Projects 26 roadster build; Bang Bang
Discussion in 'Traditional Hot Rods' started by h.i., Nov 4, 2012.
  1. LSR 2909
    LSR 2909
    from Colorado
    Nice progress and your work looks great to me!
    h.i. and PINEAPPLE like this.
  2. Chalkie
    Chalkie
    from England
    Great build well done
    I do love a 26/27 T's
  3. FlatJan
    FlatJan
    i first thought the distance between grill and body would be to large but really turned out great
    h.i. likes this.
  4. h.i.
    h.i.
    from denver
    This summer I really wanted to fire this thing up and run it to test the fuel system and distributor that @PINEAPPLE built for me, and just for motivation really. I wired it up and had it running pretty well. There was a little backfire out of the intake which I thought was probably just too much fuel. One of the strombergs I rebuilt was leaking quite a bit of gas from one of the emulsion tube channels. I pulled it off and rebuilt another 97 I had on the shelf. Put it back on and nothing had changed. Still backfiring. @PINEAPPLE was over one day and suggested we check compression real quick. Got all the way around to #7 and found the dead cylinder. Valve was not closing. Decided the best course was pull it and do the top end so back out it comes. Its on the stand now waiting for parts.
  5. PINEAPPLE
    PINEAPPLE
    dong
    Stogy likes this.
  6. brEad
    brEad
    Bummer! Thanks for the update. Don’t get discouraged, you’re getting closer.
  7. hotrodA
    hotrodA
    Great car and great work!
    I see it and the seller’s remorse hits me again. Should have never sold mine.
    Keep the updates coming, please.
    Stogy and Dave G in Gansevoort like this.
  8. Greenblade
    Greenblade
    Cool build! Looking forward to further progress
  9. Tim
    Tim
    from KCMO
    Same :)
    Stogy and PINEAPPLE like this.
  10. h.i.
    h.i.
    from denver
    I didn't like the way I did the pedal surround the first time so I redid that and got it a little closer. VFIR0151.jpg
  11. h.i.
    h.i.
    from denver
    Small updates. Trying to get everything ready to go to the plater so I finally chopped and fitted the stanchion inserts. Had been putting this off cause im not very good with the TIG and these were super rusty and beat up. QXKA8913.jpg
    Jeff34, Outback, Okie Pete and 7 others like this.
  12. h.i.
    h.i.
    from denver
    Started working on the dash. Was loosely fitting the cluster when I pulled this awesome move. Did a little turning on the insert while its is apart. IMG_4379.jpg IMG_4380.jpg
    V8-m, Cali4niaCruiser, rod1 and 13 others like this.
  13. h.i.
    h.i.
    from denver
    Little update for whoever is still following. Was cleaning up the motor getting ready to grind the seats and do new valves, cam, etc and got a neat surprise. Going to test another 8BA I have and if its any good we will build a new engine. #flatheadsforever QKKE9248.jpeg
    Jeff34, Okie Pete, Tim and 6 others like this.
  14. Auggie Dawgie
    Auggie Dawgie
    from New Jersey
    Sweet build. The stance is perfect and like what you did with the seat pan.
    Stogy likes this.
  15. Squablow
    Squablow
    Bummer about the crack, not a great spot for it, either. Hope you have better luck with your next block.
    Stogy, OFT and -Brent- like this.
  16. Dave G in Gansevoort
    from Upstate NY
    Some cracks are good. That's not one of them! Hopefully the new block checks out. Love the progress. And the stance is great. Do a video when you get the engine running. We all need our flathead fix now and again...
    Stogy, wood remover, Outback and 3 others like this.
  17. alchemy
    alchemy
    Save it for later. Pinning and sleeving will save it.
    Stogy, brEad, Jeff34 and 1 other person like this.
  18. PINEAPPLE
    PINEAPPLE
    Hey Guy. Are you working on this pile? wtf
    Stogy, 43willys and 26 T Ford RPU like this.
  19. h.i.
    h.i.
    from denver
    Okay I guess its time for an update haha. The old Merc motor was cracked and a friend turned me on to this good running 59a for cheap so I picked it up and dropped it in.
    Jeff34, Nailhead A-V8, OFT and 6 others like this.
  20. h.i.
    h.i.
    from denver
    I had the radiator redone to match the bigger outlets because early ones just look better. Also had to redo the belts and fan mount for 59a style stuff.
  21. h.i.
    h.i.
    from denver
    I also got a bunch of stuff chromed a while back but didn't take any pics. Here is the deck latch and tail light installed. 69457713602__C48760EB-BEC1-41AE-B433-44088D8AA0B6.jpg
    Jeff34, Nailhead A-V8, OFT and 5 others like this.
  22. h.i.
    h.i.
    from denver
    I got the tack strip kit and went to work sanding and fitting this mess.
  23. h.i.
    h.i.
    from denver
    Built a seat frame and made a filler panel with a little engine turning for the firewall. 70883471581__9BC2A3DA-102B-4A49-9802-92FB313190CB.jpg 70873652308__F1551C16-A55F-410B-BA79-630037A8BF35.jpg
  24. h.i.
    h.i.
    from denver
    Basically trying to get all the metal work done before prepping for paint. Last pic before tearing it all down. 70494226873__7B991AF3-73C7-40BB-8856-48DC2207CA8E.jpg
  25. h.i.
    h.i.
    from denver
    Had to kick out the 48 to make room and took it all apart again 9B557114-E348-47EA-B841-29EB3EBD66D2_1_105_c.jpg
    Nailhead A-V8, OFT, Okie Pete and 2 others like this.
  26. h.i.
    h.i.
    from denver
    Got the rust oleum and started primering everything.
  27. h.i.
    h.i.
    from denver
    And now we are all caught up to tonight:
    AndersF, cactus1, OFT and 10 others like this.
  28. Tim
    Tim
    from KCMO
    Awesome!
    ERguitar likes this.
  29. 26 T Ford RPU
    26 T Ford RPU
    This will be stunning, nothing out of place and great proportions. What will the color be? :cool::cool: JW
    OFT and h.i. like this.
  30. Okie Pete
    Okie Pete
    Very Kool
    h.i. likes this.
