COE 1954 GMC COE BUILD THREAD
Discussion in 'Off Topic Hot Rods & Customs' started by neverdun, Oct 16, 2023.
  1. neverdun
    neverdun
    I started with a complete truck restore cab. T 20230901_123954 (1).jpg 20230901_124015 (1).jpg hey say start with the best you can so I did.
    RMR&C likes this.
  2. neverdun
    neverdun
    RMR&C likes this.
  3. neverdun
    neverdun
    I spent this weekend removing the entire drivetrain. Going to the s****yard unless someone wants it.
  4. neverdun
    neverdun
    I built a jig and set it on it. Next weekend I hope to get everything stripped and Z the rear of the frame. Possible start on the crossmember install for the front suspension.
    b-bop likes this.
  5. Badmoonreizen
    Badmoonreizen
    from Howell, MI
    You followed good advice! A beautiful cab, and you are going full-bore ahead.
    Congratulations!!
    Regards, Mark
    neverdun likes this.
  6. neverdun
    neverdun
    The frame is "Z'd" and my welder took a ****. No worries.....The rear is sitting on jack stands tacked to the jig. The front crossmember is almost finished too. Lots of welding next weekend! 20231028_175959.jpg
    b-bop and Getfuzzy like this.
  7. neverdun
    neverdun
    Change of plans, Swapped the frame for a 2004 GMC crewcab short bed, Bagged the front , The cab is mounted. Engine is just sitting on blocks here, thumbnail_20231223_155018.jpg thumbnail_20231223_155031.jpg thumbnail_20231223_194447.jpg
    b-bop likes this.
  8. wetskier2000
    wetskier2000
    from NH
    Looking great! Good idea starting with such a nice cab. If I were to do another COE, I would look much harder for a solid cab. I certainly enjoyed patching mine back together and learned A LOT but the amount of time was huge...
    what's the tape outline on the LF fender?
  9. neverdun
    neverdun
    Wheel centerline. Better than writing on the body.
  10. wetskier2000
    wetskier2000
    from NH
    Got it... sure was hoping it wasn't a cut line on that beautiful sheet metal....
