Hot Rods Horsepower minimum, got a number?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 10, 2024.
  1. Mr48chev
    It's funny but I have a little box with wheels with 130 hp that would run a lot of 300+ hp cars into the ground on the long roads when you get up to real road speed for hours on end. I've been thinking about putting the motor in a T modified and figuring out final gearing to be the same as it is now and going out to play.
    Ned Ludd likes this.
  2. twenty8
    twenty8
    .....o_O
  3. wheeldog57
    wheeldog57
    The Chevy has a whopping 200RWHP and it is fun. Anything I put together moving forward will need to have more than that!
    Sharpone likes this.
  4. twenty8
    twenty8
    Straight up legitimate question.......
    As you say, power = torque * rpm. Wouldn't that mean that the only way to add power is to increase torque, or to raise the rpm where your torque peak happens? I don't get how else you can "insert more power" when power is a function of torque and rpm.
    SS327 and Ned Ludd like this.
  5. Kerrynzl
    Kerrynzl
    Power is Torque x RPM.
    there is 2 basic methods for more power , Increase Torque, or Increase RPM [without losing torque]
    All the car really cares about is Power [or torque if you want to argue] at the rear wheels
    There can be 2 different engines with the same power but one needs to rev higher to achieve this.
    If the gear ratios are used to correct this ,so the wheel speeds were the same then the power at the wheels is also the same .
    If there was Zero drivetrain losses the power output of the engine would be identical to the power output at the wheels
    300 ft/lbs at 6000 rpm = 342 hp
    Now if we geared down the output 4:1 the torque is multiplied by this [and the output speed divided by this]
    1200 ft/lb at 1500 rpm = 342 hp
    Ned Ludd and twenty8 like this.
  6. Stan Back
    Stan Back
    Here's a little test I did years ago. First run with regular gearing . . .
    . . . and then a little gear change . . .
    Speed was about the same, but a second quicker E.T. (Notice how courteous I am while drag racing -- I've always let the other guy go first. Could be why I switched to Land Speed.) I wouldn't recommend this for everyone. It took a lot of arm power to turn off the strip with all the added caster.
  7. twenty8
    twenty8
    ^^^ That is how I understand it too.^^^
    I don't get @G-son talking about adding power, as if it was a separate en***y.
    You get power increases by tweaking torque and rpm. Add torque, and increase the rpm where the torque is most effective. The power increase follows as a result, doesn't it?
    SS327 likes this.
  8. G-son
    G-son
    from Sweden
    I was referring to using different engine rpms & gear ratios to get the same wheel speed and compare wheel torque to see what will give you the best acceleration. The peak power engine speed will produce more wheel torque than the peak torque rpm - for that matter, any rpm with more power than peak torque rpm will beat peak torque rpm.
    You don't need to raise the peak torque rpm, you just need to raise the rpm more than you let the torque drop off (at rpm above torque peak). As long as the rpm rises more than torque drops off the power will keep going up. Peak power is the rpm where torque begins dropping of faster than rpm increases.
  9. 19Eddy30
    19Eddy30
    from VA
    I am curious if this was your Ride & let's hypothetically say 500 pounds of torque , 500 hp ,on these tires and this light of a car 1,300 -1,600
    What would you do for traction ?
    @ a Guess , not have drove yet ,
    I would start with a 3:00 gear , 2,000 -2,400 stall Or maybe 2:90 & 2,800 stall ,
    & still need to know & have throttle control before WOT .
    1biggun and Sharpone like this.
  10. Bandit Billy
    Bandit Billy
    ^^^^When the 14" drag slicks are being driven by a blown hemi, does having front spindle mount discs really help that much with 3" tires? This reminds me a of a hot Vegas ****** or that turbo pogo stick @Moriarity owns, fun to look at but do you really want to hit it? HP per IQ ratio needs to be considered.
    SS327, 427 sleeper, RmK57 and 4 others like this.
  11. loveoftiki
    loveoftiki
    from Livonia,Mi
    Less than 3000lbs and more than 300HP with a nice torque curve is perfect for the street…
    and I’m sure a lot of people that think they have 300 HP would be shocked if they really knew what they had…
    my motor is good from 1800-6000…don’t think I’ve seen 6K…but I do like to reach the speed limit as quickly as possible ,when possible, and when it’s safe to do so…and ya feel torque on the street and in the seat
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    My corvette has an 11:1 350 with 492 angle plug heads, solid cam and a man a fre, It probably has 350-400 hp. Plenty fast for me, it holds ya back in the seat , fun to go thru the gears in and if I baby it it gets 24 mpg on the freeway... you heard me 24 mpg... But I don't baby it very often
    WC145, Chavezk21, tomcat11 and 7 others like this.
  13. squirrel
    Oh, you're changing the gear.
    That's just what I said above....in a different way...
    SS327 and G-son like this.
  14. Ziggster
    Ziggster
    I’ve been watching Nick’s Garage from Montreal on YT for over a year now. He specializes in building and dyno testing OT muscle car engines from the late 60s and early 70s. Most builds end up pretty damn close to the OEM specs (gross) for hp & torque even with some enhancements. You’re doing real good if you’re achieving 1 hp/cubic inch using pump gas. A recent test of an Olds hi-perf W31 350 “only” made 325 hp.
  15. DDDenny
    Hmmm
    Where did I put those leaf blowers?
    Hold my beer!
    Sharpone, swade41 and Tickety Boo like this.
