Projects Going rate to replace the wood in a vintage truck bed?
Discussion in 'The Hokey Ass Message Board' started by 32Tudor, Jan 8, 2024.
  1. 32Tudor
    32Tudor
    I have a 52 Chevy 5 Window pickup project that came to me partially ***embled. I am doing it as time and materials. I have a new bed wood kit and the old bed is taken apart and most of it is filled and painted. I would like to know what the hour expectation is to ***emble and trial fit the wood, then finish it and do final bed ***embly? I watch Brothers YouTube and he does a great job but I am finding it is taking a lot of hours. Just curious what professionals might estimate to install a wood kit?
  2. Mr48chev
    That pretty well depends on the level of perfection you want or settle for. Sanding the wood, laying on each coat of finish, sanding between coats if that is what is needed. ***embly just depends on your work speed.
    alanp561 and Pist-n-Broke like this.
  3. rusty rocket
    rusty rocket
    I’m a trim carpenter by trade,. Sanding takes time if the wood is ruff. Don’t cut corners and work your way up with the grit of paper. Finish can be as simple as a hand rubbed danish oil finish or an automotive clear coat. It just depends on what you are going to use you truck for.
  4. 32Tudor
    32Tudor
    Thanks for the replies. I have a center engine ski boat and a common problem is rotted stringers. the replacement cost of the stringer job is between $6k-$8k. What I was hoping to get from this post was a ball park of what people that don't do the work themselves are paying to have new bed wood installed. I am guessing it is around 20 hours of work? This is my first one and I may be a little slow compared to a seasoned professional, which is why I am second guessing my billing on this phase. Yes, I tend to give away free hours on stuff if I feel I am not as fast as I should be.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    IMG_0322.jpeg I installed one in my 50 .
    I used hand cut wood without the Babbitt.
    Used stainless screws in the channels instead of the provided hardware. Worked out great. 20 hrs seems like a good number.
  6. continentaljohn
    continentaljohn
    As said fit and finish of the wood floor will be the variable. As a wood mahogany boat builder. We finish our wood depending on the placement and can it be seen A surface,B surface and so on . So on the A surface we sand up to 320 and then apply varnish. We then sand up to 5000 and then polish. I think a wood bed on a old truck is beautiful . I dig when they use figured or exotic woods .. So it depends if your going to use the bed to haul treasures or ? 4211365D-DD67-4381-B4A3-3B259888F975.jpeg 7BA28312-ED81-4018-B8AF-9D683F617AF9.jpeg C203BAEA-8A3D-4897-9EC5-7AA0A084D106.jpeg DDFBF1AE-1DFB-4AD8-B57F-142846512417.jpeg B91A77E2-69E4-4FBE-862E-D337A79C2330.jpeg
  7. Budget36
    Budget36
    Hi John!
    continentaljohn likes this.
  8. Budget36
    Budget36
    For the OP, does the owner have expectations of a show truck, or?
    Will it sit outside, etc.
    I was the “bolt grabber and holder” for my dad as a kid, he had already removed the wood from his ‘57.
    He spent a Saturday sanding it, raising the grain with water, all day doing that.
    Let it site out all week. Then he stained it with something the next Saturday, let it all dry.
    I placed bolts and that the following Saturday
    I don’t have any memory on hours. But 20 (in my mind) seems low.
  9. Joe H
    Joe H
    I just looked at a '67 Chevy truck that came out of a Me*** Auction. A lot of money was spent on the purchase, truck looked pretty good at first glance, then as looked it became clear it was spit and shine job. What really stood out was the bed wood, one coat of varnish, no sanding, and random cut lengths. They were so badly cut, an aluminum strip from the local hardware store was screwed over the ends to hide the poor craftsmanship. Not only that, as the wood went around the wheel wells, it just straight cut, not trimmed to fit the radius of the metal. I would say this was a 20 hour job.
    alanp561 and 5window like this.
