Projects 1931 Cobbled Roadster Build
Discussion in 'Traditional Hot Rods' started by glorydime, Jan 1, 2019.
  1. glorydime
    glorydime
    from Austin, TX
    My radiator has the offset fill that will sit under the hood so i needed to fab up a little hold down for the radiator cap on the grill it self. I had a piece of s**** left from some sheet that I was hole sawing out. Cleaned up the edges and welded on a threaded piece and took the cap screw out to the threaded part allowing the cap to rest threaded on the radiator. Nothing fancy but I'm happy with the radiator shell it is too nice for this car.
    cb02685d-055d-4afc-806c-c3e8f7a15c45.jpg 5be8916c-e686-47ac-ae81-b1a448833b53.jpg 080aaacf-09ed-4957-a006-757b7b98d43f.jpg a27e8cdf-ea2f-44ad-8ac3-49905de355df.jpg 44952b8c-e313-447f-bc5a-4619dc9d471c.jpg
    brEad, Tim, oliver westlund and 7 others like this.
  2. Jeff34
    Jeff34
    @glorydime Looking great! Keep on it!
    I think we have the same welding cart setup :D
    glorydime likes this.
  3. glorydime
    glorydime
    from Austin, TX
    Over the Holiday break I built my light bar. Had some help from my little nephew. He is 8 and in return he asked me to show him how to mig. Light bar took me a few days of heating and bending and looking over and over. Not to mention getting it level was hard, but it came together pretty well. Only issue I had was I ran out of gas on the Friday prior to the Holiday. Luckily my wife is a jeweler and she has some acetylene at her shop. I have a pair of 903 guides and a pair of 904s. I always thought i was gonna like the 904s most but I am leaning to the 903s. They are smaller and look better on this tore down sweaty roadster.
    b828ca0d-8684-401a-bea8-7d1eb9c20359.jpg 67da93eb-50fd-40f8-a2d7-b3fc698ec543.jpg a82c93c0-32b7-4217-99c4-571376a69160.jpg c30b0d45-8334-4ead-b7ff-80e55e2fa867.jpg 3086e193-096e-4e2a-a55a-e037ce7869d5.jpg e89a6043-eca1-43c6-bb77-336ed874109b.jpg fc444e72-ebb8-4316-a2d0-883467b0e60d.jpg 1f9931e4-c97b-4e68-b9c6-54fdfd8f8c67.jpg 41d79948-825d-4ce5-bc77-41551ff4b131.jpg fde0b21a-8494-40de-bd41-850b220933f8.jpg 233a87ed-c2a0-4d2f-990b-716c5e572a4f.jpg 04502261-5248-403c-936e-90fe603af9ca.jpg
    brEad, Tim, GordonC and 6 others like this.
  4. glorydime
    glorydime
    from Austin, TX
    Harbor Freight Special!!!! its actually a really nice cart. I have three machines on it and its so sturdy.
    Jeff34 and stillrunners like this.
  5. Metal Mover
    Metal Mover
    from Jamul CA
    It's coming together nicely, lots of hard work there!
  6. stillrunners
    stillrunners
    from dallas
    Keep on going.......!
  7. glorydime
    glorydime
    from Austin, TX
    Finally seeing the light at the end of the tunnel.
    stillrunners likes this.
  8. glorydime
    glorydime
    from Austin, TX
    Being my first hotrod I’ve made so many mistakes i had to fix later. Next car I hope will go smoother. Can’t believe how much I’ve learned from this forum and just being hands on with this car.
    brEad and oliver westlund like this.
  9. glorydime
    glorydime
    from Austin, TX
    Got my Shocks on this weekend. Amazing how much stiffer the car is now with them on. I bought the SoCal closed tube shocks. I like the look of them alot. 24d55235-ac84-49a7-b9ca-0fd326269c8e.jpg 1661dbb0-bc10-41b6-9eb7-07d4a00558c5.jpg 17a7d865-374c-4db0-b32d-79a6c38e9e66.jpg 27c820f8-b48d-4520-9aac-d1da82089213.jpg
    brEad, Tim, So Cal Brian B and 7 others like this.
  10. What an awesome build. Keep the updates coming.
  11. stillrunners
    stillrunners
    from dallas
    Getting alot done in that little garage !
  12. glorydime
    glorydime
    from Austin, TX
    Frustratingly small. Making it work.
