Technical Bringing home a classic on salty roads
Discussion in 'The Hokey Ass Message Board' started by Mopar Tony, Dec 29, 2023.
  1. Mopar Tony
    Mopar Tony
    I live in SE Iowa and being the dead of winter I know it isn't the best time to buy a cl***ic car and get it home, however I don't have a choice if I want it. The guy selling the car wants me to get it if I want it, and I don't want to miss out on the deal. I found a 51 Mercury I plan on getting I will be bringing it home on a car trailer. HOWEVER it has been snowing here the last couple of days and the road salt is on thick. The roads are also wet which I know will create a salty mist behind the truck that I am not excited about. When I get home tonight it will be dark and probably around 9pm. I still think I have to wash it off ASAP but being below freezing not sure how I'm going to get that done. I was told to neutralized the salt put a little backing soda in the water I use but I wasn't sure if that'd be abrasive on the paint? Any one else been stuck with this problem? What did you do?
  2. A lot of oil beforehand??
    Run as many back roads as practical.
    Ben
  3. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Just go get it.
    Leave it on the car trailer and take it to the closest car wash the next morning so you can power spray it top to bottom and power spray underneath it. One day of dirt or some road brine is not going to ruin the car.
    That car has been exposed to more road salt than Bonneville has salt in the last 70 plus years.
    Unless your water hose is in a heated shop, I wouldn't be using my water hose if it is outside so the line freezes up over night.
    Just go to the closest car wash and power spray it from top to bottom and power spray underneath it and you'll be fine.
    54delray, verno30, jethro67 and 29 others like this.
  4. '29 Gizmo
    '29 Gizmo
    from UK
    Snow foam the top and an underbody wash. It will soon flush the salt out.
    Its survived 70 years so should be fine
    Hot Rod Nut likes this.
  5. Happydaze
    Happydaze
    Get a box trailer.
    Chris
  6. Hot Rods Ta Hell
    Hot Rods Ta Hell
    • Find someone locally (private party racer, rod shop, etc) that has an enclosed car trailer that you could hire to haul the car.
    • If you use an open trailer, I'd wrap the car once you get it on the trailer and strapped down. Tyvek style vapor barrier comes in rolls up to 10' wide. I'd unroll it side to side under the car, then pull each side up tight against the rockers, bringing it up to overlap on the roof. Then unroll a length of 5' wide under the car, front to back and pull those up over the hood & trunk to overlap on the roof.
    • Then I'd start walking around the car with a 3' roll of clear pallet wrap, starting at the trailer deck, wrapping the tires, sides of the car and working my way up to the roof. That stuff is cheap and clingy like Saran Wrap. Maybe a couple of cheap rolls of duct tape for good measure.
    Probably 30 minutes of work, but this should essentially seal the car in a co**** pretty well even at road speed pretty good.
  7. Greg Rogers
    Greg Rogers
    My feelings are exactly the opposite. One day of salt wash is really bad! It will get up in nooks and cranneys and you will try to get it all out at the carwash and you won't. 70 years of age as a pampered cl***ic car is, no comparison to 12 hrs in a salt bath. Any way you could get a inclosed trailer?
    Hemi Joel, swade41 and chryslerfan55 like this.
  8. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    He said he had a trailer so with his question - presumed it was a open trailer.
    He didn't say what the condition is - pampered or not - just a 51 Merc. so who knows what the condition is.
    Yes, obviously an enclosed trailer would be the best way.
    Just dealing with the cards he dealt us with his description.
    SE Iowa has plenty of dirt racers all over that area so with a little **** Tracy work he could probably find one to rent or better yet - go buddy road trip together and make a memory. Buy lunch/ dinner - both and make damn sure to take the enclosed trailer to the car wash after to soap it up really good and really spray rinse it down to get off the road salt.
    That trailer to some guys is a hell of a lot more important the some old 51 Merc..:D
    For that extra touch - spray some tire shine on those tires to make it sharp looking :)
  9. theHIGHLANDER
    theHIGHLANDER
    Road salt becomes corrosive at 38deg and rising. Have you got a warm spot for it? If so do as suggested above, wash it on the trailer. In fact, back the car down ½ way, block it for safety, then take 1 or both ramps off so you can get under and spray wash the living daylights out of it. DO NOT transport the car wrapped up. The flapping cover will beat the **** out of the finish. Even a soft cover does that. All of our stuff are thoroughbred race horses, not a field horse content with a shed and weedy field. Behave accordingly. And news flash, you're still subjected to road salt (in the dust) well thru May. In fact some of the road abrasion year 'round is even more corrosive than salt. And yes, enclosed is best. You're not the only car guy you know.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    Wait for a cold dry road day to go get it, surely the guy can wait a week or two?
  11. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Yes, send him a $200.00 or $300.00 non refundable deposit to wait until the next dry day.
    That way you bought time and it favors him financially to work with you.
    I've done that before to show guys you are serious and not a BS time waster.
  12. I’d drive it home in the snow if it runs.
    I’d have a blast doing doughnuts in parking lots and such.
    with a big ole grin.
  13. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Damn drugs.....:eek:
  14. The37Kid
    The37Kid
    Finished show car or something field fresh?
    Tow Truck Tom likes this.
  15. HOTRODPRIMER
    HOTRODPRIMER
    No one mentioned that driving on icy roads could result in a accident, Consider Cob's advice to offer the seller some good faith money to hold the car until the roads are clear. HRP
  16. gotta56forme
    gotta56forme
    from Seattle
    consider this the ramblings of the semi-insane...
