Projects Traditional Banger Build
Discussion in 'Traditional Hot Rods' started by reffiesj, May 17, 2023.
  1. Lättähattu
    Lättähattu
    from Finland
    I'm not a expert, but i think that the shackle angle is not correct with your shorter main leaf. The original looked better. And remember that model A axle has perch boss higher than I beam and 32 has the boss even ground into the I beam. Not much difference, but some any way, around 1/8". I would try the original main leaf with spacer on top of the axle, or have a local spring shop made you a main leaf with lenght between those two you have now.
  2. reffiesj
    reffiesj
    Thanks Lattahattu - I realized this morning that the pic I posted is a bit confusing as the axle is hanging loose - will snap a pic with full weight on the front end when I next head to the garage - I checked it post-install and there seemed to be good clearance (and decent shackle angles)
    winduptoy and chryslerfan55 like this.
  3. reffiesj
    reffiesj
    Here is a pic of the front suspension under load - plenty of clearance now. IMG_1143.jpeg
    Also started work on breaking down the rear brakes
    winduptoy, chryslerfan55 and Jeff34 like this.
  4. Lättähattu
    Lättähattu
    from Finland
    Now the front end looks perfect! I did not notice that there were no load on axle in earlier photo.
    winduptoy likes this.
  5. ModelAMitch
    ModelAMitch
    The front end turned out great, looks good with everything put together.
    Does the new exhaust header interfere with the oil tube out of the valve cover? Did you mention where you got the header from in a previous post? Keep the updates coming!
  6. reffiesj
    reffiesj
    Thanks Lattahattu - appreciate all the input.
    Thanks ModelAMitch - the header is a Red's Header with the tag ground off - I had it ceramic coated locally. It does not interfere with the oil return tube, I checked the clearance and just decided to put another coat of paint on the oil return tube so ***embly wound up a bit out of order - will reinstall it over the next couple of days.
    Outback and chryslerfan55 like this.
  7. Good looking project you got there. Needs a Miller conversion though. Hehe.
  8. reffiesj
    reffiesj
    Chryslerfan55 - maybe some day…for now I would be happy just getting the brakes wrapped up, the rear end dropped and the police head, downdraft and Zipper distributor installed…
    Made some progress tearing down the rear end and am planning to drop brake rods, radius rods and miscellaneous odds and ends off at the powder coater this week - also realized I didn’t have spark plug ends for wires and need to fab a new lower rod for the linkage to clear the header - reverse eye rear main leaf and new shackles are also on their way….
  9. reffiesj
    reffiesj
    Got a little time in today. Managed to make progress painting rear brake parts, getting the fuel line in place to the carb and removing the spring from the rear axle without sending myself to the hospital…
    winduptoy and Jeff34 like this.
  10. reffiesj
    reffiesj
    Frustrating work over the past two days - while the p***enger side rear perch bushing came out with a handful of hammer whacks, the drivers side was a whole different story altogether - it wouldn’t budge - tried the hacksaw and still wouldn’t move or even collapse on itself - wound up using a drill, chisels and punches to eventually break it out but it took WAY longer than was reasonable. Managed to remove and break down the rear spring before calling it quits for the weekend….
    lahti35, winduptoy, Jeff34 and 2 others like this.
  11. lamaison
    lamaison
    from Canada
    Just a heads up with regard to your spring ***embly, ***uming it was previously ***embled incorrectly and you're unaware. The short "dummy" spacer leaf shown on the top of the spring should actually be placed under the bottom main leaf. The clamps should tighten up against it. It's sole purpose is to make the spring ***embly the same thickness as other springs with 8 leaves (Coupe, etc.) allowing the same clamps to be used on both the 7 and 8 leaf springs. ***uming it is the correct original spacer it will be long enough for the clamps to bear on. Might want to verify length before final ***embly.
    Also the correct top spring leaf should have beveled edges to avoid binding in the crossmember.
    Nice work so far, good luck.
  12. reffiesj
    reffiesj
    Lamaison - thanks for the input - the advice is much appreciated. I had not realized that the roadster had a spacer in the spring pack - will move it to the bottom and am also planning to remove spring #2 and cut it down to also serve as a spacer (real spring #2 not as shown in the pic). The second spring in the photo does indeed have beveled edges.
  13. berijillel
    berijillel
    Good project, looks great! And good luck in dealing with the spring
  14. reffiesj
    reffiesj
    Thanks berijillel
    Got a little done tonight - finished up the throttle linkage and started on front brake re***embly w the floaters.
