Technical What would Johnny hamber do?
Discussion in 'The Hokey Ass Message Board' started by silent rick, Jan 4, 2024.
  1. silent rick
    silent rick
    would you drill and tap this intake for a pcv valve or just run a road draft tube?
  2. 73RR
    73RR
    Well, a pcv is certainly the better way to go but, on a fresh engine it should not be ****ing much foul air. The advantage is that it will provide a negative pressure atmosphere and that is helpful in keeping things clean and some will suggest that it can help with ring seal. If you have concerns about 'looks' then you can mount the valve on the bottom of a runner or plumb into a spacer under the carb(s).
  3. squirrel
    Is it going on an engine that needs to last 100k miles? or 25k miles?
    Is there anything else modern on the build?
    In other words, like most things, "it depends"
  4. pwschuh
    pwschuh
    Road draft tube plumbed straight down a dolphin's throat. :D
  5. Rocky
    Rocky
    Classified Editor
    My concern would be with a PCV plumbed into one carb or one runner, it would be running leaner than the other ones. I suppose you could use several T-fittings and hoses to pull from all carbs/runners equally but it'd look like hell. I'd go with a road draft tube for now.
  6. Jack E/NJ
    Jack E/NJ
    from NJ
    If it was mine, I'd worry more at this point about what air cleaners to put on top of those rock catchers.
  7. silent rick
    silent rick
    fresh build, going to start off with this edmunds, a lot less painful to tap into the spacer under the rear carb than a runner on a vintage intake, no matter how well i hide it.
    i guess i could run a hose down to the exhaust
    Tim and chryslerfan55 like this.
  8. KevKo
    KevKo
    from Motown
    That looks like the plenum connects all 4 carbs, so it could be drilled and tapped at the rear, or even underneath, out of sight.
    19Eddy30 and Tim like this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    Won’t half the engine run lean if you take it from the rear carb? A PCV is a calibrated vacuum leak
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Johnny say’s No!
    I also agree with what Rocky said.
    Moriarity and squirrel like this.
  11. Oneball
    Oneball
    If plumbed into the plenum on that manifold a PCV won’t make one carb run leaner than the others in any negligible way.
    I think PCVs work really well but if you’re not going to be dailying it and doing 25k a year I wouldn’t go to the effort of drilling a tapping it, in fact I wouldn’t even bother with a road draft tube, just fit a couple of filtered breathers and away you go.
    hrm2k, MCjim and chryslerfan55 like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    I run a road draft tube on my 40. There was no way I was going to drill a hole in this
  13. oldiron 440
    oldiron 440
    Draft tubes look cool with that oily froth at the end tube and oil coming from every seal on the engine splattering on the bottom of the ride and marking its spots along the way.
    KevKo, loudbang, SS327 and 5 others like this.
  14. silent rick
    silent rick
    rustproofing
  15. 56don
    56don
    You just described a Ford Y-Block
    alanp561, Cooon, guthriesmith and 2 others like this.
  16. silent rick
    silent rick
    that's next on the list waiting to be built, 4-71 with either four 97's or a pair of 400cfm AFB's
    Cooon likes this.
  17. squirrel
    Oh, that doesn't happen until the engine has a few thousand miles on it....
    guthriesmith and AHotRod like this.
  18. silent rick
    silent rick
    just burn it off in the header?
    mad mikey likes this.
  19. onetrickpony
    onetrickpony
    from Texas
    You have to have a vent to allow air in with a PCV valve. I use the road draft tube as the inlet, while the PCV draws the vapor out.
  20. '29 Gizmo
    '29 Gizmo
    from UK
    Road draught tubes get a bad press. On an old knackered smoky oil burner they puke out.
    But a well built freshly built motor with minimum blow by and good oil vapor seperation upstream of the tube they work fine.
    They also need a "draught" with the outlet in a low pressure zone under the car to draw out properly, as they are designed stock.
    427 sleeper and squirrel like this.
  21. silent rick
    silent rick
    oil fill tube in front with a filter/breather cap on it
    onetrickpony likes this.
  22. Rickybop
    Rickybop
    PCV vent?
    Isn't that taken care of by the inherent blow-by?
  23. silent rick
    silent rick
    you're scaring me
  24. wheeldog57
    wheeldog57
    A small block Chevy plastic 90 PCV that goes on the valve cover MAY fit under the wire loom covers of the hemi.
  25. onetrickpony
    onetrickpony
    from Texas
    Duh.. I read "road draft tube" and thought " oil fill tube." I'll go back to sleep now.
  26. RodStRace
    RodStRace
    I did one on a OT tunnel ram. I would NOT on that.
    The guys saying plumb to exhaust, there are systems designed to create a pull and use a check valve. Problem is, it must not have ANY restriction - open header with short collector.
    https://www.jegs.com/c/Oil-System_Crankcase-Evacuation-System/10449/10002/-1
    As you can see, they are basically road draft tubes in the collector.
    You may also notice vacuum pumps and catch cans if you want to keep from drilling that intake.
  27. silent rick
    silent rick
    hiding the pcv isn't the problem, i put a grommit in the hole for the road draft tube and install it there, but where do i plumb it to?
  28. silent rick
    silent rick
    i won't have much past the collector, maybe 24-30 inches and a quick turnout
  29. Bandit Billy
    Bandit Billy
    I don't have a game plan on how to plumb it, but I'd want one if it was me. I tried to use the road draft tube on my flathead, and it was no bueno. Oil leaks, smells, stuff that most guys just put up with owning an old engine but not me. I fitted a PVC and all the leaks are gone. Mine was easy, that 4x2? Not so much. Maybe a hidden vacuum pump to **** that block out?
    loudbang and silent rick like this.
  30. Could en electric set up work.
    Never used one like that
    Just wondering.
    silent rick likes this.
