Technical Blower snout length on a SBC
Discussion in 'The Hokey Ass Message Board' started by Gavin Tittle, Nov 15, 2023.
  1. saltflats
    saltflats
    from Missouri
    What does the front of that intake look like, only have seen the back?
  2. Fordors
    Fordors
    I think you are referring to the OP’s manifold, here’s the front of the Edelbrock B10.
    427 sleeper, mad mikey and saltflats like this.
  3. saltflats
    saltflats
    from Missouri
    Thank you. Looks like a race manifold. The OP should look for a different one if it's going on a street ride.
    427 sleeper and mad mikey like this.
  4. Fordors
    Fordors
    I run a Weiand, the early one with no water crossover. I drilled the heads for 3/8 pipe and ran -10 lines to an Offenhauser thermostat housing, never a problem with cooling.
    gimpyshotrods, 427 sleeper and rod1 like this.
  5. saltflats
    saltflats
    from Missouri
    Run a BDS and not have to drill the heads.
  6. fast30coupe
    fast30coupe
    from Illinois
    If your heads are aluminum you can weld an AN bung to that spot
    mad mikey likes this.
  7. GlassThamesDoug
    GlassThamesDoug
    This one is only $4500, but it's wrong on so many levels for street. But it would look cool, at least it has that going for it.... IMG_0748.jpg IMG_0752.jpg IMG_0755.jpg IMG_0754.jpg
    swade41, Hollywood-East and mad mikey like this.
