Having a body dipped for rust/paint removal...PROS and CONS???
Discussion in 'The Hokey Ass Message Board' started by batt69nova, Apr 11, 2012.
  1. Bert Kollar
    Bert Kollar
    My avatar coupe was chemically stripped 30 years ago and the paint is still as applied. Chemical is way better, it gets ALL THE RUST but is must be properly done.
    C69A and osage orange like this.
  2. koolkemp
    koolkemp
    Thats gonna need a ****load of bracing before it comes off the frame to be dipped!
  3. You might not get much back from the dipper. Can you find a better body tub to work with ?
    Resurrecting that old girl is going to be an adventure.
  4. zman
    zman
    from Garner, NC
    Bingo...
    The place I use not only neutralizes it but also dips in on OSPHO as well. Haven't had any issues. And my PPG rep knows and hasn't said anything about it. :rolleyes: They bad thing is it takes all of the rust away and you will be surprised as to where there are now holes.
    jazz1 and osage orange like this.
  5. 56sedandelivery
    56sedandelivery
    Years ago, there used to be a Redi-Strip of Puget Sound, in the Georgetown area of Seattle. I took the doors and trunk lid from my 56 Chevrolet bracket car in. There was an old gas cl*** Anglia there also. They dipped the entire body/frame of the Anglia together. I don't know how the frame stayed attached to the body when they pulled it from the tank. It had been so rusty, had so much bondo, and had really "hacked up" type of work done to it, that there was little of the car left. I bet the owner was just sick after seeing it. I had the hardest time getting ALL the chemicals out of the seams in the doors/trunk; the chemicals would leach out no matter how much I washed them. But, they were absolutely free of ALL rust and paint. Butch/56sedandelivery.
    Chainsaw chipper likes this.
  6. Well, there you have it. Weld off the old paint and rust
    BTW, no one wants to hear about your 2". My condolences :(
    Chainsaw chipper, BJR and 6sally6 like this.
  7. GassersGarage
    GassersGarage
    Back in the '80's, a friend of mine was building a '53 Ford F100. He had the body dipped then proceeded to build a show stopping show truck. Within a year, he asked me if I wanted to buy it. As a joke I said I'd give him $3000 for it. He agreed which floored me. I asked him why? He said the acid was bubbling the paint and he felt the truck would fall apart eventually. He ended up trading it for an old Porsche 912, which wasn't woth anything back in those days.
  8. batt69nova
    batt69nova
    from OR
    It's already been braced a lot.
    I don't have a current pic and the floor isn't skinned yet, but the bracing is in. It's in the factory locations, but is made out of rectangle tube and thick steel, instead of trying to recreate bracing by bending and sandwiching sheet steel like the factory did.
    Since the car was not really supported at all, we used straps and jacks to get the body "square" and adjusted the doors so they closed nicely. Once the doors were in a good position, we welded in what you see here:
  9. johnnystang
    johnnystang
    could you tell me who you had dip and e-coat your project. Looking to find a place before i purchace a project car, thanks.
  10. Bandit Billy
    Bandit Billy
    The hood on my 41 had rust I could not remove sanding so I took it over to American Metal Stripping (I think that is what it is called) over by Jubitz Truck Stop in Delta Park. They did a fine job and I saw several car bodies while I was there in bare steel. Nice people, helpful and fast.
    One word of caution don't google "Portland area strippers" on your wife's computer.
  11. Mr48chev
    I always have at the clowns who say "but you won't get much back if it is real rusted" You ******** didn't have anything to work with to begin with if it was that rusted out.
    Back in 2013 Steve Frisbie (Steve's Auto Restorations) had the Ron Dunn shoebox Ford at the Portland roadster show as it was bought.
    In 2014 at the roadster show they had it in bare metal after it was stripped.
    I'm thinking that the same shop that did Billy's hood did that car. The cost isn't cheap by any stretch remembering what it cost to have my hood stripped in Tacoma before it was Louvered in Bremerton in 1981.
    Ideally you would stick it in an oven the same as a powdercoat oven after it was all dipped and rinsed and bake any moisture out of it.
    Gasser 57 and Bandit Billy like this.
  12. Hemi Joel
    Hemi Joel
    from Minnesota
    Restoration spe******ts in Franklin Wisconsin.
    (414) 529-1515
    kabinenroller and 1933_willys_77 like this.
  13. firemangordy
    firemangordy
  14. I've also used Restoration Spe******ts with great results on the recommendation of @kabinenroller.
    @johnnystang you didn't fill out your profile so we don't know your location
    kabinenroller likes this.
  15. 6sally6
    6sally6
    How old are ya ?! (Why you axe)
    IF you're in your 60's or 70's like most of us....why go to the expense of removing EVERY piece of rust on EVERY section of the car ?! POR-15 the spots you can and roll on.