  13. glorydime
    glorydime
    from Austin, TX
    Finished up the Parking Brake yesterday. The mounting is straight from Tradel/Bishop book. Angle Iron around the detent and welded on stems or spacers. For the rod I used the left over rod from the mechanical brakes that were on the car when I got it. I was able to use one end of the eyelets from the brake rod as a keep on the back side of the crossmember. Couple of brakes and taps in the rod and it was in the car and working great, we seems to be working well. Parking on a hill will be the real test.
    bcccdc70-e318-43f3-a8db-b104c168faa0.jpg ecb4ab9d-18f9-4a3f-9fae-fa0995fc53a2.jpg 41cbe8c6-d1cb-41d9-a096-b5322172f5cb.jpg 6bdd38cd-2713-4222-a099-cb78560971f2.jpg d315e427-e6ff-432c-a484-6ada09a0a345.jpg b05217bd-d8b0-4bb0-9d6a-c0f170524630.jpg 1ed25bfd-02c2-4cb7-9a8f-16fc187c5add.jpg ec7ffcf7-8196-4a01-94ca-b385e5698cfa.jpg 54f0b707-bc7a-4f94-b012-b2956f586195.jpg 54366045-f9a0-4a2c-a46f-b126bbaac9b9.jpg 52915166-e18e-4cdf-874f-4b5945ed7bfe.jpg 4dfc261a-1459-4dd9-955d-2fd6c3da115c.jpg 7ea12273-ce17-44eb-8168-2e352f50d2f6.jpg 1e518e56-4218-4e97-9c7e-b2ca8d72621f.jpg 9abffca4-38f5-4a61-8b2c-32f6c983a4d9.jpg 542b0335-dacc-4fe5-856b-0ee1c0935c24.jpg 2c168da0-fbed-404f-94b9-9394414f9ae6.jpg 62f9ea4b-794f-4132-816b-510209054400.jpg 9a1d98f3-3b45-44c8-9f99-5423eef3c7bd.jpg
    brEad, Tim, So Cal Brian B and 6 others like this.
  14. stillrunners
    stillrunners
    from dallas
    You experiance and photo's are going to be helping a lot of new builders get along with their project - thanks for posting !
    Outback, brEad and glorydime like this.
  15. glorydime
    glorydime
    from Austin, TX
    Man I hope so. I often feel odd posting every little thing being that so many AV8 builds prior on here are superior and doing the same thing but better. But then I think of a bunch of stuff I posted on here, mistakes and all, hopefully will help. If nothing else i hope anyone wanting to build a car like this sees this thread and can see you can still build traditional hotrods on a shoe string budget while learning the entire way to the finish line. Cant apricate the folks like yourself who motivated me via kind words.
    brEad likes this.
  16. stillrunners
    stillrunners
    from dallas
    Actually you'll be helping those one car guys that get scared off by those big shows and showie stuff !
    brEad, glorydime and OFT like this.
  17. stillrunners
    stillrunners
    from dallas
    that should be "one car GARAGE guys....
  18. glorydime
    glorydime
    from Austin, TX
    Started tackling the p***enger side exhaust run. My plan is to use 35/36 driveshaft for tips but ill need to make some connection runs down to the side of the frame. My goal is to make the tips visible but not gaudy. I am still learning to tig too so this was a bit of challenge, but I made the best of it. I bought the headers from Havlir House of Fabrication. Cant recommend these enough. Took all the hard work out of this part of the build. Honestly Dave is the only part of the car I outsourced, but i am so glad I did. I purchased a set of mandrel bend steel pipes from speedway and began planning and cut it up. The p***enger side is pretty easy being that nothing is in the way. I can tell the driver side is gonna be a challenge for me. Dave included some exhaust flanges for me to attach where i wanted. The tips extend out so i needed to install the flanges to be able to take the exhaust tips out if needed at a later time. I don't have any of the exhaust clamp holds to allow yourself to plan these easier. I just used stich magnets to hold everything in place while i made marks where to tack, then finish weld at a later time. You can see where I used two jack stands to place the driveshaft tips to get the look I wanted and build off that area.
    ad7b472c-652d-4981-b072-9e2aaedd27f7.jpg d143b7eb-a060-46a9-a24d-be43ba570ea4.jpg 64fccc08-0ad2-436f-9817-bc6e540b6918.jpg 96df1b90-fa93-4a3d-8ad9-bfb876da5aaf.jpg 77a76787-27c4-4375-8964-bfe0c23345e3.jpg 83486052-b29b-4ccc-913b-7e98af11f74e.jpg aff36f3c-0aa0-45c1-b574-ce947adc9ac9.jpg 5c91d2a1-eb7d-424a-9f36-19445e4de057.jpg 6b74b8e9-86cc-4a99-9852-030491bd9325.jpg 395c6859-05cf-44c3-bd4d-245805c52468.jpg c02e3e33-cbf6-4b04-92b8-e13b7da2a311.jpg de1a1453-a43a-4290-8ed8-d4297fa31580.jpg 5731cbfc-e7f7-40d8-83fb-55dddb4c376a.jpg 986cd47e-4128-4a61-b54a-7493f4941802.jpg
    brEad, Tim, oliver westlund and 5 others like this.
