Projects Bought a Mercury on purpose
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 4, 2023.
  1. drdave
    drdave
    There's really only one real answer here.... LOL
    Squablow, Sancho and anthony myrick like this.
  2. Messing with another bumper. Had to do some adjustments
  3. ROADSTER1927
    ROADSTER1927
  4. I like this ugly bumper set up
    got to work out a twist on the p***enger side
    Toms Dogs, ffr1222k, bobss396 and 5 others like this.
  5. Any usable 51 taillights or lenses in HAMB land?
  6. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Anthony;
    What is that bumper from? Looks almost familiar, but I can't place it.
    TIA.
    Marcus...
    anthony myrick likes this.
  7. The original one we had to straighten from the wreck.
    The other bumper donated it’s brackets.
    We just about got it straightened.
    One small patch for the fender under the headlight and we’re gonna body work and prime the fender and apron.
    A small repair on the rear body as well.
    Probably straighten the rear bumper in our press next week
    the grill was bent and twisted. It’s getting closer as well
  8. Oh, and wanted to see what the other, less gaudy bumper looked like.
    I guess I’m leaving this one with the ugly bumper.
  9. bobss396
    bobss396
    Go with it, I like ugly...
  10. Had a rotted spot under the headlight on the damaged fender.
    Students made a template then we made a patch
  11. Little more finish work and they hit it handled
  12. 4 pedals
    4 pedals
    from Nor Cal
    I had a good shop teacher in high school, took it all 4 years and was ***istant my senior year, which meant I just goofed off a lot, but there was never anything like this. Is bodywork a separate course?
    Devin
  13. It’s a collision cl***.
    I sneak in some old cool stuff when it fits.
    It’s a 3 year high school course. Unfortunately cl*** time is short. Bout 1.5 hours.
    The welding and cutting cycled every 3 years. But a curriculum change will have 2nd year students doing that every year.
    This is one of the welding and cutting cl*** projects.
    these are pieces that resemble unibody structure. Students prepped them, applied a DTM primer to the inside, a weld thru in the weld area then resistance spot welded them. After that a section was removed (spot welds removed and a slice thru one side) then that section was prepped again and welded back on with a mig.
    Demonstrating how to section body panels.
  14. First year refinishing students
  15. First year students.
    it’s not perfect. Students had some sand scratches they missed. I knew they were there. Now they know what to look for and why.
    Gotta learn somehow.
    Single stage enamel:)
  16. partssaloon
    partssaloon
    I envy the hell out of these kids and what you are teaching them. Sure wish I had someone like you when I was a kid.
  17. Previous owner beat the **** out of a dent with a claw hammer
    got a new 4.5 inch shrink disc
    getting used to the smaller disc. It feels different than the large ones.
    Students made good progress with it.
    Should be almost filler free when done
  18. These hubcaps popped up. 15s look kinda cool
    might pull the trigger
  19. Since we’re fixing the major dents on the merc I’ve considered shaving handles.
    I do like the Lincoln push ****on. The merc only has the one drivers door lock anyway. Could leave it.
    But probably only use em on the front doors. Considering solenoids.
    I’ve installed a pair of the Lincoln’s from @CoolHand in the past. Worked out nice.
    Go flush or no? Hmmmmmm
    I’ll dig thru my junk pile and see if I still have some cable style latches for the trunk.
  20. Squablow
    Squablow
    Those hubcaps are neat, but I wonder how deep your wheel needs to be for them to seat? That base cap looks really familiar, I'm trying to place it. I know I've had issues with hubcaps that wouldn't fit on certain steel wheels because the caps would bottom out on the center of the wheel before seating on the outer rim.
    If they're local, I'd bring one of your intended wheels over and snap it on first, to make sure they'll go.
    ffr1222k likes this.
  21. Mine has OE merc wheels. A regular caddy sombrero fits with the dog dish looking mount removed. Looks like these mount on the outer rim instead of like the other ones I have.
    Internet pic
    This HAMB pic has them on a standard Chevy wheel
  22. Acquired a truck load of old transmission junk. There was a very nice Chevy FW with the Borg and Beck bolt pattern
    SBC FW with the merc clutch.
    The merc input has some wear on it
    need a new pilot bushing for the adapter. No big deal.
    the pile of transmission parts should yield 2 gm OD 3 speeds.
    One Muncie and one Saginaw.
    Also had a new pressure plate and disc for a gm trans in the parts pile.
    I’ve got a bell bor both small and large gm FW.
    Was kinda thinking about using a gm trans. It’s already set up for the Merc trans. Would have to add a slave cyl set up and handle the drive shaft.
    Hmmmmmmm
  23. The larger shrink disc works better
  24. ffr1222k and anthony myrick like this.
  25. J. A. Miller
    J. A. Miller
    from Central NY
    Looks like a nice set!
  26. Not sure
    Washed em off.
    15s. Not perfect.
    Fine for me
  27. I'm sure I'll get corrected if I'm wrong, but I believe the Saturn was only on true Olds hubcaps. I'd run them!
