Hot Rods How about some love for the T-Bucket?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, May 9, 2021.
  1. Tim_with_a_T
    Tim_with_a_T
    ^^^^OOOOOHHHHH ME LIKEY
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Dennis,
    I remember looking at one of Randy's cars real hard in the early 70s but I can't for the life of me remember how the steering was set up. It did have the almost vertical column and he drove it like a school bus. (A bit faster though:D)
    Driver50x likes this.
  3. 53olds
    53olds
  4. Snicklefritz65
    Snicklefritz65
    from Mass.
  5. wheeltramp brian
    wheeltramp brian
    Those front slick tires are awesome. I'd love to have a set.
    Jim Bouchard likes this.
  6. Snicklefritz65
    Snicklefritz65
    from Mass.
  7. denis4x4
    denis4x4
    from Colorado
    Those look like tractor front tires with the center rib ground off
    Deuces and Jim Bouchard like this.
  8. Frames
    Frames
    Have you ever seen a Schroeder with the column coming out low? A little better steering wheel angle. I ordered them that way when Schroeder was still in business. Same lower column 2024-01-10 12.32.23-1.jpg 2024-01-10 12.32.23-2.jpg 2024-01-10 12.32.23-3.jpg with a right side steer Mopar box. PS; Note the brake pedal in the 1st picture. More K I S. Pedal pivots on the steering extension tube.
  9. wheeltramp brian
    wheeltramp brian
    I thought about buying some ribbed Front tractor tires for my 29 altered a couple years ago and shaving the center ribbed down as there only 40 bucks each.
    Deuces and bchctybob like this.
  10. guilld
    guilld
    High test 63, Driver50x and 53olds like this.
  11. Tim_with_a_T
    Tim_with_a_T
    Any more pictures of this one, besides the two posted? I haven't seen this one before, and I really like what I'm seeing.
  12. Dave G in Gansevoort
    from Upstate NY
    I wonder if they were motorcycle slicks from the 60s. They'd have been available in 16 in rim diameter, and not extremely wide.
    Snicklefritz65 likes this.
  13. lake_harley
    lake_harley
    I'm thinking if the tractor front tires even had a speed rating you're fortunate you only thought about shaving off the center rib and running them at "non-tractor" speeds.:confused:
    Lynn
  14. 40ragtopdown
    40ragtopdown
  15. Snicklefritz65
    Snicklefritz65
    from Mass.
    good point. bike slick options in that style were certainly more plentiful than now.
  16. 40ragtopdown
    40ragtopdown
  17. DDDenny
    Deuces likes this.
  18. Snicklefritz65
    Snicklefritz65
    from Mass.
    i'm trying to locate where i sourced the pix in the first place. in the mean time this is what i have.
    chriseakin, Outback, Sancho and 9 others like this.
  19. Dave G in Gansevoort
    from Upstate NY
    You know, looking closely at the picture of the tires, they may just have been narrow tires run on a tire truer to shave off the tread. You can sort of see some remaining tread pattern
  20. nitrobrother
    nitrobrother
    That last picture: Pulling the car out of the garage to start the engine for the first time, all your rodding buddies present to help out, neighborhood kids hanging around watching the goings-on and catching the hot rodding bug. Way cool...wish that would have happened in my neighborhood.
  21. Snicklefritz65
    Snicklefritz65
    from Mass.
    i hear ya. i ran into similar disapointments.
    good thing i'm an introvert.
    Outback, Deuces and nitrobrother like this.
  22. Snicklefritz65
    Snicklefritz65
    from Mass.
    it's a curious thing. i know a later version of ivo's t had regular cheaters on the front after barris got his hands on it. but this car seems like a lot less show and more go so i wonder what's going on here.
  23. RodStRace
    RodStRace
    1st pic, topping up the radiator, fixing the headers to the car
    2nd pic, first start, turning the key while working the throttle
    3rd pic, Before or after first start. Maybe it didn't fire, and they are diagnosing. Appear to be looking at the crank pulley. Maybe the camera stopped the fan and they are checking timing.
  24. Tim_with_a_T
    Tim_with_a_T
    That thing is BAD! I love it. Thank you for posting.
    High test 63 and Snicklefritz65 like this.
  25. wheeltramp brian
    wheeltramp brian
    I ended up getting the car running. But I never planned on putting it down a track or at any speed. It was just to look at. I ended up finding a used set of tires for the front.
    chriseakin, Outback, jnaki and 8 others like this.
  26. GuyW
    GuyW
    Mickey Thompson wrote about this in his autobiography (1964-ish). He ran the farm implement tires on his race car at Bonneville and the lakes, but said he later found out they were rated for 25 MPH (IIRC).
    The other factoid that stuck with me was his happiness at obtaining a cylinder boring machine - he raided the dumpsters behind FORD dealerships to salvage the useable parts to use in his flathead race car engines - and with the boring bar he could bore each cylinder for a specific salvaged piston...
    Outback, Driver50x, bchctybob and 3 others like this.
  27. 40ragtopdown
    40ragtopdown
  28. 40ragtopdown
    40ragtopdown
  29. twenty8
    twenty8
    ^^^ Great. Now I have another pic saved for a possible future build. That is the duck's nuts right there....^^^
    Any more info @40ragtopdown ?
  30. DDDenny
    Right on!
    I'd stop eating my pizza and walk across the street to check that out, not much gets in the way of my pizza either.
    Outback, Driver50x, Deuces and 3 others like this.
