Hot Rods Model a gasser
Discussion in 'The Hokey Ass Message Board' started by BRENT MAGGI, Jul 18, 2022.
  1. mad mikey
    mad mikey
    Yea, have had mine on for two seasons, street strip. NO issues.
    BRENT MAGGI, 427 sleeper and Stogy like this.
  2. Hollywood-East
    Hollywood-East
    Personally... For me, This is the First thread I look for....$
    Absolutely Love the approach...
    And Am thankful, You did Exactly as I would have, Which means nothing..
    But Everything to me..haa
    Kill'n it Dog..!!
    Just Gary, Thor1, Stogy and 3 others like this.
  3. mad mikey
    mad mikey
    The picture of the seat and the inside is so Bad ***.:)
  4. Stogy
    Stogy
    I don't have a safety belt in my street Hotrod. I often wonder if they'd let me do a run whatcha' brung without it...but I'll ask for ****s n giggles if there was ever one in this warrior...I know they ran them in the dry lakes in the 40’s, especially with war stuff for nickels and dimes...kinda in a different league than mine really...if it didn't this former racer was quite adventurous and lived to tell the story...amazing really all that power and just rear drum brakes...maybe even was plated and streeted...
    Brent...just curious...
    brady1929, 427 sleeper and mad mikey like this.
  5. BRENT MAGGI
    BRENT MAGGI
    Yes there was a lap belt in the car when I first got it. Lap belt will go back in, but that’s not something I’m worrying about right now. Not sure how much it would do anyway with that seat haha. 936108D5-81C6-4ACF-A81C-0DC95853A69C.jpeg
    catdad49, Okie Pete, porkshop and 9 others like this.
  6. Hollywood-East
    Hollywood-East
    If that 70 yr + old seat belt fails, You have larger problems... Let's be honest/Clear...
    Now the seat in a racing situation... Not so much.... But God.... Who doesn't love a Smokey filled bowling alley seat!!!!
    Priceless...
    mad mikey, 427 sleeper, Thor1 and 2 others like this.
  7. BRENT MAGGI
    BRENT MAGGI
  8. BRENT MAGGI
    BRENT MAGGI
  9. BRENT MAGGI
    BRENT MAGGI
    The car has a kick panel in it again. the original one I made ended up hitting the trans after I moved the engine, I will try to rough it up a bit eventually. The car is completely wired now with a keyed shut off, and keyed ignition. I cut the battery box down today, need to bolt it down and work on shortening the cables. The gl*** brake reservoir started leaking again, need to find a permanent solution to stop the leak. I think it should be ready to fire off next week
    60E421E2-4202-47C9-B1E2-0087882A80DB.jpeg 5B936330-4129-466B-B635-1B766F11B3EC.jpeg 125F87B3-6B5B-4564-B9A8-0F7AE9EEF83B.jpeg
  10. Tim
    Tim
    from KCMO
    Is that headlight bar hollow? Can’t say I’ve ever seen anyone sneak the headlight wires threw one but it’s clever!
    porkshop, sdluck and mad mikey like this.
  11. BRENT MAGGI
    BRENT MAGGI
    I finally fired the car off. It Will need some tuning but exciting to finally hear it! Not sure the shifter is going work.. I’m going to mess with the linkage more but the gates are wrong for a reverse valve body. I’ve been working on getting the master reservoir to stop leaking- it’s a major pain in the ***!
    https://youtube.com/shorts/dljM4LvLdik?si=***aTYgiFxwwk9GS
  12. BRENT MAGGI
    BRENT MAGGI
  13. SS327
    SS327
    I can’t see the video. Guess I’ll just make engine sounds.
  14. BRENT MAGGI
    BRENT MAGGI
    it should work now. Just made a YouTube and not sure how to work it I guess.
  15. SS327
    SS327
    Thanks! Sounds snotty! I like it!
  16. mad mikey
    mad mikey
    Sounds good. The wicked little coupe wakes up and roars.:)
    SS327, BRENT MAGGI, Just Gary and 2 others like this.
  17. Tim
    Tim
    from KCMO
    Sounds great!
    You did the YouTube thing correct it’s just that YouTube makes shorter videos into “shorts” and they don’t embed. Make your video longer and it will fully embed next time.
  18. BRENT MAGGI
    BRENT MAGGI
    I’m going to end up running this b&m series 60 shifter in the car. Does anyone have the correct knob with the grove in it for this shifter? The guy I bought it from had a regular threaded one on it but doesn’t work 8C4D6109-0AB5-4827-AA12-C76A6F3F776F.jpeg CC52367E-32D4-491D-B23B-690C56BF560B.jpeg .
  19. tomcat11
    tomcat11
    If you can find one I believe a 1965 Dodge A100 shift knob will fit. Some if the very early B&M Series 60 shifters used one that is nearly identical. Some of the knobs had their logo on sides instead of what you see here. Nice to hear that thing run!
    catdad49, Okie Pete, Thor1 and 5 others like this.
  20. GoJoMoJo
    GoJoMoJo
    from Sonora
    Panella’s! They do great work! I think we had motors there at the same time. No wonder mine took so long. Lol.
    That’s one bad a$$ little g***er.
  21. -Brent-
    -Brent-
    mad mikey and BRENT MAGGI like this.
  22. tomcat11
    tomcat11
  23. BRENT MAGGI
    BRENT MAGGI
    Thank you guys. I just bought the shift knob, will see if it works! My engine was down there for a year… glad that’s over with haha.
    catdad49, porkshop, Thor1 and 6 others like this.
  24. BRENT MAGGI
    BRENT MAGGI
    The shifter is in. It seems like it will work 100 times better then what i originally had put in. Was going to fire it off and go through the gears on the stands but the car has no pedal for some reason. Bled for a hour and am getting nothing. Will mess with it more when the rain stops. 42933A84-81F4-4DE7-A53D-78C225EF20E2.jpeg
    catdad49, Okie Pete, tomcat11 and 9 others like this.
  25. slayer
    slayer
    Yea, working shifter! Booo no pedal! Good job, you almost got her licked.
  26. DESEL 32
    DESEL 32
    Now that's OLD SCHOOL right there. Glad you were able to track it down and aquire it.
    BRENT MAGGI likes this.
  27. mad mikey
    mad mikey
    The shifter looks right at home in there. Maybe pressure bleed the brakes?
    SS327 and 427 sleeper like this.
  28. choptop40
    choptop40
    That A is haunted in a good way.......I think ??
    BRENT MAGGI and mad mikey like this.
  29. wheeltramp brian
    wheeltramp brian
    I had that same shifter in my 64 El Camino When I got it 20 years ago and it worked out great. No problem but being a kid I just had to have a ratchet shifter and tossed it.
  30. Tim
    Tim
    from KCMO
    Seems like Brent and Brent need to get there 60’s style model A racers together for a little trouble making
    catdad49, Thor1, slayer and 5 others like this.
