1952-59 Ford has anyone used a stock explorer rear [ un cut ] in their 54 pass car
Discussion in 'Off Topic Hot Rods & Customs' started by robert evensen, Dec 18, 2023.
  1. robert evensen
    robert evensen
    if you used a stock width explorer rear in a 54 p*** car , what wheel / offset were used in an original wheelwell .. thanks
  2. 55customlinecowboy
    55customlinecowboy
    The stock explorer rear has 2 different length axle tubes. This will offset the pinion yoke. Most people get two rear diffs from the junk yard and use both short axle tubes and axles.
