Hot Rods Getting Over Fear of Cutting up Parts/Making Mistakes
Discussion in 'The Hokey Ass Message Board' started by Auggie Dawgie, Dec 20, 2023.
  1. JD Miller
    JD Miller
    :D
    Sharpone likes this.
  2. gimpyshotrods
    gimpyshotrods
    Can confirm.
  3. gimpyshotrods
    gimpyshotrods
    You would need a WIG welder and a FIG welder!
  4. DDDenny
    And be a qualified weldor to operate those welders!
  5. Dave G in Gansevoort
    from Upstate NY
    The instructor covered oxy/fuel, stick, mig and tig all those decades ago. He never covered wig and fig! I was never exposed to either. And how do you get filler rod or wire in some of the more esoteric woods like mahogany or ipe? Then I also have a question about the shielding gas: helium, argon, a mixture? And let's not forget about composites. Carbon/carbon fiber...
    Okay I'll stop now
    X-cpe, Auggie Dawgie and Sharpone like this.
  6. mohr hp
    mohr hp
    from Georgia
    IMG_0611.png IMG_0610.png Go find a damaged aluminum radiator and practice on that., I found 2 freebies at an airport tug shop. I used them to make a weird shaped coolant expansion tank.
    Auggie Dawgie, Just Gary and Sharpone like this.
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    One thing here.....I would not use a torch to preheat on a radiator as you may cause the solder to melt if you get too warm. Since what you need to weld on the radiator are mounting brackets, a lot depends on their location. Making tack/very short welds and letting it cool will keep the heat from spreading out. Just get a couple similar thickness aluminum plates and try it on them . Also place your ground clamp somewhere near the point of the weld so current is not flowing thru soldered joints. Maybe a small clamp that the ground can attach to.
    Auggie Dawgie, big duece and Sharpone like this.
  8. bangngears
    bangngears
    from ofallon mo
    I can teach mig welding in one sentence and your ready to weld. If you blow a hole, turn it down. If it pops and looks bad, turn it up. We are done. Good luck.
  9. i7083
    i7083
    I got really hung up on making my front shock mounts match, and they did. Both for the left side.
    Don't over-think it, just think it over.
  10. Auggie Dawgie
    Auggie Dawgie
    from New Jersey
    IMG_0202.jpeg This is the radiator I am talking about. It looked welded to me, but maybe be soldered somewhere on the inside. Since my car is channeled it sits too high. I just have to cut and reweld those brackets 1-2” higher on that bottom part.
    SS327 and Sharpone like this.
  11. The37Kid
    The37Kid
    Have you thought of fabricating brackets that would bolt onto the the lower bracket? Anneal the bracket that is there and fold it up after the new bracket is made.
    alanp561, rod1 and Sharpone like this.
  12. ekimneirbo
    ekimneirbo
    from Brooks Ky
    The tubes in the radiator are soldered in place. The outside frame is welded. Welding aluminum requires more heat input because aluminum disipates heat more quickly. If you concentrate the heat in a small area reasonably quickly, it has less chance to spread. So if you apply a "tack" with a MIG type of set up, it doesn't have time to spread. A TIG can control heat well for doing short welds and then letting it cool. The trick is getting it clean with a stainless wire brush and then being able to realize when it becomes molten. With a Mig you just have to get it set right before you apply the weld so that it doesn't blow thru, so find what setting works on some similar thickness aluminum pieces. Don't set them flat on a steel table, as the table will absorb heat and your setting will be too high when you do the radiator. Being its an expensive radiator, I'd probably recommend finding a good welder to Tig it for you. Probably $50-$75 if you have the brackets ready to fit up. Then practice Tig/Alum on some s**** stuff.
  13. goldmountain
    goldmountain
    I remember the fear of cutting up parts back when I was a lot younger. It was 1974 and I had just seen "American Graffiti". I cut the top off my friend's deuce 5 window. Definitely a moment of did I mess up? Well, yes I did.
  14. NealinCA
    NealinCA
    I read this quote from Lil' John ****era in Hot Rod magazine in the early 1980's and it has stuck with me.
    "Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before."