  16. Roothawg
    Roothawg
    More formulas....you engineer types.:rolleyes:
    Ned Ludd and Sharpone like this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    I suppose if you spend like 100 grand and build an engine with 1000 hp you won't have to be bothered with doing any math
  18. swade41
    swade41
    from Buffalo,NY
    My "tractor" motor made
    665 tq @2500
    362 hp @2500
    But somehow it still made
    642 tq @6000
    791 hp @6000
    I won't mention the extra tq it made in between but will say it broke 700 by 3000 rpm and didn't dip below that 700 until 5200 rpm
    So yup, all the character of a tractor
    loudbang and Sharpone like this.
  19. Roothawg
    Roothawg
    1000 hp, nah. 500, probably and it won't be 100 grand.
    Sharpone and Moriarity like this.
  20. dumprat
    dumprat
    from b.c.
    Horsepower is ********. Torque makes **** move.
    275 hp and 375 ft lbs is way more fun than 500hp and 175 ft lbs.
    Don’t agree? Buy a “Naws” kit for your Honda and try that out…… lol
    SS327 and Sharpone like this.
  21. swade41
    swade41
    from Buffalo,NY
    Don't base everything on only his channel, I watched a few of his one sided mopar episodes, there's plenty of other well do***ented channels that make more power with same type builds.
    This guy is just one of them
  22. Kerrynzl
    Kerrynzl
    @twenty8
    That is back to front
    Torque is force over distance [met by resistance]
    And as time is factored it become power [Power makes **** move]
    Torque and Power are like twins
    You don't feel the effects of torque unless you ARE the actual resistance [but you do feel power]
    If you put the nose of the car against a brick wall while in gear there is torque [force met by resistance]
    When the resistance is overcome and the wall collapses, and the car f***s off thru the other side, you feel the power [because of velocity]
    Increasing torque multiplication will increase the torque against resistance [which is why a car accelerates better in lower gears]
    Larger torque output also is the same.
    Eventually there becomes a point of equilibrium where there is not enough power to overcome resistance [velocity is part of this equation now] and the car literally won't accelerate any further
    This is the aerodynamic "brick wall"
    The rate of acceleration is calculated as thrust [at the tyre footprint] against resistance [m***]
    Thrust is engine torque x total torque multiplication ÷ wheel radius.
    3000lbs thrust in a 3000 lb vehicle should accelerate at 1g
    With power factored this theoretical 1g could be 0-50 mph or 0-100 mph depending on power output.
    The 0-100 mph example would need 4 x the power of the 0-50 mph example.
    This ^^^^ is why the stock eliminator racers stack as much mechanical leverage into their setups
    They are usually at peak power approx 50 to 100 yards from the end of the quarter [the gains are made from leaping out of the hole]
    This almost sounds like a contradiction, but acceleration is actually a constantly changing velocity [velocity is force/time or torque/rpm] as a vehicle accelerates the torque "could" theoretically remain constant but the RPM increases , therefore power increases
    Sharpone and Ned Ludd like this.
  23. George
    George
    A guy built a curved dash Olds replica, the original had a 1 cyl, 1 HP engine. His had a 2 cyl, 2 HP engine. He figured he doubled the number of cyls & doubled the HP so it gotta be a hot rod...
  24. tjm73
    tjm73
    My daily off topic economy car has 165hp at 6500rpm and a 5 speed stick. It weighs about 3000 lbs. 90% of the time I don't turn much more than 4500 rpm with is only about 110hp. 99% of the time I am running up on all the traffic around me.
    My off topic late model '93 Mustang has just over 400 hp, a TKO600 5 speed and weighs about 3400 lbs. I can barely use it. By the time I'm in 4th gear I'm at going to jail speeds.
    For my '32 Tudor perfection would be 300-ish hp and a 4 speed or a 5 speed. I'm not looking for a race car I can drive on the street. But reality will probably be half that (if I'm lucky) as I wanna keep the car Flathead powered and I don't have deep pockets.
    But really...HP is kind of a bogus "power" number to focus on. Torque is work. HP is an expression of torque versus time. Regardless of the HP I want as much torque as possible as soon as I can get it and I want to carry as much torque as possible through the revs up to around 5000 rpm. After all torque and horsepower cross at 5252 rpm.
  25. Bandit Billy
    Bandit Billy
    We should have a HAMB bench rather meet. Like soap box races, we all bring our fast work benches to a sloped racetrack and let em go! Bench racing! It's awesome baby!
    Roothawg, SS327, wheeldog57 and 3 others like this.
  26. Sharpone
    Sharpone
    A lot of discussion on HP vs Torque when actually they are closely related. As stated HP is a function of torque so at any given RPM the higher the torque the higher the HP will be. The bottom line is cubes rule. Small blocks with snotty cams are fun IMO but are harder drive well.
    Bottom line :
    Horsepower minimum = how slow or how fast do you wanna go?
    Light cars need less HP
    More speed = more $$$s
  27. twenty8
    twenty8
    Hey Kerry, that was not me. You have quoted @dumprat .....
  28. Kerrynzl
    Kerrynzl
    I replied to Dumprat but also tagged you to this response regarding your original question
    sorry for any misunderstanding cheers
    twenty8 likes this.
  29. Ziggster
    Ziggster
    I think the forebears of prewar racing understood that. This vid always brings a smile to my face. Lol!
  30. tim troutman
    tim troutman
    Always a blast to drive my T roadster had a 107 rear wheel rated factory horse power engine 4 speed 427 gear. 2050 pounds . Drove db_US60_0121.jpg the **** out of it 22 years 9 states. Never got out ran by a flat head at nostalgia drags
    WC145 and Sharpone like this.
