Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. TA DAD
    TA DAD
    from NC
    I got a new base fabbed up for the Ram air, now to cut a hole in it without messing it up ! plus I got to use my new shrinker/stretcher
  2. TigerFan
    TigerFan
    from Athens, GA
    I just about finished the floor, and got my steering column and wheel mocked up.
    Does anyone have a suggestion for headers or exhaust manifolds for a small block Ford in a Model A on ‘32 rails? I have Vega box.
    rod1, Cooon, mad mikey and 8 others like this.
  3. TA DAD
    TA DAD
    from NC
    I got the base welded up with no problems. I think I will venture out and find a slip roller to do the center section. IMG_1162.JPG IMG_1164.JPG
    X-cpe, loudbang, mad mikey and 5 others like this.
  4. Poverty cap
    Poverty cap
    I moved to Louisiana recently and got my 62 Belair out of storage and trailered down. Last few days I’ve been cleaning getting ready to bring in the shop. 21C008A8-A3EF-4443-8A24-DCD250176C22.jpeg 075DDDB2-396C-425D-8AEC-BB8F98E66F04.jpeg
  5. milwscruffy
    milwscruffy
    Prepping some parts for an old 50's Chevy that'll be for sale in spring. IMG_2154.JPG IMG_2155.JPG
    osage orange and j hansen like this.
  6. TA DAD
    TA DAD
    from NC
    skooch, orbitup, loudbang and 5 others like this.
  7. RICH B
    RICH B
    Finished blocking out the front fenders and squirted some black sealer on them; hauled them up to the garage, and hung them in place. Now on to finish the nose of the hood without messing the fenders up; not sure why I didn't do that before I took the fenders off.
    Chucky, TA DAD, lurker mick and 3 others like this.
  8. nobby
    nobby
    IMG_20240113_193255.jpg IMG_20240113_193302.jpg IMG_20240113_193307.jpg started doing the dash on the correct side
    done did the firewall, then realised the battery wont go on the firewall as the thing stuck up too far, got to put it under the seat, run longer cables to the elastic trickery doohickeys
    Chucky and j hansen like this.
  9. RICH B
    RICH B
    Spent the afternoon fitting the fender to cowl bolts, the inner fender bolts, and the front pans; amazing how things that were bolted together a year ago fail to line up again.
  10. 67drake
    67drake
    from Muscoda WI
    Just going over parts of my ‘62 260 chasing threads, cleaning gasket surfaces, ect getting ready to ***emble. Found stripped threads on one of the fuel pump bolt holes in timing cover. Better I found it now than later! :)
    Chucky, mad mikey and j hansen like this.
  11. 67drake
    67drake
    from Muscoda WI
  12. TA DAD
    TA DAD
    from NC
    I made a little progress this week on my air cleaner. The snorkels are welded in place, I added three stops to locate the filter element. There is still some clean up work on the spot welds and then get it closed up and make the top. IMG_1192.JPG IMG_1193.JPG
  13. TA DAD
    TA DAD
    from NC
    The air cleaner is finished. I am very satisfied with how it turned out. Now to install some inlets in the front fenders and run the hose. IMG_1195.JPG IMG_1198.JPG
  14. choptop40
    choptop40
    Run it through the rectangles in the grille.....
    40two, loudbang, X-cpe and 1 other person like this.
  15. lake_harley
    lake_harley
    Many of you probably know how bulky and ugly a marine intake/exhaust manifold is for a 120 HP Mercruiser engine. Well, over the last couple days I cut all of the "marine" stuff off of one to use the intake portion on a Chevy/Mercruiser 4-banger I plan to use in my Model A Tudor. It took about 2 days, a sawsall, cut-off wheel, milling machine, bandsaw, angle and straight die grinders with sanding discs and a carbide cutter, and a metal chip in one of my eyes to convert one to this......
    Lynn
    Chucky, loudbang, X-cpe and 3 others like this.
