  1. Sky Six
    Sky Six
    from Arizona
  2. dearjose
    dearjose
    Front pulley looks like it's an inch off the ground. Prolly one of the most extreme rakes I've ever seen on a digger motor.
    1947knuck, mad mikey, Deuces and 6 others like this.
  3. What was the purpose of having the rake on the motor?^^^^^^^^^^^^^^^^^^ Most diggers seem to have some rake to the motor.
    1947knuck, Deuces and chryslerfan55 like this.
  4. Yblock63
    Yblock63
    Did you ever happen to run across any old pictures of Lemon Wedge?
  5. DDDenny
    I've always likeď this one.
  6. mohr hp
    mohr hp
    from Georgia
    The engine rake or dump on a FED is critical to the bite. Early rails with lousy tires needed a lot of help getting bite, so the engines were high in front, promoting weight transfer. As tires got better, less weight transfer to the rear was needed, so to prevent backflips, the engines went down in front. It was a delicate balancing act.
    mad mikey, Deuces, loudbang and 2 others like this.
  7. 65pacecar
    65pacecar
    from KY, AZ
  8. 65pacecar
    65pacecar
    from KY, AZ
  9. bushwacker 57
    bushwacker 57
    Cotai Drag Strip Nor Cal background 61 Starliner Gas Ronda Bill Waters Ford Oakland Ca.
    mad mikey, Deuces, loudbang and 5 others like this.
  10. bushwacker 57
    bushwacker 57
    mad mikey, Deuces, 1320 Fan and 3 others like this.
  11. mad mikey and 65pacecar like this.
  12. Thank you. Makes sense.
    Deuces likes this.
  13. 65pacecar
    65pacecar
    from KY, AZ
  14. 65pacecar
    65pacecar
    from KY, AZ
  15. 65pacecar
    65pacecar
    from KY, AZ
  16. Let’s see, if I adjust the tension on the belt by a half turn would I then need to adjust the timing by the same?
    65pacecar and old flopper like this.
  17. 65pacecar
    65pacecar
    from KY, AZ
  18. bschwoeble and 65pacecar like this.
  19. In the past I bought many 3" pulleys from dragsters that had that forward rake, and chewed up the front edge of the pulley. It was easy to cut them down on a lathe to make 2" pulleys.
    mad mikey, bschwoeble and 65pacecar like this.
  20. bschwoeble and 65pacecar like this.
  21. 65pacecar
    65pacecar
    from KY, AZ
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    THE CUT OFF IS 1965!!!!!!!!!!!!!!!!!!!
  23. bschwoeble
    bschwoeble
    It can't be said enough. Is it because some are being sneaky, or because they are not savvy enough.
    Moriarity and Deuces like this.
  24. Deuces
    Deuces
    It got worse with a longer wheel base and trashed out oil pans..
    mad mikey and chryslerfan55 like this.
  25. DDDenny
    Attempting (and failing) to interpret the rules.
    Only Smokey Yunick could do that!
    mad mikey, ottersea and chryslerfan55 like this.
