Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
  2. squirrel
    I set up my old Delco tach drive single point vacuum advance distributor the week before last...no machine, just used the timing light, it works pretty well now.
    This is a before picture.
  3. D2Denny
    D2Denny
    Pulled the body off my 31 Tudor A to prep the frame for an 8BA, 39 trans, and 40 Banjo rear. Ran out of storage room on the shop floor for the body so now I have a 4 door 1962 Mack B-75. IMG_1180 (convert.io).jpg IMG_1183 (convert.io).jpg
  4. That Mack is Gorgeous!! What engine and transmission are in it??
  5. lumpy 63
    lumpy 63
    I want a crackerbox with a big screaming detroit:cool:
  6. patsurf
    patsurf
    well,the dog isn't gold...
    427 sleeper likes this.
  7. D2Denny
    D2Denny
    Truckdoctor thx for the compliment END673 170 HP Double over triplex
    Lumpy Speak louder. Spent time around Freightshakers with 8V and 12V71's 50 years ago.
    Patsurf Gold dogs came out in 67 with the maxidyne R models
    Truckdoctor Andy and lumpy 63 like this.
  8. patsurf
    patsurf
    thanks for the education-thought it was 'since ever' for 'full mack'...
  9. TA DAD
    TA DAD
    from NC
    So with the points wired together do you just set the gap and not worry about the dwell. I just set up a GM dual point tach drive with GM style points and it was wired the same way as yours which I found odd. But I only put one set of points back in it so not a big deal. All the ones I have set up in the past had individual lead wires .
  10. lumpy 63
    lumpy 63
    20240106_141602.jpg More Rat motor goodness today.
  11. Very cool! Is that the Willys Go Devil engine?
    deathrowdave and anthony myrick like this.
  12. The military version.
    I guess the big difference is the waterproof dizzy and wiring. probably 24v as well.
    Truckdoctor Andy likes this.
  13. Lloyd's paint & glass
  14. lumpy 63
    lumpy 63
    Thanks Lloyd. Going in a slightly off topic Shovelle:cool:
  15. I’m hot on an O/T shovelle, not that one^^^
  16. choptop40
    choptop40
    image.jpg . Arrangements to have the 50 delivered…
  17. saltflats
    saltflats
    from Missouri
    We always try and find one of the rental houses when we travel in a group.
  18. kls50
    kls50
    I bought the black wheel in 2014 from a hamber and repaired it with some two-part epoxy putty from Amazon in 2015. ($50.00) I was lucky enough to find an original horn ring and had it re-chromed. and bought a new horn ring ****on for it along with the hardware to install it.(NOS) I recently bought the other wheel to repair and purchased a Lime Works horn ring and ****on. I plan on putting one on my 1950 Ford coupe and the other one in a display case, along with some other 1950 Ford stuff. I am currently repairing and painting both wheels. The horn ****on in the last picture will be for sale. Sorry, the wheels are not for sale.
  19. spanners
    spanners
    Careful Anthony, you'll get roused on for speaking Australian calling it a dizzy.
    61Cruiser, anthony myrick and twenty8 like this.
  20. Easier to spell
  21. twenty8
    twenty8
    Great, now you'll have to explain "roused on" to them all..........:D
    61Cruiser likes this.
  22. DIS-TRIB-U-TOR!!! Sound it out, just like you were taught in elementary school!
    Geeze.... how soon sum peepl firgett there book lurnin'
  23. atch
    atch
    At Lloydfest last year Sherry and I stayed in an Airbnb. We liked it and plan to do that more often.
  24. lumpy 63
    lumpy 63
    20240107_103801.jpg 20240107_140037.jpg Worked on modifying a new Chevy AD ch***is to accept a gear vendors overdrive:D
  25. Weekend distraction from the 56
    292 inspection. Removing the air compressor.
    Used a bore scope and cyls look great. Super clean on the inside. Clean behind the side covers and under the valve cover. Might just do a reseal if the comp numbers are good.
    2 plugs had fouler tips. Guess I’ll look at valve stem seals then the guides.
    The point mounting plate was loose and the advance disconnected
  26. Anthony, is that 292 out of a medium duty C-60 or 70? I’ve never seen a Chevy 6 from an air brake truck! That looks like one tall engine.
    anthony myrick likes this.
  27. C60 dump with air brakes. Compressor still pumps. First for me as well. But it’s factory. Cast 6 cyl only bracket and a special side cover with oil return. The pump is plumed into the oiling system.
  28. lumpy 63
    lumpy 63
    Whats it going in?
  29. My sons 61 Chevy c40 has my 350 in it. The 350 has a mild cam and 461 heads. Kinda doesn’t like lugged around in the big truck. The plan is to use the 350 in the wife’s 56 and put the 292 in the truck.
    It was born with a 235 and I almost put a 261 in it. The 292 is cheaper and easier.
    TA DAD, Moriarity, Johnny Gee and 4 others like this.
