a 15-1/2’ which a lot of guys he raced never figured out. It was always fast but with the 950 was much better.
    Deuces likes this.
  10. gary macdonald
    gary macdonald
    I had one in a 1400 lb T bucket , chevy counter part LT-1 ( 1970 ) tarantula intake , turbo 400 . Loved it , want another . Still have the car . I could just neutral drop it and leave in second gear , it would shiftfrom 1-2 at about 5500 rpm , when the third barrel opened it was like a nitrous hit . Of course this was 1973 and I was 17 so ...
    Elcohaulic and Deuces like this.
  11. carbking
    carbking
    There seems to be some confusion on model types:
    Holley 3150 (CFM not specified) List number 3680
    Holley 3160 (950 CFM) List number 3085
    Holley 3160 (950 CFM) List number 3916
    Holley 3160 (1050 CFM) List number 4604
    Have been sold out for decades, but had several 3916 and 4604 units. Don't remember ever having a 3085 or 3680.
    Jon
    Deuces and Fordors like this.
  12. Greetings could u share some photos ? Thank u
  13. I am if
    I am if u still have it
    Thanks !!
  14. Can I p
    Can I pay u to mail me a copy of this ?
    Thanks Chris
  15. DDDenny
    George has been AWL for over five years.
    Deuces likes this.
  16. Russ B
    Russ B
    Just saw this thread; I had a 950 Holly 3 barrel sometime around 1967, but I never did use it
    Deuces likes this.
  17. Deuces
    Deuces
    :(:rolleyes:
    egads likes this.
  18. willys36
    willys36
    I used a spacer on my Hemi manifold. I modified a CI 354 manifold for my long-bell 331 engine. I bored the engine 1/8" over and used 354 pistons to convert it to the larger displacement.
    Here are photos of how I modified it.
    I bored out the ports on the stock manifold using an adaptor as a guide.
    I cut the web out of the adaptor to accommodate the oval plate.
    loudbang and Deuces like this.
  19. 73RR
    73RR
    I ended up sending my last 3 950's down to OZ but kept the last 1050 as a reminder of younger days...those were the days my friends....
  20. In_The_Pink
    In_The_Pink
  21. seb fontana
    seb fontana
    from ct
    Sorry gone a while ago. Not sure if I still have the 3-barrel carb or not.
  22. chinarus
    chinarus
    from Georgia
    Found this old thread - have a new question.
    Anyone have experience with this modern Holley 3 two barrel SBC 350 setup ??
    Specs say a HEI distributor is too large.
    Deuces likes this.
  23. 427 sleeper
    427 sleeper
    The spec's are right!
    gimpyshotrods likes this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    Blessing in disguise. HEI’s are ugly anyway
  25. willys36
    willys36
    h
    Here is how I modified my cast iron hemi manifold to accept the 3bbl. Had to bore the holes larger too but makes a great combo. carb spacer gives me the necessary clearance for the secondary plate. Maybe that is what they did for that Carter manifold too? Chrysler was deep into the science of intake manifold design in the 50s.
    Deuces, 427 sleeper and Moriarity like this.
  26. seb fontana
    seb fontana
    from ct
    My 950 3-barrel went to Rex for his project X clone a few months ago.:)
  27. 1971BB427
    1971BB427
    from Oregon
    Wont accept an HEI, but also wont work if your car has a later 700R4 trans. I was ready to pop when these first hit the marketplace, but Holley told me they didn't offer an adapter bracket to use these on a 700R4, and I needed that.
  28. chinarus
    chinarus
    from Georgia
    Whats the issue with a 700R4 ? Control box not take care of it?
  29. 427 sleeper
    427 sleeper
    700r4's need a t/v cable to operate. 4L60e's have a controller.
  30. chinarus
    chinarus
    from Georgia
    Found thi Holley 700R TV Cable Kit.JPG s Holley TV cable adapter kit - can it be made to work?
