Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. Erik B
    Erik B
    087B56C6-6E00-4F7B-AFBB-849C536306C4.jpg IMG_3898.jpg IMG_2975.jpg IMG_3875.jpg Grille shell fabrication. Plaster model, wheeling panels, welded ***embly, flange for hood seal.
  2. Erik B
    Erik B
    IMG_3299.jpg IMG_3301.jpg IMG_2860.jpg IMG_3335.jpg 4F2472F5-980D-44F6-9F64-A7AD56E11583.jpg IMG_3886.jpg
    Aluminum hood was formed with a slip roller to get the arc. Flanges were made by bending up bottom edges. Support structure made by bead rolling a frame structure. Custom made goose-neck hinges for a side opening hood. Sanding out imperfections to make the polished graphic sweep.
    banjeaux bob, G Baese and rod1 like this.
  3. fredvv44
    fredvv44
    Beautiful workmanship Erik.
  4. timberwolf01
    timberwolf01
    Ned Ludd, Kume and porkshop like this.
  5. Erik B
    Erik B
    IMG_2952.jpg IMG_2954.jpg IMG_2967.jpg IMG_2946.jpg IMG_3391.jpg IMG_3390.jpg IMG_3764.jpg IMG_3606.jpg IMG_3611.jpg Wind deflectors in poly carbonate with aluminum mounts.-
    Wood rimmed steering wheel in 2 hardwoods with 6062 T6 aluminum center.
    Pedals are Wilwood units with etched copper pads.
    banjeaux bob, rod1, porkshop and 2 others like this.
  6. mohr hp
    mohr hp
    from Georgia
  7. banjeaux bob
    banjeaux bob
    from alaska
    414012007_7317643374921880_2950270041183645641_n.jpg "MARTYR" in it's current form.
  8. timberwolf01
    timberwolf01
  9. Erik B
    Erik B
    Limited production is the goal but funds are insufficient.
    rod1 likes this.
  10. Erik B
    Erik B
    IMG_4537.jpg IMG_4701.jpg IMG_3501.jpg IMG_3788.jpg IMG_4454.jpg IMG_0998.jpg IMG_1480.jpg IMG_0234.jpg IMG_0236.jpg Upper and lower A-arms with heim joint ends for adjustability. Rack and pinion steering with no bump-steer. Engine turned dash and cowl panel with bead roll. Adjustable pivot steering wheel. Front trunk with brake and clutch reservoirs. Engine turning is done with fine valve grinding paste on felt pads for deeper scratch than a Cratex stick. Lockable glove box contains front hood release lever.
  11. fredvv44
    fredvv44
  12. Erik B
    Erik B
    That looks great, Fred. Did you eyeball the spacing?
  13. fredvv44
    fredvv44
    I did it on the mill table so I cranked it the same for each spot but I was not terribly accurate with that. I wanted a bit of "hand made look" with it.
    foolthrottle likes this.
  14. banjeaux bob
    banjeaux bob
    from alaska
  15. timberwolf01
    timberwolf01
  16. timberwolf01
    timberwolf01
    1927 Benjamin/Benova B3 Sports
  17. timberwolf01
    timberwolf01
  18. timberwolf01
    timberwolf01
  19. timberwolf01
    timberwolf01
  20. fredvv44
    fredvv44
    Seeing photos like those makes me think of what the flow of life was like in those days. We get so caught up in the fast pace of theses days.
    timberwolf01 and porkshop like this.
  21. timberwolf01
    timberwolf01
  22. timberwolf01
    timberwolf01
  23. Paul
    Paul
    Editor
    has this been posted already?
    Ziggster, fredvv44, G Baese and 5 others like this.
  24. noboD
    noboD
    That's ****** cute. IS the body wood? And fenders?
  25. Paul
    Paul
    Editor
    and looks like the frame is too
  26. Speccie
    Speccie
    Paul, thanks for sharing the video on the 1919 Grafton. That looks like fun to me.
  27. coupeHEAD
    coupeHEAD
  28. j hansen
    j hansen
    porkshop, coupeHEAD and timberwolf01 like this.
  29. coupeHEAD
    coupeHEAD
    j hansen likes this.