    If it's really a concern, could you rent an enclosed storage space for a month, maybe two in the seller's locale until you have a better transport situation lined up? I realize it will add some cost, but if you get temp storage, it may ease your mind.
    Texas57, mohr hp, swade41 and 3 others like this.
  17. Just woke up.
    But I was fortunately born with a natural chemical imbalance saving myself untold amounts of cash from not needing drugs.
  18. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Been there,,,, done that,,,,, got the T'shirt.
    chryslerfan55 and gotta56forme like this.
  19. alanp561
    alanp561
    No offense intended, @anthony myrick;). Ahhh, me! Southerners and winter. Since I've moved here, I've always been amazed at the reactions of Southerners and the possibility of snow. "OMG, it may snow tomorrow. Close the schools and businesses and everybody run to the store for milk and bread". Then there's "OMG, it snowed a whole half an inch. Quick, let's run to Walmart to get milk and bread. While we're there, we can do doughnuts in the parking lot". :rolleyes: Another thing I've noticed in these situations is that no one ever mentions getting toilet paper.
    As for the matter of getting the OP's car home, I'm in the enclosed trailer camp.
  20. J. A. Miller
    J. A. Miller
    from Central NY
    Refer to Cob's post #3.
    Baking soda is used to neutralize acid not salt.
  21. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Excuse me for the hi-jack buuut.
    Come from SE Pa. First trip to Wisc. ( trailer trk'g )
    Plowed Snow, banked next to the roads 4 ft high.
    At least a half hr 'til dawn, I near my drop address, there on the corner, there's a crowd.
    It's the kids waitin' at the school bus stop.:p
    Btw Drag'n a trl in ice and snow, can require a lot more than a wash job to repair...
    williebill and chryslerfan55 like this.
  22. pirate
    pirate
    from Alabama
    If you really want the car and fully intend to buy it pay the guy in full, do the paperwork with the stipulation you will pick the car up when the weather is better and dry. That doesn’t mean weeks or months but the first time weather permits. Can’t imagine someone would give up a sale for a reasonable request of a few days or week especially if the person is a car guy. If it’s a project car just go get it. If it’s a show car hire someone with an enclosed trailer. If the guy is insistent on it being gone as of change of money I might question why that is so important. I haven’t bought a tremendous amount of cars but never met a seller who wasn’t willing to work with me on pick up or ***isting when my arranged transportation arrived.
  23. I’m the southern idiot that loves snow.
    I usually drive a couple hours to find some when we unfortunately are “spared” when snow comes our way.
    but going after cars are fun adventures. Waiting for things to be perfect kinda takes out the danger. The most fun I ever had behind the wheel was an old ford ton truck I bought. Took 4 tires, a fuel pump, coil, carb, gas, oil and tools. We got the front brakes to bleed. Replaced the fuel pump, rigged up a gas tank in what’s was left of the bed. No key so we wired up a household light switch. Dumped some motor oil in the rear that had a blown seal.
    Drove it around 225 miles home. No exhaust and no side or back gl***.
    fun times
  24. 57JoeFoMoPar
    57JoeFoMoPar
    What kind of car are we talking about here? A complete project car in well prepped bare steel? A finished show car with immaculate paint? An honest driver? A completely rotted pile of ****? The answers to these questions will be what determine the best course of action is, from "go rent an enclosed box" to "F it, just go get it"
  25. MCjim
    MCjim
    from soCal
    Absolutely. I have held stuff for months after being paid; and usually the buyer compensated me- without asking.
  26. partsdawg
    partsdawg
    from Minnesota
    Have seen this scenario played out here in Minnesota.
    Always found it ironic that the worriers would fret over the vehicle and salt but thought nothing about taking their $30-80,000 truck and $5-8,000 trailer out in the salt to go get the vehicle
    phat rat, Ribbedroof, Bugguts and 5 others like this.
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    maybe I am the only one, but I store my dually and trailer for the winters.... I hate salt
  28. What’s the difference between Bonneville salt and yankee road salt?
    everyone seems to highly prefer the Bonneville salt and are fine with old cars covered in it.
    Just wondering
    Jacksmith, vtx1800, 29A-V8 and 3 others like this.
  29. Mopar Tony
    Mopar Tony
    Car is definitely not a POS. It is a quality driver. I have looked around for an closed trailer with no success. I do not have a heated shop, just a normal garage for the car to be in when home. It is 38 degrees here today with no snow currently on the road. It snowed yesterday and they bladed and spread salt. The roads are still damp in spots and I'm just afraid the car will be misted on the way home with road salt. The car was a Texas car and I don't think its ever seen salt and it is the most I have ever paid for a old car and I don't want it ruined. The guy has to move the car from where it is located and he doesn't want to pay storage, also I think he needs the money or he wouldn't be selling it. I was thinking of just bringing it home and power washing it in my driveway tomorrow afternoon. It is supposed to be about 40 and then I'd put it back in the garage till may or so.
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    Man, all those pictures of cars covered with Bonneville salt make me shudder.... people say all you have to do is jack up your car and run a lawn sprinkler under it... that just drives the salt deeper into the pinch welds.. Here is a case in point Bob Klessig drove his 52 chev convert on the salt and there was a widely distributed photo of this car going thru a salt water puddle and the spray was shooting up all around the car. I called him and said "man, what the hell were you thinking?" and he replied having fun. It was a year or two later I saw the car in Salina and there was RUST bubbles all around the bottom of the car. He had to completely redo the body and paint after that.
    You could not pay me enough to drive my old cars in any kind of salt
    curbspeed, RDR, Rolleiflex and 17 others like this.
