  1. 40ragtopdown
    40ragtopdown
  2. 40ragtopdown
    40ragtopdown
  3. 40ragtopdown
    40ragtopdown
  4. 40ragtopdown
    40ragtopdown
  5. 40ragtopdown
    40ragtopdown
  6. 40ragtopdown
    40ragtopdown
  7. 40ragtopdown
    40ragtopdown
  8. 40ragtopdown
    40ragtopdown
  9. 40ragtopdown
    40ragtopdown
  10. 40ragtopdown
    40ragtopdown
  11. 40ragtopdown
    40ragtopdown
  12. 40ragtopdown
    40ragtopdown
  13. 40ragtopdown
    40ragtopdown
  14. 40ragtopdown
    40ragtopdown
  15. 40ragtopdown
    40ragtopdown
  16. 40ragtopdown
    40ragtopdown
  17. 40ragtopdown
    40ragtopdown
  18. 40ragtopdown
    40ragtopdown
  19. 40ragtopdown
    40ragtopdown
  20. 40ragtopdown
    40ragtopdown
  21. 40ragtopdown
    40ragtopdown
  22. 40ragtopdown
    40ragtopdown
  23. 40ragtopdown
    40ragtopdown
  24. El Caballo
    El Caballo
    from Houston TX
  25. I have a question on this diagram. The ignition switch has 3 wires coming off of it. It doesn't have the wire from the ignition switch to the start side of the starter shown. My question is what is the top wire from the ignition switch to the coil? I see the power wire from the ignition switch going through the resistor to the coil. What does the third wire do? If it's 12 volt it byp***es the resistor, if it's power from the coil to the switch, it wouldn't be 12 volts would it? I've never wired an ignition like this.
    65pacecar likes this.
  26. 65pacecar and 40ragtopdown like this.
  27. Fabber McGee
    Fabber McGee
    Top wire is supposed to come from a small terminal on the starter solenoid, not the ignition switch. Energized only when the starter is turning to provide a full 12 volts to the coil and get hotter spark to get started more easily.
  28. 65pacecar likes this.
  29. 65pacecar likes this.
