Technical Stick welders, help me out please
Discussion in 'The Hokey Ass Message Board' started by Budget36, Dec 23, 2023.
  1. KenC
    KenC
    I've had a Mig for 30+ years, cheapie from Italy. But a good cheapie, claims to be 140A, uses a 20A 120v circuit as it has the 20A plug. The name escapes me right now, but that brand was purchased by Lincoln and is now their low end product. But, I only use it for thin stuff as I prefer my stick machine, an even older AC-DC machine with the sliding, no stops, amperage adjustment. Before that I had the normal AC tombstone. Once I tried the DC side, I don't think I've ever gone back to AC, except to use high amps to cut some heavy s****.
    With it and 7014 I can finally make welds that look presentable! At least when horizontal. Even 6011 doesn't look too bad and sticking is minimized at least. I've adopted a drag/lift start movement that seems to work better than just tap/lift.
    I'm no welder and need all the help I can get and DC seems to help a lot
  2. Fortunateson
    Fortunateson
    Is it a Cebora?
    seb fontana and Sharpone like this.
  3. Marty Strode
    Marty Strode
    I have had a Tig for 51 years, and a Mig for 45. My Lincoln 300, has always had a stinger hanging on it. I recreated a ch***is for a Belly Tank that was built in 52, a while back, and stick welded it for correctness. I was able to give lessons to a young friend, who had never stick welded before. IMG_6816.JPG IMG_6823.JPG IMG_6850.JPG
  4. Dave G in Gansevoort
    from Upstate NY
    Not a recommended practice, however in a pinch I was shown this trick by an old pipeline welder. Your rod is wet, you're out in the middle of nowhere, and the job has to get finished. Oh, and there's no way you're going to get frexh rod in time. What do you do?
    Stick the rod on purpose to ground, no arc. Watch it doesn't get red hot, and it will "bake" out the moisture. It's a timing kind of thing. You need to let it get hot enough to evaporate the moisture, seen as steam coming off the rod, but not damage the flux.
    Like I said, not recommended, but in that pinch...
    Rex_A_Lott, das858, Sharpone and 2 others like this.
  5. Budget36
    Budget36
    Well, I must be practicing that technique several times while arc welding;)
    Sharpone likes this.
  6. twenty8
    twenty8
    This is why it can be a downward spiral with the inexperienced. Too much heat generated in the rod from constantly sticking it to the work piece, which degenerates the rod and can cause it to stick more....... and around and around we go....
    alanp561, Sharpone and Budget36 like this.
  7. Voodoojaime
    Voodoojaime
    Use 7018. Stronger than 6010. But make sure your gaps are pretty tight.
  8. Dave G in Gansevoort
    from Upstate NY
    Like I said, not recommended...
    Also, in context, in a situation where the job has to be done, we do whatever it takes.
    I don't stick weld much these days. And I wonder how many of us keep our mig wire dry. I tend to buy small spools so it doesn't rust, as I can go a couple of months without welding anything. Thank god for tig. I can keep that rod dry...
  9. warbird1
    warbird1
    Since I started stick welding 60 years if I get anything that is "out of position" and absolutely, positively has to be a good weld I'll go with 7018 and plug the stinger into my Lincoln tig machine on DC. Anything else I'll go back to tig or mig. I've had a couple of AC buzz boxes over the years and did a lot of welding with 7018 AC with good results.
  10. bobss396
    bobss396
    7018 was a recent revelation for me. In HS and in a college welding course, it was 6011 (snap, crackle & pop) all the way.
    In college I did required practice welds that were handed in and graded, for those who struggled. I guaranteed them a B grade in exchange for a pitcher of beer at the campus bar.. a whole $2.50 value...
    warbird1, Budget36 and Sharpone like this.
  11. alanp561
    alanp561
    And this is why Boilermakers have a drink named after them. Alcohol calms the nerves, steadies the hands and allows one to make picture perfect welds using 3 or more mirrors with 100 % penetration every time;). You must have been coached by a pipefighter:rolleyes:.
  12. revjimk
    revjimk
    from Denver
    Thanks... but my question was whether you could build a safe ch***is welding downhill... I'm guessing no?
    Budget36, alanp561 and Sharpone like this.