  19. glorydime
    glorydime
    from Austin, TX
    The hanger was my next challenge for these little tips. After chatting with a few friends and looking at how others have hung them I wanted to make the mount disappear which meant I needed to hit the back side of the pipe but not attach to the frame. I was able to make it work off the Model A cross member i left in the car just behind the F1 crossmember I used to mount the trans and master and pedals. If I ever end up going this route again I will not purchase a hanger I will just make one. I got this one from Speedway it was not cheap and its stainless, which was a little bit of challenge for me to weld to the steel tip. I used 308 fill rod and it worked ok. The silicon cups are where its at with these. You can buy them separate. I had to alter my hanger a little to fit in the place I wanted it but nothing fancy or hard here.
    5e3eeefb-0356-4ee3-a473-82ae64d4bc56.jpg 2e4942d1-ac14-4236-a61a-53522a60d3ec.jpg b6563383-2add-4bcf-acb2-409aadab83eb.jpg bad88565-b63c-47e1-834f-09b62d4c40b0.jpg 2467d1b3-93dc-40e9-852e-c6b9d1200c4b.jpg
  20. Squablow
    Squablow
    Looks great! All the little details coming together. I really like the headlight bar and headlight position.
    I like that battery box too. If you need to vent it, you might check out some old appliances, lots of old dryers and stoves and stuff had little louvered pieces on the back, even microwaves. Cut a little louver patch out of something, cut a hole in the box and rivet the louvers on over the top. Would look old-timey and be functional.
  21. glorydime
    glorydime
    from Austin, TX
    Damn thats a good idea! dig it.
  22. glorydime
    glorydime
    from Austin, TX
    Drivers side was much harder and actually took me two times to make it work. I am only using basic traces on cardboard and magnets to hold pieces together, but i made it work. My clutch bar is pretty high and being that the steering and master cylinder are all in this location its pretty cramped. First try i went way too low making it look ugly, second round i got it tucked more but still allowing for some heat room. I used the same hangers i used for the p***enger side and am very happy with them.
    536f61ea-333a-4460-bc53-98d9618b0d3b.jpg 7a315a71-4180-43ac-b0f9-5b9d9fb39dc2.jpg 38ffd71e-48fa-429b-ac75-5c5629930a92.jpg 870d4149-9f25-4226-bc57-a7fb5c5de2f3.jpg 9243ca61-65d4-4318-bb1a-0aab3a4b89e8.jpg 553504d8-ff6c-4d20-beb0-0fdd5db028c4.jpg dca8485e-3367-4483-b1d0-f217d3d5e7c9.jpg fd245d8d-98a9-4654-9a8f-882e7a28b642.jpg
    brEad, Tim, So Cal Brian B and 2 others like this.
  23. glorydime
    glorydime
    from Austin, TX
    As you can see from the photos my NEWB came out big time. But I remade the connection and it turned out much nicer on the eyes while still providing room enough to allow for some heat distance.
    7c023209-cce1-4b5c-b1d4-bb77474a2fd3.jpg 033a359d-b938-41ee-91dd-19ac98ca300c.jpg 56e7db53-3732-4d81-8fca-1df27beec44f.jpg a2535ffe-4bc1-449e-8445-1b1c94e2793c.jpg 3e5180ea-f1c6-44b7-a975-bca14230bb60.jpg beddefd1-21a7-4a3f-99f6-da3c648b427a.jpg e43080ed-91dd-4c1e-964b-51cba081bbd4.jpg 930024a0-a5c2-4227-a03f-180a652bb4f4.jpg a82538ea-137d-4bc2-9704-dee78731240e.jpg d929b47e-20a3-4b32-bb22-8111f7d9f668.jpg
  24. Jeff34
    Jeff34
    Very nice!
  25. stillrunners
    stillrunners
    from dallas
    Your getting it done !
  26. glorydime
    glorydime
    from Austin, TX
    Fired the motor this weekend for the first time since the overhaul. I was using a temp fuel source from just gravity feed from sitting on the cowl. Need to hook up a fuel pump to get it to idle and set timing, but no coolant running Im not gonna run it long. Nephew came over again to give me a hand.
  27. Jeff34
    Jeff34
    It's ALIVE! Awesome!
  28. glorydime
    glorydime
    from Austin, TX
    Was able to get it idling this weekend and timed. I dont have any exhaust gaskets in the manifolds so its loud up front but all good I am planning on changing heads and intake. Also I didn't run it long to not overheat, maybe 2 minutes. Pretty happy.
    brEad, roadwarrior84, Tim and 4 others like this.
  29. glorydime
    glorydime
    from Austin, TX
    After getting the motor running and idling i decided to take it back out and paint it. I went with Bill Hirsch paint. Cant recommend this product enough. I used a bit of the brush on method and some small spots with the spray paint. Degreasing that motor wasn't too bad being that i had done most of the cleaning prior when i had overhauled the motor some.
    3c7288dd-84ea-41ca-a66b-b2a616a4dbde.jpg ee56b9c8-6617-47cb-a02f-a19221a82f30.jpg 2d37425f-993a-4614-8bb7-1ca50206f0ea.jpg
    brEad and Jeff34 like this.
  30. Tim
    Tim
    from KCMO
    How cool is that! Congrats on the fire up!