  16. alanp561
    alanp561
    o_OYou're only issued one set of eyes! You weren't wearing your safety gl***es, were you:oops:? You're almost a grown-up, how many times do you have to be told:mad::rolleyes:? Sorry, I was just repeating what my father always yelled at me:(.
    brading and 61Cruiser like this.
  17. lake_harley
    lake_harley
    You are absolutely right. I looked for some safety gl***es today and couldn't find any in the shop but I'll guarantee you I will be picking up a pair of safety gl***es.
    I didn't have much grinding left to do with a carbide cutter today but I'll guarantee you I made sure I was positioned so that the chips were being thrown out away from me.
    Lynn
    loudbang and mad mikey like this.
  18. dln1949
    dln1949
    A01B978B-C0E5-4844-A4BA-41C3439700F8.jpeg Shoot, all I got done was to install the windshield.
    Chucky, 40two, alanp561 and 7 others like this.
  19. poorboy
    poorboy
    IMG_7304.jpeg I wired in this universal turn signal kit that my wife got me for Christmas.
    Chucky, alanp561, mad mikey and 2 others like this.
  20. Pontmerc
    Pontmerc
    from Finland
    Cleaning snow, that if officer asks, sticker is visible. IMG_20240121_131533.jpg
    Chucky and mad mikey like this.
  21. MMM1693
    MMM1693
    TA DAD Nice work!
  22. TA DAD
    TA DAD
    from NC
    They have to go in the outer fender
    Thanks, I have really enjoyed building this truck. Other than the store bought solid motor mounts everything is home fabricated. So the old air cleaner was just of of place. And this is what I came up with. Hopefully it will pick the truck up and not slow it down !
    Chucky, loudbang and mad mikey like this.
  23. TA DAD
    TA DAD
    from NC
    No un-ringing this bell ! ( not that it really matters in the whole scheme of things ) Just trying to get my thoughts together on how to do it. IMG_1201.JPG
  24. jrod60
    jrod60
    from Katy, TX
  25. Bandit Billy
    Bandit Billy
    I like it! One suggestion, add a bug screen to your design if you haven't already planned for one. My 442 has fresh air intakes under the bumper and they pick up leaves, rocks, insects and even a plastic bag once. Your engine will definitely enjoy the added cool air.
  26. nochop
    nochop
    from norcal
    Should be going to prime soon 72747644204__63EDB8A1-890D-4BF0-9DF1-E255AACC834C.jpeg
    Gastrap, charleyw, TigerFan and 11 others like this.
  27. MCjim
    MCjim
    from soCal
    Made a set of door access plates out of my old mail box; so I can hang my, new-to-me, old original door panels. IMG_8126.JPG IMG_8127.JPG IMG_8130.JPG IMG_8132.JPG
    rod1, guthriesmith, Chucky and 4 others like this.
  28. TA DAD
    TA DAD
    from NC
    Good point, Thanks. I had not thought that far thru it. One thing I did think of this morning is the hoses in the wheel wells will be exposed to road debri. But this thing sees limited use as I am a worn out old guy and my travels are not many these days. I stopped by a buddies shop this afternoon IMG_1203.JPG and this piece of stainless was laying there so I probably have the inlet screen taken care of.
    Chucky, mad mikey, loudbang and 4 others like this.
  29. Pontmerc
    Pontmerc
    from Finland
    Drive with it to work and back home.
    Because my wifes suburban broke oil pump shaft and i gave my 71 220d mercedes her to commute. 17060192536251630791353642521790.jpg 1706019334393713920554510619895.jpg
  30. TA DAD
    TA DAD
    from NC
    I am still chugging along on this project. The whole truck is very easy to service so it took about two minutes to pull the fender off so I could get it up on the table. Then my original idea did not go as planned , so after a couple more attempts I got back on track. I plug welded the the snorkel into the fender that way it keeps the same look as the rest of the truck as far as the welds go. The inlet is about 3/16 of an inch proud of the fender so I have to grind that down and I might weld it in solid and the plan right now is to put a couple pieces in the replicate the grill bars. IMG_1208.JPG IMG_1213.JPG IMG_1214.JPG