  13. Petejoe
    Petejoe
    from Zoar, Ohio
    Welding down hill is really only safe for thin gauge material.
    Welding down hill on a strength required application is unsafe. It will trap slag, cause cold lap and not add enough material for proper strength. Any weld at its throat should at least be as thick as the parent material.
  14. alanp561
    alanp561
    What you said is what I should have said instead of trying to impress him with something unrelated to what he asked. Dammit:(
  15. Sharpone
    Sharpone
    Budget 36
    Thanks for the Thread
    Saw some cool pics and learned a bunch.
    Did you get your project welded up?
    Dan
    Budget36 likes this.
  16. Budget36
    Budget36
    Not yet, going to make some strides on it today. I’ve been getting some great info from @alanp561 I hope to put to practice this afternoon.
  17. Sharpone
    Sharpone
    We’ll like the commercial says “Your in good hands”
  18. saltflats
    saltflats
    from Missouri
    I seen a stick welding rod laying in the parking lot at Menards today, I didn't pick it up as it has been snowing.
    Sharpone and alanp561 like this.
  19. gene-koning
    gene-koning
    A few months ago I was cleaning up a cabinet I'm getting rid of that was in my old welding shop. Way back in the corner of the bottom shelf was a plastic box of stick welding rod that has never been opened. I'd have to look at it to be sure which rod it is, but I'm betting that box is nearly 20 years old. The box has been on the shelf in the mostly closed up steel cabinet, in my basically dry shop (heated in the winter, garage door open in the summer). I have 10 year old sheet metal in here with almost no surface rust on it. I wonder if that box of rod would be any good?
    LWEL9226, Sharpone and Budget36 like this.
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    I'd use it , but then again , I'll use anything " usable" . 40+ years ago a guy gave me a new can of a eutectic SS rod , , I've used it for various projects over the years , welds look god , haven't failed , I'll keep using it !
  21. Joe H
    Joe H
    I did some welding with one of these, Sears carbon Arc welder. Welded a lot of exhaust pipes and some fenders on my race car. Dad was pretty good with holding the arc just right in one hand and the rod in the other. I couldn't get the arc to stay steady, so I used the arc welder portion.[​IMG][​IMG]
  22. Dave G in Gansevoort
    from Upstate NY
    Oh man, remember all of the different versions of that sold in the back of all of the magazines? For something like $29.95+s&h? I always wondered if they actually worked. Now I know...
  23. Joe H
    Joe H
    The arc welding rods were something like 1/16" diameter, I went through a ton of them welding pipes together, then went really fast!
  24. Sharpone
    Sharpone
    I had a box to yours. I could weld ok with it , was really terrible if I used any thing other than a 12 gauge extension cord I’m guessing anything other than 12 gauge caused enough voltage drop to cause problems with the arc. The welding I did with it was probably marginal at best, a pro would’ve done better I’m sure. I think I payed $90 for it, did what I needed at the time - welding up leaks on an underground water line ,I’m positive that old water line was/is HAMB appropriate lol
    Dan
  25. warbird1
    warbird1
    One of these was a Christmas present from my first wife in 1969. Finally threw it out when I moved 11 years ago. Those 1/16" rods burned real fast...
  26. Marty Strode
    Marty Strode
    I have this 110 welder, probably from the 30's-40's. It is wood framed, with a Masonite front panel. I tried it out, and it still works. I still have a stash of stick rods of all sizes and strength from the 70's, kept close to the furnace, and they always weld just fine. IMG_0648.JPG IMG_0649.JPG
    GuyW, Sharpone and Budget36 like this.
  27. alanp561
    alanp561
    It would depend on how it was sealed. Is it airtight? If so, I'd throw it in the oven at 250 degrees for four hours and use it without thinking a thing about it.
  28. alanp561
    alanp561
    @Budget36, still waiting for those pictures. I don't know about these other guys, but I promise I won't laugh, honest;).
  29. Budget36
    Budget36
    lol. Weather moved in for a bit on Saturday, and just too much muck to deal with out back.
    But I have a plan, kinda, I think. Well maybe…
  30. alanp561
    alanp561
    Happydaze, GuyW, carolinakid and 2 others like this.