    Many times I will build a simple part but add some twist to it to try something new. The process may not have been needed to make that part, but now I have a new skill for when it is really needed.
    alanp561, Graham08, 2deuces64 and 9 others like this.
  15. DDDenny
    I can't quote it verbatim but Johns' answer when someone asked him how a certain part was made, he said something like "I just removed metal until it looked like the part I wanted".
  16. lostone
    lostone
    from kansas
    I've been there too...
    I'll try some new ways to try and work sheet metal, like bumping, stretching etc, then shrinking etc then once I have it all screwed up I'll start again.
    Sometimes this doesn't work then at that point I go back to what I do know and work from there. Sometimes with a new piece and sometimes with the piece I started with.
    Either way I learn something along the way, things like when to stop and do something different or when to change methods and keep going.
    It's all a lesson, a learning curve, feel-sight gets better, methods get better so the end product gets better.
    So it just all boils down to one thing, "if you ain't trying, you ain't learning" that's the way I see it....
  17. Sharpone
    Sharpone
    I agree , I would hire it done, looks like it would be easy to totally screw up at which point you’d have to pay $$s to fix or buy a new radiator either way a fair amount of money wasted maybe. In the mean time practice practice practice so next time you would have the skills and confidence to tackle such a task.
    Dan
    ekimneirbo and Auggie Dawgie like this.
  18. NealinCA
    NealinCA
    From another thread on the HAMB...
    The late Gray Baskerville once asked ****era how he could make a rear view mirror out of a solid block of aluminum to which ****era replied "That's easy, just cut away everything that doesn't look like a rear view mirror."
  19. DDDenny
    I do believe that's it!
    alanp561, SS327 and Sharpone like this.
  20. The37Kid
    The37Kid
    I know it is another era of Hot Rodding but was John ****era the "inventor" of CNC billet wheels and that whole era of aluminum?
  21. blue 49
    blue 49
    from Iowa
    ^^^^ Seems to me he started with a "Strong Arm Milling Machine". (A saw and a set of files)
    Gary
    Sharpone and The37Kid like this.
  22. The37Kid
    The37Kid
    At one time he had a Bridgeport in his livingroom.
    alanp561, gimpyshotrods and Sharpone like this.
  23. LWEL9226
    LWEL9226
    from So. Oregon
    My dad was a carpenter also and I am sure he has turned over more than a few times.....
    LynnW
  24. Happydaze
    Happydaze
    At Dan Fink Metalworks there is, or certainly used to be, an aloominum b*llet, circa 24x18x6, that was an aborted wishbone of Li'l John, now just a large paperweight.
    Chris
  25. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Sounds like someone I would have liked to know...............:)
    alanp561 and Sharpone like this.
  26. Well coming from a guy that jumped into a hot rod project 20 years ago with no idea how to do it, I can say with confidence that it's ok to do things a few times over. I mean I butchered a Model A frame so badly that I drove to Los Angeles and back in a day just to get another one with good numbers. Fortunately the first one went to some much more capable hands at the time and still lives on as well. You'll be fine, the first cut is the hardest.
  27. alanp561
    alanp561
    That's two sentences! Bet you were a pipefitter, huh? ;)
  28. Adriatic Machine
    Adriatic Machine
    Mock it up, critique it. Remember it is only metal and most mistakes are recoverable
  29. jerry rigged
    jerry rigged
    A hard lesson for me to learn was "don't let Perfect become the enemy of Good". Otherwise nothing ever gets done.
    57 Fargo, Auggie Dawgie and Sharpone like this.
  30. rocsas
    rocsas
    from colorado
    Sometimes you just have to go for it, I was nervous as hell starting this 1951 ford, but the more you go the more comfortable you get with it.
    Seeing the end product is more rewarding then any bolt on part for sure. Yea cutting up an expensive part is hard but just take your time and measure 40 times before a cut and be careful, that will minimize any mistakes.
    Even if you cut something or it doesn't go right, sometimes the best way of learning, is by making mistakes
    FB_IMG_1685684240237.jpg FB_IMG_1685684249567.jpg FB_IMG_1685684233075.jpg FB_IMG_1685684259582.jpg FB_IMG_1685684293257.jpg 20231216_142416.jpg
    Auggie Dawgie, Sharpone and alanp561 like this.
