Technical Need 40 Ford steel wheels to work with disc brakes
Discussion in 'Traditional Hot Rods' started by Ernie Gentile, Jan 7, 2024.
  1. Ernie Gentile
    Ernie Gentile
    I just upgraded my 40 deluxe front brakes from drums to rotors. The offset inside the OE steel wheels hits the calipers. I put 1/2 inch aluminum wheel spacers and now they clear. For safety reasons I would rather the lug nuts to tighten down further and be able to get more threads on them. Any thoughts on this? Suggestions on the wheel replacement? The rear wheels are totally fine because I left the drums on the rear axle and the lug nuts go all the way in. Thank you!
  2. razoo lew
    razoo lew
    from Calgary
    Get longer wheel studs installed?
    alanp561, 05snopro440 and Pocket Nick like this.
  3. verde742
    verde742
    grind the rotors, put a little chalk on them to see where they rub...
    It won't take much grinding
    alanp561, LOU WELLS and hotrodjack33 like this.
  4. Get longer studs. Probably easier than tracking down a pair of good wheels, then cleaning them up, painting them, mounting tires on them, etc. A stud swap could be done in under an hour and is much cheaper. If you have at least 1/2" of thread engagement on a 1/2" stud then you're golden, the fastener won't be any stronger with excess threads poking out. A picture would tell us what is going on.
  5. Budget36
    Budget36
    Keep in mind, your front track width may have gotten wider with disc swap. Now you added spacers.
    Suspension guys will know the words and why that may not be a good thing.
    Scrub?
    alanp561, HemiDeuce and X38 like this.
  6. X38
    X38
    You have original Ford 5 1/2 inch pattern 16" wheels?
  7. 05snopro440
    05snopro440
    What size and bolt pattern are we talking about?
    If there's no problem running the spacers (track width is fine, etc.) then just get longer studs. I've been running aluminum spacers on the front of my OT S10 for 22 years without issue. I think mine are 1/4 or 1/2".
  8. hotrodjack33
    hotrodjack33
    I ran into the same problem on my old Sedan Deliv. with the 11" GM rotors/calipers. Took an angle grinder and "trimmed" offending corners on the caliper. Didn't take much...maybe took a 1/32 off.
  9. pprather
    pprather
    If the interference is only 1/32", as Jack estimated above, can you replace the 1/2" spacer with a thick washer on each wheel stud?
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Would not recommend washers with early Ford wheels. They will not seat correctly. A thinner solid full surface spacer would be best. IMG_2391.jpeg
    alanp561, pprather and Moriarity like this.
  11. krylon32
    krylon32
    from Nebraska
    I've got Super Bell Power Stoppers on my 40 coupe with WheelSmith 15X5 inch wheels and no spacers. The stock length studs worked fine.
  12. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Modern wheels have a different shape on the backside to clear disc brakes better. Are you using 15" wheels?
  13. 29Sleeper
    29Sleeper
    from SoCal
    Using flat spacers means the wheels are located on the studs not the hub. It also puts the lugs into a shear condition rather than just tension holding the wheels. If you use spacers try to find "hub centric" ones. You can get a set custom made on Amazon for about $40.
  14. krylon32
    krylon32
    from Nebraska
    With the right wheels you need no spacers, adapters or longer studs. Do it right the first time without band aids. Call Wheel Smith and talk to REX, explain what you have for brakes, axle width and intended tire size. He should be able to get you on the right track? He's helped me many times.
    joel and X38 like this.
