Hot Rods 9" third member
Discussion in 'The Hokey Ass Message Board' started by bangngears, Dec 27, 2023.
  1. bangngears
    bangngears
    from ofallon mo
    I am thinking of buying a 28 spline posi third member from Speedway. Any comments pro or con? I do not want a whiny rear third member.
  2. gimpyshotrods
    gimpyshotrods
    Gear noise, in my experience, is largely a factor of how well the pinion depth and backlash is set up.
    That is a Human Resources issue, rather than a parts one.
    Que the guys that are going to tell you that you will surely die if you don't run 31-spline axles (or larger).
  3. saltflats
    saltflats
    from Missouri
    I would check with quick performance.
  4. primopro
    primopro
    from Corona, CA
    X2 with quick performance suggestion. They will build you whatever you want, reasonable prices and easy to deal with. I would definitely suggest upgrading to the hard plastic diff case for shipping protection.
    lumpy 63 and Just.dale like this.
  5. deathrowdave
    deathrowdave
    from NKy
    If the mechanic can not set up a 9 I’m not to whine with new gears , I think he is never goin to make full pay grade
  6. saltracer219
    saltracer219
    The O.E. Ford gear sets usually pattern nicely and are quiet. I understand that the aftermarket ring and pinion sets available these days are notorious for being noisey but I have no first hand experience with them.
    finn and Desoto291Hemi like this.
  7. saltflats
    saltflats
    from Missouri
    It can be a **** shoot sometimes.
    seb fontana likes this.
  8. Just.dale
    Just.dale
    Great experience with Quick Performance also!!
  9. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I got my latest 9 inch center from Quick Performance. Reasonable price, Quick service, Runs quiet. They do have one little gimmick I fell for. When I ordered they told me it would be 6-8 weeks but for an additional fee of how much I forget I could have it in a week. I needed it to complete a project so I bit. If your in no hurry they're an excellent source for a 9 inch center.
    lumpy 63 likes this.
  10. RmK57
    RmK57
    Find out where Speedway sources their diffs from, it could be from Quick Performance.
  11. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I've used quite a few 9 inch Speedway centers in customer ch***is and they are built in Lincoln NE.
    RICH B and loudbang like this.
  12. da34guy
    da34guy
    X 5, 6 or 7 Quick Performance for the win
  13. chevyfordman
    chevyfordman
    Definitely not SpeedMasters in California.
  14. bobss396
    bobss396
    Mine is from QP as well, 28 spline since my axles were fine. AND...I got a cool decal :cool:. IIRC delivery was in under 3 weeks.
  15. squirrel
    nobody sets up their own any more? :)
  16. saltflats
    saltflats
    from Missouri
  17. sunbeam
    sunbeam
    To bad you can't get white lead any more.
  18. squirrel
    That's never slowed me down at all.
    Truckdoctor Andy likes this.
  19. 57 Fargo
    57 Fargo
    9” are about the easiest gear set there is to set up. We use them to teach students how pinion depth and backlash affect gear pattern, because they are so easy to adjust.
  20. squirrel
    how does that make you feel, paying to get a service done that auto tech students are experts at? :)
  21. 57 Fargo
    57 Fargo
    Honestly Jim, differentials and transfer cases are two of the simplest components in a vehicle but it seems two of the most feared by people.
  22. bangngears
    bangngears
    from ofallon mo
    All i did was ask specifically about Speedway motors experiences with their third members. Sorry for the cluster#%&!
    Budget36, 2OLD2FAST, loudbang and 2 others like this.
  23. saltracer219
    saltracer219
    Yup, pretty basic stuff here, I can't imagine paying someone else to do this!
  24. seb fontana
    seb fontana
    from ct
    Better than no reply at all?
    saltflats likes this.
  25. Paulz
    Paulz
    Check out John's Industries in Caspian MI.
  26. jaracer
    jaracer
    ***aniam white mixed with a bit of motor oil is close.
  27. tomcat11
    tomcat11
    I do. Pretty simple, you know its done right, and the money you save goes to something else.
  28. finn
    finn
    Listen to Saltracer. Some brands are quieter than others, albeit more costly.
    I would ask a couple of vendors, like Quick, Currie, and others to develop a consensus. Buying cheap likely leads to buying twice if you’re after something quiet.
  29. Mr48chev
    Screenshot (615).png Screenshot (618).png Screenshot (617).png Screenshot (619).png
    For a lot of us Speedway products (not other outfits name brand parts) are the last resort because we can't get it through regular channels parts unless we are running a circle track car. Maybe it is anti facebook rodder syndrome where too many of those guys think that Speedway is the only place in the world you can get a hot rod part.
    As others said, nine inch rears aren't hard to set up right but my experience says they can be a tad tedious if you don't have a high degree of patience.
    1149.99 for an OEM case with a posi and new gears all ready to go is interesting if you don't have anything to work with though.
    Looking on Summit with a Summit brand ring and pinion and limited slip carrier and a Richmond gear install kit the tab runs 804.97 just for the base price parts without the case. It doesn't take long to make one of those ready to go units look pretty good.
    Budget36 likes this.
  30. Budget36
    Budget36
    Maybe he has a no differential/pumpkin in his 9inch? Maybe doesn’t have experience setting up gears? Maybe prefers to just install the damned thing and get on down the road, not spend the time to say “I did it myself”.
    Why buy a ready to fit transmission mount/crossmember etc? Surely it can be built at home for less money.
    Roothawg likes this.