    When you die your wife is gonna sell it no matter what she sez now.............jus kidd'in...not...prolly!
    POR-15 when applied to THE RUSTED AREA will turn it to gl*** and perserve it (but you know this prolly)
    It should preserve it for 10+ years before it "might" come back !
    What do you care when you're dead .... or too old to drive?!
    You DO KNOW this is coming...right !
    Enjoy it as soon as you can........let the next young stud streetrodder worry about it after you...............uh.....go.
    6sally6
    osage orange and nochop like this.
  16. zman
    zman
    from Garner, NC
    Note, never ever buy a car from 6sally6.
  17. kabinenroller
    kabinenroller
    As mentioned above I highly recommend Restoration Spe******t in Franklin Wisconsin. They have been doing work for me for quite a while with zero issues.
    The key to a good job is preparation!
    After the parts are chemically stripped they should be ecoated. ( you don’t paint a part without primering it first do you?) After ecoating the surfaces should be scuffed with a Scotch brite to promote adhesion. I have never had issues after the process, over the years I have had many parts and bodies stripped.
    Here is my Cyclone with the body stripped ( fenders and doors have been ecoated already) and the body after ecoating. I normally have the parts stripped “80%” then bring them back to my shop for metal work, when the fabrication and metal work are completed I send the parts back for a final strip and ecoat.
  18. zman
    zman
    from Garner, NC
    One of the big things I liked about our local place is they dip it in a neutralizing bath after the acid and then will dip it in OSHPO as well.
  19. bantam
    bantam
    My dad had his T Tudor sedan dipped 20 years ago. All bodywork done in lead and an absolutely beautiful paint job put on the body. Within a few years acid came of the seams. Terrible.
    20 years later the dipping industry may have significantly approved. No e-coat for my dad, for instance. That said, his result makes me never want to dip a car.
  20. Hemi Joel
    Hemi Joel
    from Minnesota
    Or especially his wife! :D
    I get what he is saying, though. Some cars are worth going the extra mile and dipping/ecoating, and some just aren't. But the older I get, the more inclined I am to spend my remaining time only on cars that are worthy of going the extra mile for.
    SS327, down-the-road and loudbang like this.
  21. I dipped my '29AA more than 30 years ago. They finished it with Ospho and I followed their instructions to get it in epoxy ASAP, then in high-build primer when I was ready. I've since sealed it after finishing the body work and sanding down to 400. No rust after all these years, but I'm still not on the road yet.
    down-the-road and SS327 like this.
  22. Fordors
    Fordors
    I had my 5W dipped at Redi-Strip in Des Plaines, IL way back in ‘72 or ‘73. I let it sit for a while, then washed it down and used Metal-Prep to give it a final clean, primed it inside and out and nothing has ever leached out on it. I’m pretty sure the Redi-Strip process included a neutralizing dip but that was a long time ago :confused:
    The cost back then? $90 !!!, and they knocked off $15 for damage to the belt line on the drivers quarter panel where it was struck by their forklift.
    The photo was right after we brought it back to my garage. Obviously I wasn’t much of a photographer with my Kodak Pocket Instamatic.
    down-the-road likes this.
  23. 56Packard
    56Packard
    from Phoenix AZ
    I won't do a dip, better to blast
  24. zman
    zman
    from Garner, NC
    Why? You can't just drop that on your 3rd day here and not explain.
  25. RacerJames
    RacerJames
    So I'm in northern AZ, closest to me would be Vegas. My car is from SLC by way of NYC so it be rusty. It's around 5 days round trip travel to get my parts to either Oregon, Michigan or the Carolinas. Tried googling a place closer that doesn't charge CA prices with no luck. I'd prefer to go to the Vegas, Phoenix, or Albuquerque areas. Anyone got a lead on a "desert" dipping company?
  26. chickenridgerods
    chickenridgerods
    from DSM, IA
    Did you try a Google search for "Arizona vehicle dipping" or similar terms? This company is one of the first results it gives me. YMMV.
    http://xpressmetalcleaning.com/
  27. Mr48chev
    It looks like Xpress metal cleaning gives chemical dip or blasting options.
    Still local feedback from car folk in AZ counts a lot.
    I'm not sure what shop in the Portland Oregon area did the Ron Dunn Shoebox but it came out clean and spotless when it was at the Portland Roadster show 10 years ago. A couple of the Portland area metal stripping shops usually had displays at the roadster show every year that one could check out.
  28. patsurf
    patsurf
    wow!!nice
  29. jazz1
    jazz1
    Never dipped but i always spray Fluid Film or similar product into areas i cant access including frame after its been boxed.
    I sandblast,,it’s the most fun you can with your clothes on.
