Technical 1936 Touring sedan to coupe?
Discussion in 'Traditional Hot Rods' started by Hoosierhauler, Oct 5, 2021.
  1. Hoosierhauler
    Hoosierhauler
    from Gaston IN
    I know there’s some builds out there where this has been done but I had zero luck with the search option. (Probably my errors)
    I have a 36 ford four door sedan parts car that I believe is considered a touring sedan. While looking over the car and what was left of it with my son it appeared to me that a coupe conversion looked like it wouldn’t be to hard to do. After mentioning it to a few friends about it they said it used to be a common thing??? Anyone know of any one who has done this?
    These are the only pics I have of the car currently, it gave up its drivetrain for my 35 two door sedan that I’m building. The bottoms of the 36 is absolutely rotted away, the floors, frame, etc are all gone.
    Nailhead A-V8 likes this.
  2. You would need the back half of a coupe to do it, or at least all the sheet metal.
    are the front doors the same length ?
    I believe the frames and wheel base are the same through all models .
    you could make it a two door and get rid of the rear vent window in the process .
    or just leave it a 4 door, still a cool car .
  3. If it was easy it would be a common thing. Fordoor to coupe conversion can,t be easy or common. How about a coupe-ute ? Slab sides and a tailgate would be easier. Cheaper than importing one from Australia.
    EVL401, Pist-n-Broke, hfh and 6 others like this.
  4. Stan Back
    Stan Back
    . . . plus you could use the back doors to extend the front ones to change the proportions and maybe do away with the quarter windows.
  5. harpo1313
    harpo1313
    from wareham,ma
    Or a sedan delivery with a bustle. would be a head scratcher.
    Tman and VANDENPLAS like this.
  6. Squablow
    Squablow
    Hell yes. I wouldn't say it's ever been common but it can be done and it has been done. You can buy the tail pan below the deck lid brand new, would be helpful to have a coupe trunklid too although you could make one. Cut the back of the roof off and slide it forward to meet the back of the front doors, fill in the quarters with the back door lower skins. The tops of the rear quarters will require a fair amount of fab work but once you've got that you're golden.
    EVL401, Nailhead A-V8, Stogy and 4 others like this.
  7. Hoosierhauler
    Hoosierhauler
    from Gaston IN
    She’s definitely not continuing on as a four door, if I have to do this much work to it she’s loosing some doors lol.
    Stogy, kidcampbell71 and Tman like this.
  8. Squablow
    Squablow
    Not really all that different to this '33 I did, although the '33 needed more reshaping of the quarter window area and the B pillars were taller (never did get that far, sold it before working out the B pillar height). Made the trunklid off of measurements, filled in whatever gaps were left. It's not easy, but it definitely can be done.
  9. Hoosierhauler
    Hoosierhauler
    from Gaston IN
    Squablow thanks for photoshop!
    That’s exactly what I was thinking!
    Your work looks awesome as well.
    Stogy and Squablow like this.
  10. I don’t have a ton of computer skills, but I do my searches from google and include the words the hamb, works most times.
    Stogy likes this.
  11. goldmountain
    goldmountain
    There was that Norwegian build done somewhere on the Hamb. Can't remember the name of that thread however.
    Stogy likes this.
  12. Squablow
    Squablow
  13. Squablow
    Squablow
  14. roger didonato
    roger didonato
    I have a 36 5w roof if interested. I am also restoring a 36 ute coupe. look at some pictures of them. It may be easier. I have a set of bead dies to continue the belt line on the 1/4 panel from the door to the tail gate.
    kidcampbell71 and Hoosierhauler like this.
  15. Hoosierhauler
    Hoosierhauler
    from Gaston IN
    Roger I would just use the sedan roof since I would be using its doors and not coupe doors.
  16. alchemy
    alchemy
    5 window doors should be the same length as fordor doors. Might be a slight difference in height above the belt line. But that would be corrected when you chop the top. Using a real coupe roof would be a huge head start.
    kidcampbell71 likes this.
  17. brigrat
    brigrat
    from Wa.St.
    I have some of this 4 sale!
  18. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Brigrat;
    Did you build that? Very nice. Thread?
    TIA.
    Marcus...
  19. brigrat
    brigrat
    from Wa.St.
    I wish, a guy up here in the Kent Wa. area, Danny Pascoe, built it with simple hand tools, I only needed a portion of it for my roadster but had to buy the hole thing...................
    Wurger and kidcampbell71 like this.
  20. Happydaze
    Happydaze
    If I were brave enough to contemplate such a task, I think I'd be looking to try to convert to a 3w instead of a 5w, from a desirability / rarity / even value perspective. Must be less work too - 2 less windows!
    Chris
    Blower371 likes this.
  21. Ron Plumlee
    Ron Plumlee
  22. Ron Plumlee
    Ron Plumlee
    Maybe make a "Coudan" like I did, out of a four door sedan body. Some day I will post the build on here, but no donor car needed, just shorten it, use front of front doors and rear of rear doors, start pie cutting the top, and you have a shorty sedan, heck everybody has a coupe, but a coudan!
    kidcampbell71, Jrs50 and Stan Back like this.
  23. Nailhead A-V8
    Nailhead A-V8
    I think your car just got built! like @Squablow said you can use your sedan stuff for the roof and to fill in the missing bits @brigrat doesn't have...check out a youtuber called Bad Chad I don't always agree with his methods but results are what counts. He just joined a '36 4 dr. front section to the rear roof panels by adding a wedge shape to the door pillar simple and it looks great, he also chopped a '36 sedan lakes style that uses the stock height windshield leaned back radically...
  24. 34 5W Paul
    34 5W Paul
    from Fresno CA
    Somewhere on here this got started but not finished (maybe that's your real answer) by some extraordinarily talented dude in Europe.
    Started with this ***y beast 11536096_416588258513477_8220777699391902379_n.jpg
    Then did these careful drawings...
    Started cutting...steady...steady...
    Partial re***embly
    Then the big cuts
    That back section seems to slide right into place
    Just ready for a big *** bustle.
    That's where the thread went dead and I was bummed. Now, huge thanks and respect to the Norwegian Blacksmith, we can see the idea completed.
  25. X38
    X38
    Looks like a really well executed job. Would love to see the result.
    34 5W Paul and Stan Back like this.
  26. He will finish it for sure !
    Sometimes life makes plans a bit delayed :confused:
    Squablow, winduptoy and 34 5W Paul like this.
  27. Looking to build a 36 Ford Coupe
  28. hooliganshotrods
    hooliganshotrods
    Anyone have a link to this thread for the 5 window conversion?? I searched and looked but can't find it.............
  29. Pass The Torch
    Pass The Torch
    I have a '35 that I considered making into a delivery; Haven't busted out the sawzall just yet (and it is currently for sale...).