  10. jnaki
    jnaki
    Hello,
    As a woodworker and home owner with plenty of projects calling for surface protection from the elements and dings, be careful as to guaranteeing scratch proofing for the truck bed. We have used plenty of commercial products on all sorts of woods, soft to hard. As nice as the final finish is concerned, they all scratch or crack upon heavy loads or just about any loads on top or near. But, they look fabulous when finished.
    Truck beds that have steel strips are a little better as the strips give is some elevated surfaces to slide a box or two or even larger items. But, when something like a Harley Sportster is in need of "trucking" home due to engine difficulties not being able to fix by the side of road, puts immense pressure on the treated wood and metal strips.
    Jnaki
    Of all of the products we used, the smooth finishes are pretty much the same. It comes down to the wood used in the original layout as to how it will look with the finish put on the surface. Of course, you are going to put the stuff on the whole surface, edges and ends. (not just the top or bottom. ) "Water always wins" is something we have always kept in mind during our surf travels and living by the ocean all of our lives. It creeps into the smallest areas and resides to do damage, sometimes sight unseen.
    So, if you are doing the wood/metal job for a customer, it is not good to tell them it is waterproof. Nothing in a truck bed is water proof, except for rubber mats and that sprayed on coating. We have done many different treatments on various types of wood, such as wood for hatch boards +railings on sailboats. The elements are as harsh as possible staying outside in 366 days and nights in all weather conditions and sun.
    But, eventually something finished stays that way until a tool is dropped or a slight jar hitting an edge of something damages the surface, as little as a small bump starts the cracking and water soaking process.
    Note:
    One time the longest lasting wood surface protectant was a Polyurethane coating of three layers with sanding between each layer for an absolute protection on Oak wood. Not strips for a truck, although we did use it on that surface, too. but on an antique high chair for our toddler son.
    Of all the trials and errors of wood surface protectants, this Polyurethane product was almost bullet proof. Well, at least it was knife and fork proof. The various time of hitting the edges and points on the surface by a healthy, hungry kid, the wood surface never cracked. All it took was a nice biodegradable cleaner wipe on/off and we were in business for the next round of food. YRMV
    Note:
    To test the surface protection, my wife tried the sharper knife and fork test. The point went in slightly, but did not crack the layers to the wood. The fork points of our own utensils hardly scratched the surface...pun intended.
    There is no going rate. What is your time worth? How do you spend it and calculate the cost when something is drying on a rack? We all judge what we are worth when doing projects. If you are a custom hot rod shop, you already have a minimum rate for jobs. If you are doing a friend a favor, minimal cost is always good for friendships. Materials cost is mandatory, but perhaps, friendship is more important than time spent on the labor. YRMV
  11. Roothawg
    Roothawg
    That boat gives me wood! See what I did there?
    alanp561, fauj, Bandit Billy and 2 others like this.
  12. patsurf
    patsurf
    no bearing matl for the wood?
  13. Petejoe
    Petejoe
    from Zoar, Ohio
    I don’t understand. Please explain.
    guthriesmith likes this.
  14. X-cpe
    X-cpe
    I think the word that auto correct changed to Babbitt was Rabbet, which is a groove cut into the edge of a piece of wood.
    Toms Dogs, The37Kid and 5window like this.
  15. 05snopro440
    05snopro440
    Which is a great example of why people claiming that the sky is falling out of the cl***ic and custom car market based on auction values is silly. A lot of cars get "dressed up" for the auction.
  16. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, 32T;
    Might try checking w : horkeyswoodandparts.com .
    Bruce might be able to give you ballpark #'s. He's done these kits for decades+, vendor at Btt50's & I'd guess NSRA. His stuff seems to good quality.
    Kit could be one of his?
    FWIW.
    Marcus...
  17. 05snopro440
    05snopro440
    Being in the middle of removing the bed out of my truck to remove the old finish and refinish it, 20 hours for the job you're doing sounds more than reasonable. I could see 15-30.
    The time needed to finish the wood can easily be underestimated, but it's a time-consuming task.