  15. reffiesj
    reffiesj
    IMG_1378.jpeg Got the pedals rebushed and back in the car and front brake rods hooked back up - brakes worked fine but clutch pedal going to the floor and not returning - checked to see if pin was sheared but it was fine (that would have been too easy) then pulled off inspection cover and found a giant mess of weld on the pressure plate and old hardened grease everywhere - so looks like I am going to need to pull the gearbox off. While I am at it, am thinking I will take the rear end apart, powder coat everything and potentially change the gearing.
    This brings up a few questions - what are people's thoughts on 39 gearbox (***uming I can find one) vs Mitchell synchro box (8-9 month waiting list)? What about 3.54 gearing? Anything else I should be thinking about while everything is apart?
    winduptoy and stubbsrodandcustom like this.
  16. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I did a v8 trans upgrade on my last banger. I was running 3.27 gears in mine, it worked like a charm... Either gear 3.54 or 3.27 is a huge upgrade for top end driving. I was able to cruise 70s on the fwy with ease. But I had 100 hp B motor. I think with a Mild A motor 3.54 is where its at. Just remember you can get a bit more with some rubber also as tires can be the poor mans gear swap.
    The trans update, I used a 34 trans, Clings adapter. It worked pretty well, Synchros were nice for sure, but end of the day the only thing I really liked was the 2-3 shift being more close range. Was it worth it? Eh, somewhat. If I wasn't building period correct stuff, I would have done the 5 speed on the stock gears and really cut down on the work and gains more drivability without gear swap.
    I have owned a 39 trans and this 34 trans, drivability was about the same. So if you are going early v8 trans, then anything 32 and up top loader is where its at. You can also search for a 32 banger trans also.
    If I had to build a banger again, and I will build a banger again, I would splurge on a Kiwi quick change, and a v8 trans.
    winduptoy and Outback like this.
  17. wuga
    wuga
    I just removed the original springs and replaced them with Posies reversed eyes springs on my RPU. No where did I see the dummy plate on the bottom. I also just rebuilt an original 37 rear spring and the dummy plate had the center bolt swagged into it and was at the top. I appreciate if leaves are removed, the space for the spring clamps needs to be taken up and either spacers can be made or clamps with more meat used to accommodate can be used. The only time I would move that dummy leaf to the bottom would be if I wanted to lower the car 1/4"
    Warren
    redoxide likes this.
  18. reffiesj
    reffiesj
    Thanks stubbsrodandcustom - gives me some things to think about.
    Warren - am planning to move a couple leaves to lower the car some (along with the reverse eye main) so the dummy plate is going to the bottom of the pack - original or not.
    Managed to get the rear end out today - planning to pull the gearbox next and then start pulling things apart. Rear End Pic.jpeg Trans Removed.jpeg
    ZerroHalfcup and Outback like this.
  19. 29Sleeper
    29Sleeper
    from SoCal
    Does anyone make a mandrel bent header? These appear to use a muffler shop type bender that we used to refer to as a squish bender since it squished the tubing smaller.
  20. ‘28 RPU
    ‘28 RPU
    Whose throttle linkage are you using?
  21. reffiesj
    reffiesj
    '28 RPU - I am using a Burns Racing Equipment Linkage - had to modify the bottom lever to clear the header.
  22. lowroder
    lowroder
    why go to a 32 axle? im looking to build a banger myself with lowering springs front an rear . 600s or 550s an 700s with 35 wires are epic.
  23. lowroder
    lowroder
    super cool... im also looking to build a banger hot rod. also mechanical brakes.. but with lowering springs front an rear.
  24. lowroder
    lowroder
    great stance... what leafs did you remove? im looking to buy rev eye drop springs. are you also running stock front axle?
  25. lowroder
    lowroder
    are those the stock wheels and tires on it now?
  26. lowroder
    lowroder
    curious why your swapping to a 32 axle? im new to banger builds an also looking to build mine in a similar traditional way.
  27. lowroder
    lowroder
  28. lowroder
    lowroder
    why swap to a 32 axle? im curious as im looking to build a 30/31 A myself
  29. lowroder
    lowroder
    very interesting... i also was looking into the ol yankee springs myself.. an i have heard too of the 2 different spring eye to eye lengths.. very possible that's the issue.
  30. lowroder
    lowroder
    just curious of why you didn't return or go back to ol yankee for the spring fix instead of spending more money.