  18. RodStRace
    RodStRace
    You know that you tend to undervalue your work, and the job was time & materials. The first time you do something, it will always take longer. Once you become skilled, the profit from your labor goes up, but it should never be a loss. I'd suggest that you should bid high, and either the job sells and you make money or you don't do the job. Your name is going to be on the finished product and you have to eat.
    Since you have experience and figures on how much you tend to be low, use a percentage to 'pad' your numbers to reflect actual time. This is often the amount that covers the phone calls, interaction with the customer and other non billable hours. Don't be afraid to charge more for customers that use more of this valuable time. The guy that says "I trust you, let me know when it's done and what it cost" is taking up less than the guy that wants exact time and cost and requires updates. The former is the one you want to develop a relationship with and will be a valuable reference. The latter guy is going to want more of that business time and expect discounts later.
    clem, fauj and 05snopro440 like this.
  19. Petejoe
    Petejoe
    from Zoar, Ohio
    Oh I see. Yep sorry meant Rabbet
    continentaljohn and fauj like this.
  20. Bandit Billy
    Bandit Billy
    Like it was said earlier it all depends on what level you are trying to achieve.
    If you finish the bottom side like the top...
    Recess some hold downs...
    Turn the stainless...
    20 hours may not be quite enough. I imagine I easily tripled that figure.
    :cool:
  21. KenC
    KenC
    Well, I started with rough cut, air dried walnut. Planed to thickness, ripped to width, sanded all 6 sides to 320 with a random orbit air sander. Then cut the rabbets in the edges. I didn't keep close accounting but probably 12 hours to that point.
    Then coated all six sides with an epoxy bar top coating, twice, sanding flat between coats... Actually that may be 10 sides with you include the rabbet sides/bottom. Then sanded flat again and stored. That probably took 8 hours
    Next step, just before installing in the truck will be 3 coats of automotive clear over the epoxy, cut and buffed of course. Silly but that's what I want. The clear is actually needed as the epoxy stuff doesn't stand up well to sunlight. And the epoxy is much cheaper to fill the wood pores that a whole lot of clear
    Probably 12 hours there too.
    So 20 should cover it, IF you have the correct tools. When figuring cost to a customer be sure to include plenty of sandpaper etc.
  22. nochop
    nochop
    from norcal
    Find a take off bed from a utility bed company and Rob the steel bed. Skip the wood.
    Fitty Toomuch and alanp561 like this.
  23. donsz
    donsz
    Budget36 likes this.
  24. gene-koning
    gene-koning
    Back in the 30s & 40s, that wood floor in the Dodge pickups would have been painted black, along with the entire inside and outside of the bed, unless the original buyer sprung for a bed color option that matched the cab color.
    None of that fancy stained wood stuff.
    Lost in the Fifties likes this.
  25. patterg2003
    patterg2003
    Quote a higher price and if it is accepted as others have said. If the work takes less hours then reduce the invoice to the lower cost. That way you were paid to learn and in return are fair to the customer.
    RodStRace likes this.
  26. TwistedMetal
    TwistedMetal
    from Wisconsin
    I will be trying these on mine. Menards also sells lumber.....boom done.
  27. krylon32
    krylon32
    from Nebraska
    Time & material.
  28. Rarefish383S
    Rarefish383S
    That is beautiful!
  29. Rarefish383S
    Rarefish383S
    Just from a different angle, look for different sources of wood, nice wood can be expensive. I built this wagon out of 50+ year old White Oak fence boards. Found a farmer putting in new fences. Boards were pure bleached out gray, cow **** stained boards. FREE. I ran them through a planer till I got the honey color I wanted. The stringer kit was for a Chevy C10. If I were putting them in a street rod, I would have sanded to at least 1000 grit. But, it's just to display my chainsaw collection on.
    Toms Dogs, tjet, osage orange and 5 others like this.
  30. tjet
    tjet
    How wide is that gap between the boards?
    I need to calculate my project materials.
    Also, how thick are these boards you guys are using?
    The wood I'm looking at is 1" and 5/4"
    Rarefish383S and Bandit Billy like this.
